Question about Dell ADA745 Computer Speakers
Problem with Dell AX510 Soundbar
I installed a brand new Dell AX510 sound bar on my flat panel monitor. I get no sound. Everything is plugged in...i doublecheced to be sure all mutes are off...there is a soundcard....what gives?
  • 6 more comments
  • Michel Savard
    Michel Savard Apr 10, 2015
    I have quite of few of those that the speakers do not work, they are stuck into mute from the small board where the headphone jacks plug into.
  • Michel Savard
    Basically, it send a +6 Volts out to the amplifier board inside to mute the speakers while the headphones are in.
  • Michel Savard
    If you leave the headphones in for a long time there are 2 transistors that control that signal, +6 = mute +12= unmuted
  • Michel Savard
    There is a 20K resistor from +12V to the pin of the mute signal going to the main board.
  • Michel Savard
    If you add a 20K resistor to that pin and the other end to the switched side of the headphone jacks (the one that would go to the transistor), you will get a muted +6 volts out when headphones are plugged in and +12 V unmuted when headphones out
  • Michel Savard
    That is probably the easiest fix or else just remove the transistors and leave it unmuted all the time.
  • Michel Savard
    The amplifiers with 2 heatsinks are TDA1517, that is how I figured out the mute signal.
  • Michel Savard
    Not sure what these folks are talking about bios drivers etc, problem is simply with speaker bar???
In order for your sound to work you have to disable the on board sound in the bios . unless you already did the , then i would return it and get a different one.
Posted on Apr 20, 2009
  • Michel Savard
    I have anumber those going bad, there are 2 small transistors on the small board where the headphones plug into.
How do I replace sound bar on monitor?
Deb Powell,
Reverse the steps listed below. They are for connecting the sound bar.
1. Working from the rear of the monitor, attach the Soundbar aligning the two slots with the two tabs along the bottom rear of the monitor.
2. Slide the Soundbar to the left until it snaps into place.
3. Connect the Soundbar with the power brick.
4. Plug the power cables of the power brick into a nearby outlet.
5. Insert the lime-green mini stereo plug from the rear of the Soundbar into the computer's audio output jack.
NOTE: Soundbar Power Connector - 12V DC output is for optional Dell Soundbar only.
NOTICE: Do not use with any device other than Dell Soundbar.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 16, 2016 | Dell E197FP LCD Monitor
Why does the soundbar play with Roku but no sound comes from the bar when on regular t.v.
You have to go into the audio set up screen on the TV and direct TV sound to the output cable connector you used for the sound bar. Example: Optical, digital.
Jan 01, 2016 | Samsung Refurbished 5003 Series - 40"...
Purchased iLive Bluetooth HD soundbar 32", hooked up to TV and makes noise when on a HD channel, Samsung tv
iLive iTB174B Bluetooth HD Sound Bar for 22 - 55" Flat ...
www.amazon.com/iLive...Bluetooth-Sound-Bar/.../B0...
Amazon.com, Inc.
Rating: 3.7 - ‎6 reviews
iLive HD Bluetooth Wireless Soundbar Speaker TV Stand For 20-55" Flat Panel HDTV's Up ... when you purchase $5.00 or more of Qualifying Items offered by D.R. Worth and Sons. ... The iLive Bluetooth HD Sound Bar for 22 - 50 Inch Flat Panel TVs is cleverly designed to ... Click here to make a request to customer service.
Amazon.com, Inc.iLive iTB174B Bluetooth HD Sound Bar for 22 - 55" Flat Panel Televisions ...Bought another for a relative. ... **2 things to NOTE: 1-make sure there is nothing aside from your tv on top of the speaker to avoid rattling, which i mistook for distortion/blown speaker at .... It sounds much better than the Samsung internal speakers.
How to Connect Soundbar to TV ' Audiogurus Store
www.audiogurus.com > Learn: Home > Displays
Dec 29, 2015 | Samsung Televison & Video
I have an jbl soundbar and a sharp hd tv. After we connected the sound bar we no longer got a picture or sound.
The two brands should be compatible, and plugging the sound bar in should not affect the picture...either the tv chose that particular moment to go bad, or you plugged the soundbar into the wrong place...look for "audio out" connectors on the tv (should be RCA connectors)...
Jan 01, 2015 | Televison & Video
My Dell AX510 Soundbar Speaker isn't working, although the blue light is on, indicating it has power. I'm using a Dell monitor that is set up primarily for Playstation usage.
Ensure that the sound is actually supposed to be coming through the speakers. Just because the power is on doesn't mean that audio information is actually on it's way to the actual speakers. Maybe the television volume is low or muted, maybe the output volume is being routed somewhere else, or maybe the soundbar is broken. You should investigate and follow the signal to find the problem.
Sep 29, 2013 | Dell Ax510 Ax510pa Soundbar Sound Bar...
How can I use the AS500 DELL sound bar with my DELL E1910 monitor. there is no power to plug into?
///////http://www.stuartconnections.com/ebay/Peripherals/LCDs/Dell_E193FP/UsersGuide/English/SOUNDBAR.HTM/////// Hope this helps (Link is without //////)
Aug 10, 2010 | Dell AS500 Sound Bar Computer Speakers
I have a 4.5" black strip running down my 2001 fp monitor screen. What do I need to correct it.
Note: Soundbar Power Connector - 12V DC output is for optional Dell Soundbar only. .
DO NOT USE WITH ANY DEVICE OTHER THAN DELL SOUNDBAR.
  1. Working from the rear of the monitor, attach Soundbar by aligning the two slots with the two tabs along the bottom rear of the monitor.
  2. Slide the Soundbar to the left until it snaps into the place.
  3. Insert the black DC plug from the power cable at the back of the Soundbar into the DC Jack on the back of the Flat Panel Monitor.
  4. Insert the lime green mini stereo plug from the rear of the Soundbar into the Computer's audio output jack.
Jan 16, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Speakers connected to the flat panel won't work
Don't Connect them to the Monitor Directly.
It will Be easier for you to Connect them TO THE SOUND CARD (back of computer).
Apr 20, 2009 | Dell ADA745 Computer Speakers
Have a dell flat panel pc monitor, want sound. the only thing i see is speaker power?? whats this for?
the monitor has the ability to attach a sound bar (AX510) the power connection is for the add on speakers
Jan 28, 2009 | Dell E173FP 17" LCD Monitor
Dell ADA745 Computer Speakers Logo
1,939 people viewed this question
Top Dell Audio Players & Recorders Experts
dochubert
dochubert
Level 1 Expert
Rick Davis
Rick Davis
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
