Question about JVC UX-C30 Shelf System
How do you preset radio stations on JVC UX-C30?
  • 9 more comments
  • cfarb54 Apr 29, 2009
    This unit does not have a "Set" button. It has a small round preset tuning button, but pressing it either before or after choosing a station does nothing.
  • cfarb54 Apr 30, 2009
    Does anyone actually own one of these?
    The unit does not have a recall button and pressing power and the band button at the same time accomplishes nothing.
  • cfarb54 May 01, 2009
    I think you are mistaking this unit for a car stereo, it does not have 6 buttons. It is a shelf system.
    Sorry that did not work.
  • cfarb54 May 02, 2009
    This is a valid JVC part number. It is sometimes followed by a bk for black or wh for white, but it is the correct part number.
  • cfarb54 May 03, 2009
    I followed those instructions to the letter and it accomplished nothing,
    I do not mean to be rude, but I have already stated in an earlier post that this is a shelf system not a car stereo, duh.
  • cfarb54 May 04, 2009
    There is a small round preset button on it.
  • cfarb54 May 10, 2009
    This did not work and I do not mean to be rude, but do you really think that I would spend and time and money on this website without trying the most simplistic, obvious in your face solution?
  • cfarb54 May 11, 2009
    This is a shelf system not a car stereo
I found the user manual but they want $4.95
http://www.s100-manuals.com/manualdetails.asp?id=306283
Posted on Apr 30, 2009
  • Anonymous Apr 30, 2009
    It is possible to change the MW tuning interval. You can do this by pressing the POWER button while pressing the BAND button during power is on. To reset the interval, repeat this procedure.
    NOTE
    - When the MW tuning interval is changed, all preset stations are cleared. The preset stations have to be set.
    Most stereos are the same...find the radio station you want to keep and then hold the button down (most stereos have six buttons that are numbered 1-6) hold it down untill you here it beep or see the display flash and then it will stop flashing...repeat this step and fill up all six preset buttons
The simplest solution seems to be to:
Prerequisite: unit remote control
1) turn unit on
2) turn unit to tuner
3) make sure it can receive some signal
4) press auto preset on remote control
This appears to scan a band and when it tunes into a station it presets it to a number.
This works (but obviously might upset people - like me - who would like Radio 1 set to 1, 2 to 2 etc) but hey ho it worked
Posted on Sep 29, 2010
  • 11,896 Answers
I have looked for a user manual for this device. Unable to locate free one. Have seen many for purchase. Howeever, was told by JVC.com that you can email them and they will send you one.
Posted on May 11, 2009
    Scholar:
  • 123 Answers
To change the channel spacing from 0.2 to 0.1; hold the FM button for approximately 2 seconds, then while still holding the FM button, press and hold the #5 button. The screen will flash with either US for 0.2 spacing or 01. for EU (Europe) spacing. Press any other button to exit.
  • 741 Answers
Find the station, click the preset, hold down for 5 seconds, release. If none of this works including the instuctions you were given then there is a communication breakdown and you can get a manual off of the internet or from the manufacturer..
Posted on May 07, 2009
    President:
  • 2,923 Answers
To preset the JVC UX-C30, please follow the steps below:
1. Make sure that the JVC is turned on.
2. Hold down the small preset button for 10 seconds.
3. While still holding down the preset button, unplug the power cable from the wall outlet, but do not release the preset button.
4. After another 10 seconds, plug the power cable to the wall outlet and give another 10 seconds before releasing the preset button.
NOTE: Do not release the preset button while you are performing the preset.
Have a great day!
Posted on May 02, 2009
  • 10,594 Answers
UX-C30 seems incomplete or incorrect model number as it is no where in JVC sites.
I found TH-C30 and UX-G30 as valid model numbers. Please reconfirm model number of your JVC unit to look into its manual for how too set preset of radio solution.
Hit "add a comment" button to reply.
Thanks.
Posted on May 01, 2009
  • Shahid Electronics
    Shahid Electronics May 02, 2009
    I checked all over JVC support sites to get its instruction manual and every time it says invalid model.
    Radio preset setting procedure would be simple but I need instruction manual to guide you properly.
    Click JVC Support UK and check any instruction manual related to UX-C30
    Thanks.
  • 3,037 Answers
This must be an older system since I can't find a manual. Have you tried holding down the buttons that the stations get set on when you are on the station you want. That generally works if there is no set button. Let me know if it doesn't, I'll see what I can dig up otherwise.
Benjamin
  • 15,935 Answers
The manual says "You can also overwrite preset station numbers by pressing RECALL to select the number and then press the desired number to confirm selection."
For a total reset....
It is possible to change the MW tuning interval. You can do this by pressing the POWER button while pressing the BAND button during power-up. To reset the interval, repeat this procedure.
NOTE
Thanks for using FixYa
  • JVC Master
  • 19,396 Answers
Follow the instructions below:
Don't forget to leafe feedback.
thanks.
Posted on Apr 28, 2009
    Top Expert:
  • JVC Master
  • 80,339 Answers
The easiest way is to disconnect the Keep Alive Power, this will erase all setting and return the system to out of box settings, the keep alive is most likely the cigar lighter fuse, u can also just disconnect the battery fro 5 minutes.
Posted on May 03, 2009
  • yadayada
    yadayada May 04, 2009
    sorry.
  • yadayada
    How do u know this radio has the ability to have preset stations?? I can't find any info that it does.
  • 393 Answers
I did some research for you and there is manuals online that could help you but at a cost
i would suggest contacting jvc they may be able to help you better
Main support number(800) 252-5722
Email supportproinfo@jvc.com
Posted on Apr 29, 2009
How to tune in radio stations on a mini system without the remote
Hi, with just the controls on the unit itself you cannot set the radio station presets. They are set by holding down one of the numbered keys on the remote while in radio mode. The letter P with a flashing number will show up on the display to indicate you are setting that preset, radio will stop flashing and station will be locked into memory.
Aug 21, 2013 | JVC FS-2000 Shelf System
LED display is now blank
Had the same problume I traced it to capactor C25 100uf 16v I also replaced C32 102nf
Dec 13, 2012 | JVC Ux-lp5 Audio Shelf System
How do i set the radio stations on my jvc kd-s26 radio
1. Tune to the station you want to set the preset to.
2. Short-press the "menu" button.
3. Using dial, select the preset you want to set it to.
4. Long-press the dial to store the preset.
Jul 16, 2012 | JVC KD-S26
How do i set my preset fm stations
Should have numbers 1-6 on your radio faceplate.....go to the station you want and push and hold button 1.....it should blink, then stay lit again...that preset should be programmed......go to another station then hit number one.....is your station programmed????? If it is go and do that to 2-6 and you should be gd 2 go...let me know if that helps........
Mar 25, 2012 | JVC Car Audio & Video
UX-C30C
If competely dead, open fuse or the power transformer has a built in thermal fuse that opens, replacement only way.
Mar 17, 2012 | JVC UX-C30 Shelf System
How do I preset radio stations on my JVC KD-S27?
ussually all radios you choose your station than take the button that you select and hold the button for a few seconds and that should be it !!!
Aug 31, 2011 | JVC Car Audio & Video
Lost handbook
Click HERE to download user manual of JVC UX-N1
Thanks.
Sep 10, 2009 | JVC UX-N1 Shelf System
How do I preset individual radio station frequencies?
To set individual presets: 1. tune to the station you want as a preset 2. hold down the number (ie "1") on the remote until the number blinks on the system 3. repeat for all other stations
press the number on the remote to tune to your preset
this is very similar to setting the presets on my car radio
May 04, 2009 | JVC FS-D88 Shelf System
Jvc rv-dp100 boom box
tune into the station you want as normal. Then on the remote, press & hold the number key for the preset number you want. This will flash in the display to show you it's set. You can preset 30 FM & 15 AM stations.
Sep 17, 2008 | JVC RV-DP100 Cassette/CD Boombox
Jvc car cd/radio
The radio was improperly installed; there are two 12V leads, one services the radio when on, the other, only the circuitry for the clock and presets.
Eventually, this shouldn't be needed if the manufacturers ever think about using a little bit of flash memory for the presets and a coin cell for the clock.
You didn't give any model number so researching the manual is impossible.
If you can find the model number, look for a user's (or installation) guide on line to find the wiring info.
Aug 25, 2008 | JVC AM FM CD DET FACE CAR STEREO
715 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
