Question about Epson LX-300 Matrix Printer
Dotted spaces are visible everytime i print
I just change the ribbon of the printer epsonlx-300+.. when i started to print the first page of my work it works and the text are better compare to the old ribbon i change but all the spaces between and after the words or text have dots.. it beggins from the very head of the paper till the bottom.. may ask your help if what is going on with the printer?.. thank u
    President:
  • Epson Master
  • 2,022 Answers
See may be it is your printer head problem see if you can remove the head and see may be ther is one or two pins are not working . bye
Posted on Sep 28, 2007
Hai my printer epson lq 300 + printing issue zigzag kindly solve this issue
Hello This condition of Dot Matrix printer only due to
1. Bad ribbon cartridge (25%) 2. faulty print head (75%)
First replace your ribbon cartridge and try printing, if not OK then you have to replace the print head.
Good Luck
Jan 08, 2011 | Epson LQ 300+ Matrix Printer
How can i change font in epsonlx-300-II printer
Here is how:
1. Printer should be turned on, but not printing
2. Hold down PAUSE button for 3 seconds. The pause light will flash and the 2 tear off (FONT) lights shows the current font selected
3. Press Tear off(FONT) button to cycle thru fonts till light indicate the font you want. When you select the font needed it stays in use as default till you change it.
Note: Some software can change the printer font selected.
If need more information about your printer check the manual
Jul 31, 2010 | Epson LX-300+II Matrix Printer
I have a Samsung CLP-300N laser printer. I replaced the black cartridge about a month ago and now everytime I print, the left side of the page prints very lightly (barely visible) while the rest of the...
You have to call the service, because developer is broken. The Toner cartridge is ok. Don't buy another one. The service tecnician updates the Firmware and replace the black developer.
Oct 22, 2009 | Samsung CLP 300 Laser Printer
Print problem
Are you using dot matrix printer ? related to your statement that you've change the ribbon.
It's could be problem with printer's print head, could be one or more
pins are broken
Sep 14, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
RIBBON BECOMES LAX AS ALSO SLIPS OUT OF HEAD AND STOPS PRINTING ALTOGETHER. PRINTER LQ 300 +
make sure the ribbon you use it is genuine epson ribbon. and also adjust the liver by keeping 4 point .
Sep 08, 2009 | Epson Dot Matrix LQ-300+ Printer
Programs Lock until Printing Finished
1. Click on START, CONTROL PANEL, PRINTERS AND FAXES (or PRINTERS AND OTHER HARDWARE).
2. Right click your printer, and select PROPERTIES. (If your printer is not listed, click on VIEW INSTALLED PRINTERS first).
3. Select the ADVANCED tab.
4. Select SPOOL DOCUMENTS BEFORE PRINTING.
5. Click on APPLY (if applicable), then OK.
6. Restart your computer.
7. Try printing now.
Aug 14, 2008 | Epson Stylus Photo R300 InkJet Printer
Zebra Z4MPlus Ribbon Wrinkles
I changed the print head, and the issue was solved.
Aug 01, 2008 | Zebra Z4Mplus Label Printer
Problem with my Epson Dot Matrix printer
Chances are, you didn't installed the ribbon correctly...
A. Open the printer cover
B. Use a pin to guide the ribbon between the print head and the ribbon guide, then turn the ribbon tightening knob to help feed the ribbon into place, it shouldn't be twisted or creased.
C. Slide the print head from side to side to make sure it moves smoothly
Feb 21, 2008 | Epson LX-300 Matrix Printer
Horzontally double printing & characters are not clers.
Is the ribbon tight or sticking, If ribbon can't turn, it delays entire carriage, you will notice that if you move carriage up and down by hand ribbon turns, I have seen sticky ribbon s cause problems as well as gearing that drives ribbon with wornout gears
If self test fails then all faults /i can think of on these is
  • Dry rail/dirty bearing
  • incorrectly manufactured ribbon
  • Damaged dot head
  • broken/breaking ribbon interface carriage cable
  • worn ribbon drive gears
  • worn/dirty ribbon drive rail
  • main board
Nov 17, 2007 | Epson LX-300 Matrix Printer
try to clean the encoder strip, it is a film like strip. this might solve your problem.
Sep 20, 2007 | Epson LX-300 Matrix Printer
Epson LX-300 Matrix Printer Logo
53 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
