Question about GE GSH25JFR Side by Side Refrigerator
Constant clicking that only shut off when you hold water dispenser down , water dispenser functions eratically
  • Bati99
    Bati99 Apr 20, 2009
    Kenmore Elite - Water and Ice click constantly, then dispense erratically.
Mine was doing the exact same thing, and finally quit cooling completely. The problem seems to be an AC to DC power converter on the motherboard burning out. It powers the ice and water control panel, the fans inside the fridge, and some other stuff. If it partially fails, where it can't maintain the voltage and/or current required, things will behave strangely intermittently. I went to the local appliance parts store, and showed them my motherboard. He didn't let me even get the words out of my mouth before he said he knew what it was and went to get me a new one. He didn't even have to look it up and knew exactly where in the store room it was. Apparently it is a very common problem with GE fridges. From what I understand, they redesigned it a bit and improved the reliability. I replaced mine this morning, and it is working normally again.
It is located behind a panel behind the freezer section near the bottom. You'll be able to hear the clicking sound loudly behind it. Unplug the fridge, remove the panel, and gently unplug all the wires. It will be pretty simple to put them back correctly, because they have different pin counts, and the plugs are keyed so you can't put them on backwards. You will see several (mine had 4) small white plastic sticks protruding through the board. They are not symmetrical so the board can't be put back in upside down. There will be a tab on the side of each stick that holds the board. Squeeze that tab gently with needle nose pliers and gently pull the board past the tab. When you have all the tabs released, the whole board will come out. Line the new one up with the plastic sticks and gently press each hole over them until the tab catches. Then plug all the wires back, replace the cover, and plug your working fridge back in.
It took me 15 minutes to do, and the board cost about $160 with tax. Not cheap, but cheaper than a new fridge or a service call. The new motherboard I got had more connections than the old one. I assume that is part of the redesign, and/or they have newer models of fridge with newer features that use those connections. Just ignore the extra connections, and match up the pin counts of the plugs you have, and it will work just fine.
Posted on Apr 27, 2009
Why does my in-sink-erator hot water dispenser is dripping from the bottom
Ck connections on top. Will run down and come out of bottom. If connections are water tight tank is bad , replace.
Apr 27, 2014 | Washing Machines
Water dispenser won't shut off
If this is just the water dispenser it sound like the door switch or dispenser switch has failed. Remove and test for proper function, if this is okay then move to the control valve there is usually one for the water and one for the ice although they may be packaged together in a single unit. Unscrew each line and see if water it constantly being sent to the door and icemaker... it should only do that when the switch is activated.
Mar 01, 2014 | Maytag MSD2732GR Side by Side Refrigerator
Water dispenser drips after use but doesn't shut off completely and drips constantly.
Most likely the water inlet regulator (water valve) is faulty (like a leaky faucet) need to replace the water valve.
Jan 30, 2014 | Samsung RF26XAERS
Insinkerator hot tap faq
Check all the connections, take the cover off after you shut down the power. If the connectors are not leaking, replace it
May 04, 2013 | In-Sink-Erator InSinkErator HC-WAVESN-SS...
AEG Santos S83168KD1 - The lock light of the water dispenser flashes after the water filter leaked inside the refrigerator. I have dried the refrigerator and replaced the filter but the light is still...
The indicator lamp can be switched off by holding the button for ordinary water (K) pressed in for about three seconds until the indicator lamp goes out. Click on the link below to download the AEG Santos S83168KD1 user manual
http://safemanuals.com/314159.php?k=5311c849edaf9949b74f80cd1a089035&ID=421951&q=AEG-ELECTROLUX S83168KD1
Jun 21, 2010 | AEG Refrigerators
I have a Maytag Plus side by side refrigerator, model # MSD2756GE*. It has the indoor ice/water dispenser. On the dispenser panel, there are a total of 6 buttons with LED indicators: Crush, Cube, Water,...
Normally you just need to hit the unlock button in for 10 seconds.
If this not works, here is what you need to do -
Note: If dispenser is active for more than five
minutes, an automatic lock out sensor will shut
down power to dispenser area.
Dispenser Lock/Unlock
The Dispenser Lock and Unlock affects all keypad functions.
To Lock Dispenser:
  • Press and hold the Lock/Unlock button for three
seconds. A green indicator light above the button will
illuminate when the dispenser is locked.
To Unlock Dispenser:
  • Hold the Lock/Unlock button for three seconds. The
green indicator light above will go out
Otherwise your refrigerator has a preset shut down program that protects the dispenser from flooding your kitchen. The control will shut down and will NOT reset when unplugged. The control needs to be reprogrammed. This mode was triggered by drawing out water for too long of a period of time. Call a Maytag service dealer.
Aug 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
Whirlpool Door Ice Dispenser Not Working
mine froze up in the shute, had to put water down iti
Aug 26, 2009 | Whirlpool GS6SHAXLS Side by Side...
Push the water dispenser, water starts but then stops abruptly
Yes , replace the water inlet valve . The piece the wall water line connects to .
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool side-by-side refrigerator - 2 problems
I would suggest that you get a certified person to come out and look at it you very well could have bent the doors in the move.
but... if you want to do it yourself.
click here for a walkthrough
for your drip:
Flush air from the water system the first time it is used and after replacing the filter. Air trapped in the water line or filter may slowly travel through the coiled water reservoir to the dispenser, pushing any water ahead of it. This can cause the dispenser to drip. Water needs to completely fill the lines for all air to be cleared.
  • Use a sturdy container to press and hold the water dispenser bar for 5 seconds, then release it for 5 seconds. Repeat until the water begins to flow. Once the water begins to flow, continue pressing and releasing the dispenser bar (5 seconds on, 5 seconds off) for an additional 2 minutes. Repeat if dripping starts again because air can re-enter from the water supply.
  • As air is cleared from the system, water may spurt from the water dispenser.
  • Make sure the refrigerator is connected to a cold water supply.
One or two drops of water immediately after dispensing is normal. It may be necessary to hold the container under the dispenser for 2 to 3 seconds after releasing the dispenser lever.
Jan 26, 2008 | Refrigerators
Ice and water dispenser not working but light on constantly
CM, there are 2 things that'd cause this. One is inexpensive, the other is not. First, check the cheap one... That rectangular rubber piece in back of your dispenser area is only a cover for a cantilever device. When you push in on this with a cup, the cantilever swivels back toward you and makes contact with a micro-switch. This switch sends power to the integrated circuit board which, in turn, performs the function you requested (cubed, crushed, water). OK... unplug your fridge. Then use your ears to diagnose this. Push the actuator pad several times in and out and listen for the tell-tale "click click" of the micro-switch. If you hear it clicking, it's good. Plug your fridge back in. Now for the expensive part. If your micro-switch clicks, your dispenser control board is fried and needs to be replaced. (I'm afraid that this is the case because the board controls the light as well as all the other functions.) UNPLUG YOUR FRIDGE BEFORE REPAIRING! To gain access the board, use a small flat blade screwdriver and remove the fascia panel starting at the bottom first. Just begin prying it gently off. Then remove the screws that are holding the board assy in place and gently pull it out. Take note of all of the wiring so you can re-install it correctly. The board number you need is #61005274. Unfortunately, it lists for about $100. A professional repairman would charge you over $200 for the repair, so you're actually saving money here! BTW, we recommend using a Belkin Surge protector for all appliances that utilize electronic controls. (you wouldn't plug you computer directly into a wall outlet, would you?) We regularly use these... http://www.acehardwareoutlet.com/(a1q3xi45sxgfbzm0qejhei55)/ProductDetails.aspx?SKU=3115672
Jul 31, 2007 | Maytag MSD2436GR Side by Side Refrigerator
GE GSH25JFR Side by Side Refrigerator Logo
124 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
