Question about Refrigerators
I have a Maytag mbf2256heb has stopped cooling and is making a noise in what looks like the R-134 reservoir.
    Problem Solver:
  • 8 Answers
Try cleaning the condenser colis underneath the reefr. They may look like a black metal box that go around to the center like a cinnamon-roll by a fan, or they may be flat and fill the space under the unit completely. Clean with long wire-handle bristle brush, or compressed air. This makes a lot of dust! Be sure and replace the black cardboard cover in back or you won't get good air circulation. R-134 is a junk refrigerant, btw..r-12 was the best. I will always miss paying 30 buckis for 30 pounds. Boo-hoo-hoo! Chrisa ina bigbEar
Posted on Apr 20, 2009
Water builds up in freezer
Yes there is. The drain is either blocked by debris, or there is a heater in the drain that has failed.
Oct 01, 2014 | Maytag Refrigerators
Humidifier will produce mist for a min then stop If you look you can see it producing mist within but it will not come out of the top Walgreens cool mist ultrasonic humidifier
I have had times where my Crane humidifier won't produce mist if I haven't turned it on for several days (4+) or more. The water that sits in the reservoir may develop a film on the ultrasonic element which inhibits the creation of the mist to come out the top of your humidifier. I would lift off the tank and empty the reservoir. Then VERY GENTLY with a piece of paper towel, wipe the ultrasonic element (looks like a disk the size of a quarter at the bottom of the reservoir) to clean off any film. Then replace the tank and let the reservoir fill up the tank and try it again.
If your humidifier runs properly for a minute and then makes a whirring noise and goes silent (like the motor stopping), then it's a motor problem. The humidifier motor may have gone out of alignment due to bumping or rough handling of the humidifier when cleaning or emptying it. If that is the case, you will have to empty the humidifier reservoir, unscrew the base, and find the screws holding down the motor and check for misalignment. Loosen them a little and put it back together and try again.
Best of luck
thebqe
Feb 13, 2014 | Humidifiers
Mbf2256heb maytag fridge My fridge seems to cool properly, but it is making this nearly constant buzzing or grunting sound that stops when you open the freezer (bottom) drawer. Suggestions?
Is you unit hooked up to water because if your unit has an ice maker and not hooked up to water currently, the ice maker will call for water about every 45 mins and cause this noise. To stop this action, lift the bail arm to the off position to avoid or stop this from occurring.
I hope this helps.
Oct 24, 2013 | Refrigerators
How do i get to the ac fan motor 2000 jimmy
  1. Disconnect the VCM or the PCM.
  2. Remove the coolant reservoir.
  3. Remove the rear coolant recovery reservoir mounting stud.
  4. Disconnect the cooling tube from the blower motor.
  1. Disconnect the electrical connector
  2. Remove the 5 blower motor and tan assembly mounting bolts
  3. Remove the blower motor and fan assembly
    Reverse procedure to install. Don't forget that cooling tube. It looks useless but is very important to reinstall.
Aug 15, 2012 | 2000 GMC Jimmy
My 1996 Buick Century A/C will not cool. we have added R-134 and the compressor runs but not cooling. How much R-134 should we have to add for this A/C Thanks for any help
You can't tell how much to add because you can't tell how much it had, unless you have a gauge or look at the sight glass on the receiver/dryer. When the bubbles stop, then it is time to stop adding freon. But normally about 2 cans will fill an empty system.
The first thing to check is if the fuse is good, the belt tight, the compressor clutch coming one, and the fan working.
Aug 11, 2010 | 1996 Buick Century
Water dispenser in my Maytag french door refer has suddenly stopped working. We use it every day and the filter seems to be fine. It almost sounds like it is frozen. Please Help!!!
We have a hd2560 (bot 10/04), french door with inside water dispenser and it had stopped working a year ago, but started working a few months later. I couldn't figure out what happened, but suspected the water line was frozen. I later found out that the water reservoir is located behind the fruit and vegetable bins, so look there to see if the water is frozen.
Two weeks ago, our frig/compressor stopped cooling after making humming/clicking sounds for weeks. Fortunately, Maytag has a 5 yr parts & labor warranty on the compressor, so we were covered. Evidently, there are quite a few faulty compressors out there.
I believe that the compressor had been over-cooling in the past and caused the water lines/tank to freeze. This would also cause frozen produce/fruit. I would immediately contact Maytag/Whirlpool if you suspect a faulty compressor as well.
Oct 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Maytag Dryer not heating up
you need to be getting at least 220v to the terminal block, if you don't check recepticle and the breaker
Jun 01, 2008 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag refrigerator clicking noise and stopped working
How long a period of time have you noticed this noise? If it just started and the refrigerator just stopped it could have entered its defrost cycle. When the defrost heaters come on you may hear the heat causing some expansion. After a few minutes(18-22) the defrost cycle ends and the refrigerator will restart.
May 30, 2008 | Jenn-Air JCD2389G Side by Side...
Maytag fridge made some clicking noises and then stopped cooling
For what it is worth. I had this problem twice and both times the compressor ad to be replaced. Ton this day it sounds like a pin pong game whenever it runs. No it is not the fans or the ice maker.
Nov 29, 2007 | Maytag MSD2454G Side by Side Refrigerator
Refrigerators Logo
175 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
