Question about Brother MFC-7220 All-In-One Laser Printer
Brother laser cartridge refills
I have been successfully refilling Brother TN-2025 cartridges but now my MFC-7220 will not recognise the refilled cartridge. Cartridge has been refilled once only. Any suggestions? Email: [email protected] Thanks. John.
OK.. I agree that your problem is with the flag gear. However, there is a specific location in which it needs to be situated. The purpose of the flag gear is to trip a reset actuator on the left side of the printer. The correct position of the flag gear needs to be set so the reset actuator is depressed 3/4 of the way AND where the flag gear moves out of the way once this is done. If the flag gear is moved all the way forward, you run a risk of the gear mechanism inside not rotating it out of the way...which could leave you with a 'no cartridge installed' message. When the manufacturer of the toner cartridge made this unit, they decided to put a mark on the side to, evidently, let the assembly team know where to set the flag gear. Great for us :) On the outside plastic piece that you have to remove to get to the flag gear, you will see a diagonal line and a view window. When you rotate the flag gear, you will eventually see a portion of the white gear in that view window. Line up the white gear portion with the bottom of the diagonal line (typically two gear teeth), and you're done. Assemble and run!
Posted on Aug 01, 2008
  • wjk-mka Jul 29, 2011
    Great !!! What a simple way to get more life out of cartridges. I "knew I had plenty of toner as I had decanted remains of 2 cartriges in to one -that made it full so I could not get a third one in ! Reset as described - works great ! Cannot believewaht a manufacturers rip off this is ( and how many "Catridge Refillers" simply reset the gear and send it back out . THanks a lot Mack4life 01
You will need to reset the Flag gear. This is situated at the other end of the cartridge to the refill hopper. There are 3 screws that you must undo first, you will notice a small white flag gear, this needs to be turned back to the beginning of the curved section. After removing the screws, CAREFULLY remove the end plate and pull the flag gear out slightly and return it to the beginning position, which is the other end of the curved section. Put your cartridge back together again..Your printer will now accept this refilled cartridge
Posted on Apr 27, 2008
    President:
  • 2,022 Answers
See it is properly install or try with cleaning or just shake it . if still it is not working then you need to install new one.
Posted on Oct 06, 2007
SOURCE:
How do you reset counter on Toner for TN-360
No, If you use a refill in your recent toner cartridge you need to reset the toner, if you use a new toner cartridge, no need to reset.
Aug 28, 2014 | Brother MFC 7840W Printer
I HAVE A BROTHER LAZER MFC 9440CN, ITS ASKING ME TO RPLACE THE TONER, CAN I REFILL IT OR I HAVE TO BUY A NEW ONE
u can do both.... but refilling is not good for printer and also the print quality would be less.... and if anything happens to the printer, they will not take this printer under warranty coz of this reason.... so i would suggest u to go for a new one...
Mar 18, 2011 | Brother MFC-9440CN Laser Printer
Hello sir my brother tn-3250 laser toner blinking yellow light
Toner Blinking yellow LED indicates that the toner cartridge is nearly empty. Buy a new toner cartridge or refill the cartridge. Refilling the TN cartridges is quite simple and you can do it yourself.
It is a very simple process. Please refer to this video.
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Jan 17, 2011 | Brother HL-5250dnt Laser Printer
I replaced already new toner cartridge for my brother fax machine mfc-7220 but still the on screen message is appearing on the display "TONER LIFE END". Pls help me to solve this problem. Tnx and God bless...
I replaced already new toner cartridge for my brother fax machine mfc-2820 but still the on screen message is appearing on the display "TONER LIFE END".
Apr 12, 2010 | Panasonic KX-FL541 Plain Paper Laser Fax
My Brother HL-2170W only gets about 300 pages per toner cartridge unless I put a piece of masking tape over the whole in the cartridge through which the printer ascertains how much ink is left. When I...
It is perfectly safe to cover the sensors on either side of the cartridge. What works best is to cover it with a piece of black electrical tape. The cartridge is set up so that when you put it in the printer, the printer shines a laser from one end of the cartridge to the other. This laser reads the toner level. If you cover both sides up with tape, it tricks the printer into thinking the cartridge is full of toner.
Hope this helps! :)
Mar 23, 2010 | Brother HL-2170W Laser Printer
Toner Life has ended
Did you pull the plastic tape on the cartridge?
Feb 11, 2010 | Brother IntelliFax-2820 Laser Fax
I have a brother 2140 printer, it ran out of toner and i refilled toner starter cartridge , and error message comes back to clean the corona , i replaced ther cartridge with a new tn-360 cartridge, but...
When it says to clean the corona, on the drum there is a purple tab that moves from one side to the other. run it back and forth a couple times that should solve the problem.
I dont recommend refilling the cartridges, we have had several issues in repairing those printers with refill. if you must use refills, i would recommend getting 2nd or 3rd party manufacturers.
if you need help, you can contact us.
thanks adi
Dec 31, 2009 | Brother HL-2040 Laser Printer
Printer catridge
If you just want to REPLACE the toner cartridge, open the front door and jiggle the combined toner & drum units out. push down on a blue tab on the side to release the TN-350 toner cartridge and lift it out of the DR-350 drum cartridge. If you have the toner cartridge out and want to refill it you7rself, DON'T. You can buy toner with about the right size grains, but Brother uses toner with grains that are much smoother and rounder than that aftermarket stuff. The toner is constantly stirred during the print process, and the rough-grained aftermarket toner puts up so much resistance that it often breaks a gear in the body of your MFC. Brother usually doesn't cover that one in their warranty.
Feb 05, 2009 | Brother MFC-7820N Laser Printer
Brother MFC-7420: Toner low - massege. But catridge is full.
The magic word is "refilled." Not all refilled cartridges work correctly. Try another cartridge (a new one to be absolutely sure) to verify the printer is working properly. But my money would be on "defective refill."
Dec 05, 2008 | Brother MFC 7420 All-In-One Laser Printer
Replace ink toner message
Is it refill? if not then try leveling powder in cartridge by gently shaking, Take back as faulty, or reset new toner lever on left front of cartridge. Check toner is seated correctly in drum and drum seated correctly in machine.
Nov 08, 2007 | Brother MFC-7220 All-In-One Laser Printer
Brother MFC-7220 All-In-One Laser Printer Logo
438 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
