Question about MTX Thunder 404 Car Audio Amplifier
Tuning the amp
I knocked my amp out of adjustmant and was wondering if you knew how to bring it back to where i need it
  • 752 Answers
St the crossover to LP (low-pass), and around 80Hz for 12" subs or 120Hz for 10" subs. Turn the gain all the way DOWN. Turn the radio about 3/4 or 4/5 the way up. Adjust gain until subs start to sound a wee bit sloppy and then adjust back 1/8 of a turn. Also, DON'T turn the LOUD function on or the BASS all the way up on the radio.... these should really be flat as possible.
Posted on Sep 22, 2007
Changed out the knock sensor and engine light is still on
Some engine lights don't turn off until the car is driven for awhile. Give it some time. If it doesn't go away, take it to Auto zone to clear the engine code. If it comes back, then it might be a wire problem and not the knock sensor itself. Good luck!
Feb 24, 2016 | 1994 Pontiac Bonneville
2004 3.0L Escape. Where are the knock sensors located?
Knock Sensor
Print
Operation
The Knock Sensor (KS) is a tuned accelerometer on the engine which converts engine vibration to an electrical signal. The PCM uses this signal to determine the presence of engine knock and to retard spark timing.
Removal & Installation
  1. Raise and safely support the vehicle.
  2. Remove the intake manifold.
  3. Remove the bolt and the Knock Sensor (KS).
  4. To install, reverse the removal procedure and tighten mounting bolt to 15ft. lbs. (20 Nm).
Jul 21, 2015 | Ford Cars & Trucks
Stalls in gear no getup when pushing the gas replaced 2 knock sensors iac map oxygen 2 coolent sensors ecm spark plugs wires and whole distributer fuel filter valcum hoses now i dont know how to set timing...
Even you knew, before you started changing any parts,
that you didn't need to replace 10 things.
You just admitted to not knowing how to set timing or find
a problem,I knew that when I got the the second part you
installed
You need to study vehicle systems etc & go to a repair
shop for now,that you also knew before you started throwing
parts & money at it.
You realize you provided no vehicle at all,year,make,model
Jul 31, 2011 | Chevrolet S 10 Cars & Trucks
My Scotsman undercounter icemaker is not producing much ice and the little it does produce is watery. How do I fix? The model # is DCE33PA-1WB. Is this model discontinued?
Wow! That the first time I saw one of these! Never even knew they made it under
counter types.Anyway I'll give it a shot,Let's see here It's not producing ice as it should huh? I Googled it for complaints and found this for you,Linda go to
(http://www.retrevo.com) and once you get there type in (Scotsman DCE33)
into site search engine and it'll list service manuals for your model to seek a fix.
It stated how to make maintenence adjustmments ok now good day!
Jan 02, 2011 | Scotsman 15" Luxury Consumer Ice Machine
Hvac blower motor not working after bringing car in for service, was working fine before mechanic did tune up, replaced starter and coil on 1993 gran am withQ4 engine
What is your question? It sounds like you have an old car that will need some repairs. What he did has nothing to do with the blower motor. Turn the switch on, and tap the motor. If it works, you need a new motor. If not, check fuses, switch and blower resistor.
Jul 29, 2009 | 1993 Pontiac Grand Am
Excessive knocking at at speeds
Please check your oil.
It may be time for a tune up, because your timing
may be off, and that would make it run rough at all
speeds.Look at your spark plugs and make sure
they are not fouled. If they are wet with oil you can get "non foulers" basically a spark plug extention
sleeve. It brings the plug back out a few inches
from the cylnder and the oil can't reach it.
Apr 25, 2009 | Ford Taurus Cars & Trucks
MTX Thunder 404 Car Audio Amplifier Logo
247 people viewed this question
Top MTX Car Audio & Video Experts
Mike Duncan
Mike Duncan
Philip Armitage
Marvin
Marvin
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
