Question about RCA Car Audio & Video
How do i hook up my PAC sni-35 to my 05 monte carlo you know i need step for step instructions i am not that talented i followed the instructions on the box but i couln't figure it out i did it and the nothin so please help someone!!!
SOURCE: monte carlo 2001 ss 3.8 V6
is the battery good if it is shorted out it will do this or if the charging system is not working
Posted on Nov 23, 2008
SOURCE: wiring diagram
Do you have any connectors left intact? All you should need is the alternator power, grd, starter, distributor power, advance
Posted on Dec 22, 2008
Healeyman
  • 1198 Answers
SOURCE: i need a diagram for my 1980 chevy monte carlo
'80 Monte Carlo, a good ride. A Chilton's book is a good investment. It will show you wiring and vacuum hoses and how to do the brakes, etc.
Posted on May 03, 2009
  • 61 Answers
SOURCE: i need step by step on how to connect a stereo to my 2001 f-150
radio wires red= key live yellow=battery live. black= grd. The rest are speakers. totalling 8 (others are illumination normally orange. blue and white is aerial antenna. not required) Car colours all vary. Advise getting tester. to test for lives. Check key live by turning on and off key while testing lives. ground is normally always black. Lives are normally alot thicker than rest of wires as is ground. once lives connected you can test speakers by balancing left and right fade rear and front to connect these. As for + - on a loom these are normally hard to distinguish as a speaker can run in reverse. in just sounds alot better when ran properly. But each pair are normally the same colour although one will have a different colour line running down it. Chek out this site for car wiring colours. http://www.caraudiohelp.com/car_alarm_install_guides/car_alarm_install_guides.htm
Posted on May 15, 2009
  • 78 Answers
SOURCE: 2002 monte carlo radio code needed
basicaly if you dont got the code card you have to remove the stereo and behind the stereo is a serial number that the dealer will give you the code number but the deal is tha they charge ten to twenty dllrs kind of bites but you will have a working stereo
Posted on Jun 03, 2009
How do you replace a 3.8l engine on a 2003 motecarlo
Your kidding,right? Get a shop manual and follow step by step instructions. Are you planning to use a crate engine or rebuild yours? Beware salvage yard engines, as this is a big job and you don't want to do it twice.
Oct 17, 2014 | 2003 Chevrolet Monte Carlo
2004 Tahoe Line Output converter
You can get the signal wired behind the radio or if it is more convenient you can tap into the rear speaker wires in the colums in the rear of the vehicle which will make your rca's from it be shorter to the amps in the rear.
Jan 16, 2013 | PAC Audio Pac Sni-35 Line Output Converter...
I need to do an engine swap on a 1997 monte carlo
You can get a shop manual used, or subscribe to something like alldata for a fee. I doubt a DIY book will cover what you need.
Sep 23, 2012 | 1997 Chevrolet Monte Carlo
How to replace a thermostat on a1998 Chevrolet Monte Carlo 3.1 v6
you may be able to take off the water housing by taking the front bolt out and loosening the rear, but its TOUGH to get too. A repair shop can do it for you. I replace them if I have the intake manifold off for any reason. check if intake gaskets are leaking,(common), then you need them replaced and the thermostat is easy to replace at that time.
Aug 04, 2011 | 1998 Chevrolet Monte Carlo
Trouble shifting gears on 1997 Monte Carlo, what's a normal procedure
your going to need a diagnostic scanner that can read all the data in the ECM. Understanding what the data means will be the next step. Hopefully you have a code in memory to help diagnose this. If not then someone is going to have to drive the car with the scanner hooked up looking for any skewed data. Even if you have a code in memory you will need the manufacturer diagnostic procedures. If no code is in memory then your going to have to follow the symptoms flow chart to possibly find the problem.
Jul 27, 2010 | 1997 Chevrolet Monte Carlo
Installing a kenwood kdc-135 in a 2001 monte carlo ls
Hello, my name is Israel and I will help you. The following should be able to help you out. Please rate and good luck.
constant 12+ orange
switched 12+ yellow
ground black/white
illumination gray/black
dimmer brown white
Left Front + tan
Left Front -
Apr 13, 2010 | Kenwood KDC-135 CD Player
Rack and pinion
Go to an auto parts store and gat a haynes auto repair manual for that car, it gives step by step instructions. About $17.00.
Mar 12, 2009 | 1996 Chevrolet Monte Carlo
1999 Chevy Monte Carlo Passanger side mirror replacement
try "autozone.com" or your local library for diagram and step by step instructions
Mar 08, 2009 | 1999 Chevrolet Monte Carlo
Power stering pump
Is this the 3.4L DOHC engine or the 3100/3400 engine?
Oct 17, 2008 | 1997 Chevrolet Monte Carlo
Car Audio & Video Logo
418 people viewed this question
Top RCA Car Audio & Video Experts
Colin Stickland
Colin Stickland
Jeff Turcotte
Jeff Turcotte
L Pfaff
L Pfaff
Are you a RCA Car Audio and Video Expert? Answer questions, earn points and help others
