Question about InFocus SP-LAMP-017 Projector Lamp for LP540, LP640, C16
TROUBLE IN LP540
NO POWER IS COMING IN PROJECTOR SIDE .EVEN NO POWER LED WILL GLOW IN POSITION OF POWER BOTTON.
  • Anonymous Nov 09, 2007
    Same problem. No power. No LED light. Searched Google to see if there is a fuse for this projector. Can't find any reference to a fuse.
  • 3 Answers
Check for internal fuse on power module, you will have to open the case.
Make sure power cord is removed. Be carefull capacitors tend to hold a charge long after power is removed. I have a LP640 ....big brother to this one. If you open the case the warranty is voided so think about it first. the fuse could be on the circuit board and will look like a small solid green resistor or it could be a full sized fuse in-line with the wires coming from the power cord connector. I have seen the inside of a LP390 with the fuse behind the power inlet connector. Good Luck
Posted on Nov 23, 2007
Projector cp-sx635 lamp indicator glows red (RED). intimate trouble shoot pl
sounds like the bulb will not fire up. most likely cause is the bulb needs replacing
Jan 03, 2013 | Hitachi CPSX635 4000 Lumens LCD Projector...
I have replaced new lamp to InFocus LP540 projector, but it still indicating in the LED display "please replace lamp".. and LED is blinking two times as red.. Lamp door is closed properly and the safety...
To reset the lamp timer , press the increase volume button on the remote and the increase volume button within 3 seconds
The maintenance manual is on the infocus web site
Aug 19, 2010 | InFocus SP-LAMP-017 Projector Lamp for...
Infocus sp5000 red led blinks once indicating lamp
be sure and reset the lamp hours. Flash the software if you can. These are also notorious for the ballast cable on the inside of the lamp housing backing out when a lamp is removed or replaced. If you have the cover off push the cables back into place and hold them there as you install the lamp. Also look directely at your lamp in the center and move it side to side and up and down. If there are any cracks or frosty looking spots or bubbles in the mirror of the lamp that are visible, then the lamp is probably shot. If all this fails, most likely it is the power supply, or the lamp door has gotten mishapen from heat and the actuator on the lamp door isn't making full contact with the safety swith.
Jan 29, 2010 | InFocus SP-LAMP-017 Projector Lamp for...
Won't power up
if there are no led lit, replace the power supply.
Nov 06, 2009 | InFocus SP-LAMP-017 Projector Lamp for...
No power or led lites
the power supply is bad. replace it.
Oct 02, 2009 | InFocus SP-LAMP-017 Projector Lamp for...
InFocus LP540 Power Supply Problem
most of infocus parts are oem and made by a company in taiwan that no longer makes power supplies, and many of the parts have their stock numbers and not neccesarily a common stock. the power supply, however, is in stock at infocus for about $65.
Jun 23, 2009 | InFocus SP-LAMP-017 Projector Lamp for...
Infocus LP540
I haven't serviced an infocus projector before, But I have seen 3 or 4 Red cutting out display simptoms on projectors caused by bent or pushed in gold pins on the VGA leads. (it always seems to be red!) I won't comment on insides but do check this basic tip before delving in too deep. Good Luck
Sep 24, 2008 | InFocus SP-LAMP-017 Projector Lamp for...
Infocus LP540 --- display
It sounds like you may be feeding it with an HDMI source using an HDMI to M1-D adapter...
If this is the case, make sure the source in not set to a resolution higher than 720p.
However I really need more information to offer a definitive solution.
Take Care!
Sep 17, 2008 | InFocus SP-LAMP-017 Projector Lamp for...
LP540 INFOCUS
good luck. not even the infocus authorized service centers get those. besides, they were made by another company that does not make power supplies antmore. and infocus doesn't have any new ones in stock. if you're getting no power at all, replace the mosfets. it works half of the time.
Sep 20, 2007 | InFocus SP-LAMP-017 Projector Lamp for...
InFocus SP-LAMP-017 Projector Lamp for LP540, LP640, C16 Logo
496 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Jaime Hernandez
lekmai
lekmai
Level 1 Expert
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
