Question about Pride Jazzy 1113 ATS Indoor Power Wheelchair
Jazzy 1113 batteries go dead quickly even new batteries
  • 32 Answers
It is not uncommon for some of the new batteries available today to be defective...load test them
Posted on Apr 20, 2009
What batteries do I need to buy for my jazzy 1113 power chair?
Your chair uses two U-1 batteries.
Here's the manual:
http://www.pridemobility.com/includes/download.php?f=Owners_Manuals/US_Jazzy/US_Jazzy_1113_ATS_om.pdf
Since you're about to replace them anyway, you might try something else first..
Your charger is a "smart" charger. If the charge on the batteries is too low, the charger won't recognise them as bateries, and won't charge them.
Get access to the batteries (it's in the manual) and disconnect them. Keep track of where the wires came from. Use an old, non-"smart", car charger to put a quick charge on them. Bring them up to 12 V each, or just an hour apiece.
Hook everything back up and try it again with the Pride charger.
Good luck.
Feb 04, 2015 | Pride Jazzy 1113 ATS Indoor Power...
Pride jazzy 1113, controller light scroll back and forth, wont move, i bought one new battery, it has full charge other battery is a little over 10 volts. is there way to test charger with volt meter?
The voltmeter should read 29 volts when on. You should never replace one battery and leave an old battery in the chair. Replace them both at the same time.
Oct 17, 2013 | Pride Jazzy 1113 Power Chair
JAZZY 1113 AFTER CHARGING 10 HOURS SHOWS ALL LIGHTS, THEN AFTER AN HOUR OF USE IT SHOWS 1 RED BLINKING. BATTERIES ARE ABOUT 1 YEAR, IT READS 26 VOLTS AT THE PINS ON CONTROLLER. ANY SUGGESTIONS?
Mary yep Even though the batteries are charging they are not holding the charge to provide enough power for the chair. Usually you have one battery that is weak and causing the problem but both batteries must be replaced. If Medicare paid for your chair then they will pay for 80% of the new batteries. You can contact the provider that sold you your chair and ask if they can replace your batteries. If not, you can contact Repair Express @ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 to have tech come out and repair the chair for you and they will bill Medicare for the cost of repair. Hope this helps
Feb 28, 2011 | Pride Jazzy 1113 ATS Indoor Power...
The jazzy 1113 will not start, when you press the power button the speed light comes on gets full and then turns back off
How old are the batteries? If you've had them for a few years it might be time to change them. Even if batteries are charged correctly they eventually lose power with use and need to be changed. Here is a link to the battery needed for the Jazzy 1113 http://www.replacementupsbattery.com/UB12350-NB.html
Nov 08, 2010 | Pride Jazzy 1113 ATS Indoor Power...
Jazzy 1113 ats won't start
Nov 04, 2010 | Pride Jazzy 1113 Power Chair
Have a jazzy 1113. The speed profile lights flash then the chair shuts off. The batteries show full.
The flash of the speed lights indicate that you are in the charger inhibit mode and if the charger is not plugged in then you have a problem that needs to be checked by a tech or your provider that sold you your chair Sorry I don't have a quick fix
Sep 25, 2010 | Pride Jazzy 1113 ATS Indoor Power...
Jazzy 1113 will not charge, batteries are new, light blinks indicates charging when plugged in but fails to increase usage lights.
Most likely your charge isn't charging properly. You need a multimeter to test the voltage at the joystick. In the 3-pin femal connector measure the voltage across the two horizontal terminals. It should read about 24 volts. Now plug it into the charger and see if the voltage increases, if not, charger needs to be replaced. You can get one that plugs into the joystick on ebay a lot cheaper than going to the mfgr. about $50.00 or so. Even if the lights are blinking, it may not be putting out sufficient voltage to bring the batteries up.
Dec 30, 2009 | Pride Jazzy 1113 ATS Indoor Power...
We have a Jazzy 1113 Power Chair. The chair is fully charged, but does not move. What might be the problem?
The battery of the chair is dead. It will say its charged but then when you take it off it will die.
You have to replace the battery.
I had the same exact problem with my father.
Dec 30, 2008 | Pride Jazzy 1113 ATS Indoor Power...
Pride Jazzy 1113 ATS Indoor Power Wheelchair Logo
193 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
