Question about Hoover U5194-900 Mach5 Multi-Chamber Cyclonic Vacuum Cleaner Bagless Vacuum
It shut off and will not restart
I have a Hoover Bagless Multi-chamber cyclonic. The model number is U5194-900 and the serial number is 040800130499. I was using my vacuum and it was stopped. I cleaned everything and let it sit for a while and it still would not not start again.
  • shan4pg448 Apr 26, 2009
    Mine did the same thing. When it happened it was less then a month old and everytime we tried to start it it still won't turn on. I am getting sick of using my wet/dry vac anyone got a 800 number for hoover
  • shan4pg448 May 10, 2009
    That was one of the first things I tried
All the filters have to be removed and cleaned or replaced
Posted on May 09, 2009
Sh40060 canister hoover vac beater bar moter has no power
replace it can be gotten at guarantee vacuum and sewing center and will only cost about 25 to 30 dollars
Mar 17, 2014 | Hoover U5194-900 Mach5 Multi-Chamber...
Replacing the filters in a hoover mach 5
The filter is located under a cover directly under the bag in the bag compartment. That's the only one I can think of.
May 15, 2012 | Hoover U5194-900 Mach5 Multi-Chamber...
Hoover Mach 5 turns off after 5 minutes of using. Can you advise the problem?
5 minutes everytime? If so, raise brush all the way, and vacuum next to nothing. in fact, tilt vac up so the brush touches nothing. wait 5 minutes. If it doesn't shut off, your brush is set too high. if it does, the motor is over heating. make sure bag is empty, no debris in brush, filters clean and make sure you're not plugged into an outlet that a breaker on the outlet can pop too.
Sep 28, 2010 | Hoover U5194-900 Mach5 Multi-Chamber...
My mach 5 vhoover vacuum cleaner shuts itself off alsomst as though it is overheated
No your motor is going bad. Have you ever owned an electric fan. If you can remember when the motor started going bad on it the fan would quit turning on its own.Your vacuum is doing the same thing. Please call Hoover and order a new one or go to ebay type in the make and model..
Aug 27, 2010 | Hoover U5194-900 Mach5 Multi-Chamber...
Hello,We have an Hoover Mach 5 Cyclonic vacuum that has no suction. We have cleaned and checked all hoses, belts & filters. Please help us.
With this model, remove the dust tank, and turn it on, check for suction at the lower intake. If you have suction, install the tank and remove hose, and check for suction there. keep following until youn lose it. Then you problem will be between those 2 areas
Mar 27, 2010 | Hoover U5194-900 Mach5 Multi-Chamber...
How do I replace the v-belt in my Hoover Multi Chamber Cyclonic vacuum
its not the v-belt its the idler pully, ours did the same thing, need to get it warrentied
Dec 23, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Mach 6 shuts off
If the vac shuts off and then turns back on after waiting a while. could be a thermal fuse. it is in the motor compartment. recommend a pro shop service this issue.
Sep 27, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
I can't figure out how to get all the lint/junk out of my bagless hoover mach 4.
After you remove the cup, remove the foam or hepa filter. Reach up inside, where the cup & filter go and there will probably be a piece with what looks like fins on it. Unlatch this. It is a prefilter, to catch the big stuff that gets past the cup.
Jan 04, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Hoover U5194-900 Mach5 Multi-Chamber Cyclonic Vacuum Cleaner Bagless Vacuum Logo
260 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
