Question about LG WM-2077C Front Load Washer
Ue error during spin mode (b4 spin up happens) empty. wm3677hw
LG WM3677HW ALLINONE.
This happens even when run with NO LOAD!!
Gets to spin, does back/forth balancing act for 7min before UE flashes. Hit start/pause to clear, again to restart. sometimes will go thru, sometimes clothes are still damp at end of dry cycle. Won't happen if choosing spin only, will spin full speed full load no problem.
  • kjjones Apr 20, 2009
    1. full load or empty spin only will spin hi and completely.
    2. only happens 7 min. after entering the spin mode, never attempting to engage spin, only back and forth action as it is trying to balance load. and will do it even whith empty tub?
    If I put it into a spin only mode it spins up fine. error only seems to come up during a normalcycle run.
    Thanks for your input Sunny
    President:
  • 373 Answers
An UE Error Code is indicative of a “Unbalanced Error”. This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum. Also you have mentioned that the drum with full load has no such problem. It means that the drum cannot manage its weight in that position. So the problem might b adjustable easily. Try to remove the top panel and check for any slight movement in the position of the drum. Leaving it continue this way might increase the probability for the error to be repeated with the load. Will add some links related to internal diagrams of this model when i find some that might help you to check the drum inside.
Good luck with the machine.Please do rate my solution and post comments and results.
Sunny.
Posted on Apr 20, 2009
LG WM3677HW all in one washer dryer water not draining and have cleaned out drain filter. what now?
i had the same problem turns out it was a pressure sensor. as water fills it the tub air gets pushed into this sensor to fill to the appropriate level or to drain.
Feb 23, 2011 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
We have a wm3677hw LG washer/dryer combo. it goes into the dry cycle and keeps adding water. what is the problem. we have cleaned all the internal tubes. checked the lower heating element and it is not...
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair.It is located on the blower wheel housing inside the rear panel to the exhaust duct. Please get back to me if you have any other questions.
Kevin
Jan 16, 2011 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Ok my LG front loading washer agitates but when it comes to spin it makes a very irritating high grinding noise and does not spin. There is no error displayed but that may be because I stop it before it...
I have a similar problem. The washer was showing error code UE, but would tumble when empty in test mode, but would not spin and made a grinding noise. The bolt that attaches the rotor to the motor was loose and the rotor was spinning on the spindle that rotates the drum. I tightened the bolt, and it spins when empty, but still gives a UE error code when full. Remove the rear cover and check the tightness of the center bolt.
Dec 16, 2010 | LG WM-2277HW Front Load Washer
Le comes up and stops cycle
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jun 28, 2010 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
LG WM3677HW combo unit sets a LE code and stops in mid cycle. Motor was replaced but still does it.
Sensor maybe???
Here is a tip about the LE code that gives other thoughts also...
heatman101
Apr 23, 2010 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Lg wm3677hw combo washer drain pump repair question
You replace the whole drain pump. Pretty easy to do from the opening in the bottom by resting the unit on its back. (Make sure you drain the unit completely) You should be able to get the drain pump (pt #4681EA2001D) from http://www.encompassparts.com/lgconsumer/ for less than $50 + s&h.
Aug 31, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
"UE" error code LG washer wm0642hw
This is an Imbalance code. Your issue may be with:
  • The load is too small
  • The appliance is tilted
  • Laundry is gathered to one side
  • Non-distributed things are put into the drum
Try adjusting the load size, and make sure the unit is level.
Aug 07, 2009 | LG WM1814CW Front Load Washer
LG WM-2077C Front Load Washer Logo
724 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
