Question about GE Nautilus 24" Built-in Dishwasher
Standing water in the bottom of the dishwasher
After my GE Nautilus dishwasher finishes its full cycle the is standing water on the bottom of the tub. The dishes are all covered with a cloudy film. This started today. I looked for a filter and found none.
  • 2 more comments
  • pennysmith Apr 22, 2009
    My water isnt draining at all. It has not been used in the last year. Check for plugged lines?
  • Anonymous May 02, 2009
    I have the same problem.  Standing water after the cycle finished.
  • Anonymous May 14, 2009
    i removed trap cover and fished around but found no debris to remove
  • tmhighs May 21, 2009
    Just last night found about 3 inches of water in the bottom. Drained the water, took off the trap cover and the grate. All the connections are fine - no kinks in drain pipe, etc. Water just won't drain, it's almost as if the pump is bad. Is that possible?? (dishwasher is around 6 years old and only runs about 15 loads/year. I see several people with this problem - is everyone's dishwasher about 6-years-old too?)
I had the same problem - a 10 minute fix. The issue tends to be that the trap gets clogged by debris (like broken glass etc.) and restricts the amount of water that can be evacuated by the tub.
1. Undo the trap cover (two hex headed screws)
2. Remove the trap cover
3. Remove the inner trap grate
4. BE CAREFUL NOW ! Gently remove debris - this can have broken glass in it !!! - You can use a wet vac if you have one. Ensure all debrs is removed and the trap is clear.
5. Clean trap cover and grate
6. Re-install cover and grate
7. Bingo !
Posted on May 10, 2009
  • Billy Dietz
    Billy Dietz Apr 01, 2014
    Has a whole in bottom of food trap. How do I replace with a new one
  • Billy Dietz
    hole
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 7 Answers
The filter might be under the lower spray arm just above the motor, what is the model number?
Posted on Apr 20, 2009
Dirty water standing in the bottom of the tub
There is probably some debris that is blocking the water from getting to the pump.For More information please visit Kenmore Parts.
Oct 04, 2012 | GE Nautilus 24" Built-in Dishwasher
My GE Nautilus portable dishwasher will take water in, the motor will hum for a few minutes and then drain out into the sink. This process repeats but the water never cycles inside to actually wash the...
Try manually adding water to the dishwasher. If it works then the water valve is just clogged. Sometimes it gets full of gunk and the machine will take in water but not enough to run properly. It is in the upside down cup shaped thing on the bottom left front. The other possibility is the Cam/Timer. It is in the door right behind the dial. This is the part that triggers all the different actions.
If when you add water it doesn't work then the valve or the solenoid on the pump assembly is likely done.
Feb 24, 2011 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus- model GSD3400G00WW. Why is there standing water after the dishwasher has completed it's cycle?
i won,t too buy a g.e. dish washer model.gsd3400g00ww where can i find this model and how much it cost.
Nov 10, 2010 | GE Nautilus 24" Built-in Dishwasher
The water will not drain from the tub. it will go
if it drained before...then you might have problem with drain pump something stuck..piston nut
try slowly advancing timer...if it drains in different cycle you timer is gone bad
if not then piston nut or drain pump
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Standing water in tub after all cycles are finished
some water should remain in tub so that pump does not lose prime
Oct 10, 2009 | GE 24 in. Profile PDW7800 Built-in...
Water didn't drain, left in bottom of washer tub
I had similar problem and it ended up being a clog at the point where the drain hose meets the garbage disposal. I had to unhook the hose and clean out the food that had accumulated (horrible smell). You may have to stick a screwdriver into the garbage disposal hole where the hose fits and clean the food out there also. Then put the hose into a bucket and run a few cycles to ensure the hose is free.
Aug 01, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher drains but leaves behind about 1/2" of standing water
Water standing in the bottom of the tub is normal.
A small amount of clean water around the outlet on the tub bottom at the back of the tub keeps the water seal lubricated.
Jun 22, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus Dishwasher - NO water coming in at beginning
Normally,if water doesn't come in, cycle should not go on ! Add water by hand to tub and operate the dishwasher. Let us know with your results and we will see how could we assist you.
Aug 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwasher fills and drains at the same time
your water is syphoning out make sure your drin hose is up
Nov 14, 2006 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus 24" Built-in Dishwasher Logo
1,402 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
