SOURCE: Need to remove panel in front of evaporator fan
there should be screws in the top and bottom of the freezer compartmant. after emovinghte screws it should tip out alolowin gyou access to the screwsfrom behind the panel
SOURCE: kenmore side by side refridgerator ice around freezer fan
I am looking up your refrigerator to see the right parts. Sounds like the defrost cycle is not happening. look for a defrost or adaptive defrost board. Check your model number again because I am not able to find the number listed. I will continue to check for the correct refrigerator and if you find a simple defost timer turn it clockwise slowly until you feel and hear a click. If you do and you may hear the elements heat up inside the freezer. If that happens just put a new defrost timer and you should be set. Sea Breeze
