Question about Marantz SR-18EX Receiver
Marantz SR-18EX; Front left channel crackles
My 6 year-old receiver is making crackling/static/buzzy noises from the front left channel. I've double-checked all the connections. It does it regardless of the source; TV, radio, CD, DVD. I've switch speaker wires, so I know it's not the speaker (wish it was).
I'm wondering if this is common to this receiver, and if there's a repair that is the usual culprit, rather than spending tons of time and money tracking down the problem.
Also, are there any recommended service shops?
Thank you!
Peter in Milwaukee
  • 1 more comment
  • peter4jc Apr 20, 2009
    Thanks Guru dristi,
    I used banana plugs when I first wired things up 6 years ago, and it actually started acting up intermittently about a year ago. A couple months back, I asked a neighbor for advice. He's been into electronics all his life, and installs high-end systems mainly for church sanctuaries. So when he came over and listened to it, he suggested removing the banana plugs in favor of a direct connection. That seemed to get rid of the problem. I'm ashamed to admit that I didn't know there were different sized banana plugs, and a couple of them were small and sloppy in the terminal. So I was happy as can be that I was out of the woods. But now it's the same thing all over again.
    My connections all look good. I took off and put back on a few that looked iffy, but the problem persists. I use a piano sonata CD as my test, since it's easiest to pick out the fuzziness in my tweeter and midrange with a solo piano.
    I'm curious enough and brave enough to pull the case off the unit, just to look around. But I don't actually know what I'm looking for. Would a failed solder connection be visible or obvious? My neighbor mentioned that at a certain age, electronics have solder that is easy to do, but he doesn't have the equipment to do the newer type. He mentioned that there could be a ton of capacitors and no way to check each one without replacing them, which would be time-consuming and expensive.
    But I'm open to any and all assistance you can offer. And I'm extremely grateful for your time and wisdom.
    Peter
  • Anonymous Apr 30, 2009
    I have the same problem, the front left channel crackles on speaker and headphones
  • peter4jc May 28, 2009
    matg858,
    Thanks for the detailed post!
    Would your recommendations still hold true if my problem is sporadic? It hasn't acted up now for a couple weeks, even if it's on for hours. Other times it'll act up more quickly. It is always only the FL channel.
    Also, I am not capable of doing the repair/soldering. Are there any shops that you suggest? I don't know Fixya's policies, but can I ask for contact information here w/o causing problems? I can be contacted at peter4jc@gmail.com.
    New Friend:
  • 4 Answers
The f-l channel of the sr18, & sr18ex & sr19 is a common failure location due to the heating and cooling over the years. The crackling an/or distortion, is most commonly due to the amplifier going into a high idle, or d.c. offset that can no longer be controlled by the adjustment potentiometers on the board. usually the two 2sc3200 transistors become unstable, and as well a 47mfd and a 470 mfd elect. caps nearby. Also distortion is caused by one or more of the zener and germanium diodes all grouped near the big dual ceramic white resistor. The amp block is held in by six screws. first remove the cross bracket, then cut the cable tie free from the hole on the board. Ten screws hold the top board on, the pull the boards apart from the connectors. before replacing it, resolder ALL of the connector pins to BOTH boards.
Posted on May 27, 2009
    Novelist:
  • 98 Answers
Dear Peter,
From the problems listed by you, I think there is some leakage on the power board.
But before we do further trouble shooting, please do check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Take out all the wire and put them back again if necessary..
Are you using banana plugs for connecting speaker or just directly. Some times even a little tiny frayed wire touching the receiver could trigger the protect mode or have that cracking noise. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
If everything else seems all right and still your receiver is making the static noise then it possible that there are bad connections on the main board that are set in. This would generally happen if the system is slighly old or have dry solder. This should be a simple repair that may not require parts or maybe just the change of some capacitors.
If you can solder, you will be able to repair this yourself, I could guide you further. If not, then a local service center will change the local labor rate. Let me know if I can guide you further.
Best of luck! Thanks for using FixYa!
Posted on Apr 20, 2009
  • Sachin
    Sachin Apr 21, 2009
    Dear Peter,
    I suggest if you are not confident about soldering, then it best left alone, since you could do more damage than repair your self. But, If you friend is confident then :
    Generally, there are poor solder connections somewhere on the main board. Usually these are at the voltage regulators where there can be some heat. Look for 3-legged transistors attached metal heatsinks, If you can solder, resolder the pins on those parts. Also look for any connections that appear to be grasiny or have rings and resolder them too.
    Let me know if it help....we can then trouble shoot it further..
    Best of luck...
My Marantz SR6200 is not playing loud and it only plays in analog and when it does and I select tuner cd or Dvd will play, there is also a little crackling on the front right speaker. please if anyone...
Hi, maybe you have speakers misconnected or speakers wiring with short circuit (joined bare cables), please check them because if this continues for a long time, your device could get damaged.
Oct 20, 2013 | Marantz SR-6200 Receiver
I have a constant "crackling" noise in the left channel. I've replaced all 4 power transistors. The crackling is still there. Any clues?
Look for an open resistor in that channel. could be the large emitter resistor, or one of the low-ohm flame-proof resistors.
Jan 30, 2013 | Sony STR-DE197 Receiver
My sr 18 has no audio output,on all speakers,but video is good.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Marantz-SR-18EX-Receivers-manual/id/511ci766/t/2/
Headphones connected?
Disregarding specific sources, how does it do with test tones?
Jul 09, 2011 | Marantz SR-18EX Receiver
Marantz SR-18EX Loses Memory and Has Distortion on Center Ch.
There is a 1 Farad "super capacitor" that needs to be replaced. You need soldering skills to do it. The board is accessible if you remove the front panel of the receiver. The part # is DB-5R5D105; you can get them on eBay for about $2.00 each. Regarding the center channel issue, you may have a bad solder joint on the P781 connector on the P774 board. This is the board that houses the output transistors for the 3-channel main amp board (P704). If not these solder joints, you have a weak driver transistor on P704, and troubleshooting would probably be best left to a pro. Good luck!
Aug 17, 2009 | Marantz SR-18EX Receiver
Left side crackling noise Blown channel?
Would check your balance settings. Make sure your not balanced more to left than right. Next i would try to swap over one of the speakers from right side to left to see if it crackles. If not replace left side speakers.
May 19, 2009 | JVC KS-FX200 Cassette Player
Marantz SR-18ex remote control number
If you mean the model number, that is: RC-18SR
Jan 10, 2009 | Marantz SR-18EX Receiver
Do you know the remote code for the Marantz SR-18ex receiver? I want to control it from my Comcast remote and can't locate a remote control number.
The stock remote for the SR-18EX is the RC-18SR - that's the one it shipped with when new. You can also use the RC-2000, RC2000 MkII, and I have an aftermarket RC-1400 that works perfectly with my SR-18EX, AND offers 15 macros instead of the standard 4 you get with the stock remote.
Loss of volume on left channel
Marantz SR 5200/6200 lost audio or crackling on left or right channel except in mode s-direct is now fixed !
The root cause is a defective inegrated circuit on DSP board (the one with digital inputs). To fix it change the chip CS4391 by a new one or better by the improved version CS4392. On my device a capacitor was cut close to this IC : replace one 1uF after changing the IC. For any question search me with my callsing "F5RCT"; i have a spare IC for the one who is able to change it !
I'm amateur radio and engineer
Oct 15, 2007 | Marantz SR-5200 Receiver
No output from left channel after crackling sound
Jul 08, 2007 | Marantz SR-4200 Receiver
Losing volume on channels
I am afraid not. That crackling is a component in one of the solid state amp circuits starting to fail. These are all soldered into the printed circuit board. This could be a difficult repair to find an intermittant component. Depending on how old the unit is and how much it cost will factor in on if you have it repaired or not. Rule of thumb is that if the unit is two to three years old and cost less the 200 to 300 bucks you should not invest more then 100 to 150 bucks into it. Good Luck
Mar 14, 2007 | Sony STR-DB840 Receiver
Marantz SR-18EX Receiver Logo
937 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
