Question about LG WD-1080FD Front Load Washer
Soap dispenser slow leak
During the wash cycle my soap dispenser has a very slow drip down the side of my machine.Sometimes it is more noticible. Is ther a way to dismantle the dispenser drawer to check or repair this problem. Anthony
If you remove the lid, you can then remove the soap dispenser which in my case was getting very bunged up. I used soem fluid called swirl it (normally used for deposits in spa baths). Once clear the problem was resolved.
the problem is that as the water is fed in through the pipes at the back of the dispenser, it follows tracks with a sharp bend at the fornt which is where the blockages seemed worse.
Posted on Oct 16, 2007
    President:
  • 1,294 Answers
Plug off the wall socket first. Remove screws to remove the top of your machine. Check to see if the rubber hoses are connected well to the dispenser chamber, if not connect them properly. Another thing could be your dispenser drawer; you could pull it out gently to clean it; or you could even use a tooth brush for access.
Posted on Sep 21, 2007
SOURCE:
Water leaking during wash cycle
I've had this problem and immediately assumed it was the door gasket. However I actually sat & watched it for a whole cycle & discovered that water was running back out from the soap dispenser area and dripping from the bottom of the washer door. I removed the dispenser tray & discovered an inch of built-up soap had accumulated inside the washer, which was not allowing the water to drain through properly. Once I removed the soap & residue, problem solved.
Jul 30, 2010 | Washing Machines
Water leaking into soap dispenser when machine off
faulty water valve turn both off to see if it stops then turn on one at a time if it leaks thats it
Dec 15, 2009 | Miele Touchtronic W3033 Front Load Washer
My soap dispensar inside does not open during wash
its just a bad (failed ) dispenser. replace it . this should correct problem . mm
Dec 07, 2009 | Washing Machines
GE whre5260e1ww zh133346g top load washer is leaking small amount from the bottom of the machine during wash cycle? I took the back of the machine off and the pump and motor assembly had broken off from...
Hello there:
Here is a few tips that might help you out
Hope that they are very helpful for you
Best regards Mike
Washing machine is leaking Washing machine leaks are very common. There are many places a washing machine can leak from although most leaks come from the same few places. The most common cause for a leaking washing machine is the door seal. Door seals often get holes in them and water leaks down the inside of the washing machine which then runs out under the front. Water leaking down the front of the washing machine from the door can be caused by a worn door seal (the flange part that the door glass presses against when closed) or something trapped between the door seal and the door glass which breaks the seal. If the door seal doesn't look worn, or it's too young to be worn, then try cleaning the door seal's flange and the door glass on the inside of the door. Bits of cotton, un dissolved washing machine detergent etc can cause a leak.
Soap dispenser leaks
The next most common cause of a leaking washing machine is the soap dispenser. Leaking water from a soap dispenser is often caused by a blockage, or water pressure that is simply too high. Despite seeing many leaking soap dispensers, I've never seen a soap drawer with a seal, they just rely on water not getting to the front which is not really good enough. Some Hoover soap dispensers in particular, are renowned for leaking, and over the years Hoover have had to introduce modified soap dispensers twice.
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and the hose wasn't wide enough. Un dissolved powder from a tablet or lumps of detergent through poor hot water pressure can block this hose solid. (Note: water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning)
Finally, black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases I've had to replace the dispenser.
Tips for finding a leak on a washing machine
  • If you have a leaking washing machine, and you can't see where it's coming from, shove some newspaper underneath the washing machine. The slightest drop will give a clue where the water is leaking from. Pull the sheet out regularly to check for water leaks.
  • Water can run round things and drip onto other parts. Be careful with your diagnosis, as water dripping from a hose at the bottom could actually be leaking from somewhere else higher up.
  • Leaks usually leave marks, so it's possible to see something is leaking even without witnessing it. The soap suds that come out with the leaking water leave white trails. Rust is a good indicator of a water leak too. However, if you have had a previous leak cured, the "evidence" of a leak may still be present so be sure you don't blame a part that was repaired in the past.
  • If the washing machine leaks only at the end of the wash, when water is being pumped out. Make sure water isn't backing up and cascading over the top of a blocked drain pipe in the plumbing.
  • WARNING: Don't get electrocuted trying to witness a leak. It's dangerous running the washing machine with the top or back off.
Nov 13, 2009 | GE WDSR2080D Top Load Washer
Roper Dishwasher leaks from float or float switch onto floor
you could be usiong way to mauch soap try filling only one of the soap trays or even try doing one wash without any soap at all
this unit tends to do this if you have to much soap in the unit left over from the last load...
beyond that your machine is proibaly tilted to far forward you can lift it, by lowering the front legs begind the toekick
Oct 25, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
Whirpool Duet - Soap not getting into wash cycle
O.K. Is the water draining out properly? If the filter is blocked then your washing will be churning in dirty water as the machine will drain for a maximum time then rinse etc. in the used water.
May 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Mar 01, 2008 | Dishwashers
Lg wm1812cw front load washer
We had the same problem- for us it was because we were mixing laundry booster (Oxyclean) with liquid soap in the dispenser. It seems the water running through the tray had insufficient pressure to properly flush the tray out, so residue accumulated on the back & underside of the tray. Our water pressure is good here, and we don't use a water softener or filters that can reduce the pressure. Unfortunately it seems to just be a bad design of the soap dispenser tray.
We also had a problem with water/bleach leaking from our soap dispenser- when we used the bleach compartment in the dispenser we got leaks dripping onto the floor from behind the front cover of the washing machine. It was running down the front of the washer behind the front cover & coming out onto the floor. The repair guy said this was because the dispenser tray was pulled out too far, but the reason we were pulling the soap tray out so far was because the bleach compartment was too far back in the tray to use if we didn't. Now we just leave the drawer partially closed & pour the bleach directly into the soap compartment along with the soap.
Jan 16, 2008 | LG WM1814CW Front Load Washer
Soap dispenser drip
Normally you shut off the wall valve when you are thru with your washing. If there is a leak in the front area (important: first take the plug off the wall) open up the top of the machine and check whether the three rubber tubes are in place at the soap dispenser - one of them may have come off. Refit or replace if rubber tube is damaged; would be good to check all the tubes. Another thing would be to check that your soap dispenser is not clogged. :)
Sep 21, 2007 | LG WM1815CS Front Load Washer
LG WD-1080FD Front Load Washer Logo
158 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
