Question about Onkyo DV-CP704 DVD Player
Our screen is flickering like an old 8mm film
Had the same problem tried to plug the reciever into a different power outlet and problem solved!
Posted on Nov 10, 2012
Check the video-out cable. If loose, it can be "intermittent," thus cause image flicker.
Posted on Apr 20, 2009
2 Suggested Answers
  • 259 Answers
SOURCE: RCA drc286 screen flicker
it sounds like the vertical hold on your tv set needs adjusting also with your tv and dvd are there a set of three plugs usually red,white and yellow in colour ?? if so connect these with a cable as this by passes the tv tuner hope this helps regards JIm
Posted on Mar 12, 2009
How many feet in 8mm
no feet in 8mm
roughly 8mm is 1/3 of an inch or 3/8 "
Oct 23, 2017 | Video Cameras
I have a minolta autodual 8 film projector but the front reel is turning backwards in the wrong direction. How do I change the direction to turn in the same direction as the back reel.
I assume you haven't put a reel of film onto the projector and looped it through to the back spool. The front spool usually 'freewheels' whilst the film is pulled through the projector and taken up by the motor driven rear spool.
It is possible that the friction drive and/or drive belt have deteriorated with age, as the mentioned projector is a rather elderly 'classic' of the dual 8mm series.
If in doubt, don't risk your family pictures. Try the unit with an old piece of film on small spools.
Dec 26, 2014 | Eumig Imperial P8 Movie Projector For 8mm...
Have split image when watching 8mm film video.
If my memory serves me correctly, you should have an adjustment knob somewhere... and it seems like it was marked "frame". Another caution: I assume you know that 8mm and Super 8mm are not interchangeable. However, some of the old projectors (like a Kodak I had) had a twist knob that would change the projector back and forth in order to play either film. Just some thoughts...
Dec 06, 2013 | Computers & Internet
THREADING FILM IN A ELMO FP-C PROJECTOR
Is your film super 8mm? If yes, then the red sprocket above the lens should be pushed in, and the bottom black sprocket will stick out. If you have regular 8mm, then the black bottom sprocket should be pushed in. If the sprockets are not in the correct position, push the green lever forward (towards the screen) then open the two orange tabs, then push in the correct sprocket. Once you have the correct sprockets aligned, close the orange tabs. How to tell if you have 8mm or super 8mm film: Look carefully at the film image. If the sprocket hole is next to the middle of the image, it's super 8mm. If the sprocket hole is between images, it's 8mm.
Jan 10, 2013 | Sewing Machines
HAVING TROUBLE THREADING FILM - ELMO FP-C
Is your film super 8mm? If yes, then the red sprocket above the lens should be pushed in, and the bottom black sprocket will stick out. If you have regular 8mm, then the black bottom sprocket should be pushed in. If the sprockets are not in the correct position, push the green lever forward (towards the screen) then open the two orange tabs, then push in the correct sprocket. Once you have the correct sprockets aligned, close the orange tabs. How to tell if you have 8mm or super 8mm film: Look carefully at the film image. If the sprocket hole is next to the middle of the image, it's super 8mm. If the sprocket hole is between images, it's 8mm. If your green lever is stuck in the forward position, that's because the film is not threaded. Once your film threads correctly, the green lever will spring back.
Where do I go for service?
If the videos that show poorly were stored near a source of magnetism that may cause problems. If some work perfectly it is probably not the recorder. Try a test with anew cassette-record and playback, Unsure how to get faulty ones repaired if possible.
Jul 17, 2012 | Sharp Video Cameras
Developing a film without opening the camera
Am i right in thinking the keystone is a old 8mm movie camera? Never had any experience with movie cameras, or developing their film- I'm goin to assume its like 35mm developing, apologies if this is completly useless advice.
I'm fairly certain you will not be able to develop film in camera (camera will end up pretty wet). If the problem you have is actually getting film out o the camera I'd suggest a changing bag- basically a light tight bag that you put the camera in with your developing tin (if your home developing) or canister if your using a lab, you then have to put your hands inside 2 holes either side and transfer your film from camera to developing container- blind.
I'd advise doing a couple practice runs first with some old unused film just to get the hang of it- it can be tricky.
Again I have no experience with 8mm film processing but I'd imagine the principles are similiar.
You can get hold of changing bags from most photographic retailers, and always follow instructions that came with your film.
Nov 05, 2009 | Cameras
Mar 12, 2009 | RCA DRC-285 DVD Player
Onkyo DV-CP704 DVD Player Logo
161 people viewed this question
Top Onkyo Televison & Video Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
