Question about Dell ADA745 Computer Speakers
Speakers connected to the flat panel won't work
What gives. Brand new from Dell....i plugged in...checked to be sure all mutes were off, just get no sound....there is a sound card installed.
  • 298 Answers
You need to plug in a sound cable to the flat panel. DVI or VGA cannot carry audio signals so a cable will be needed. I would suggest just plugging the sound into the rear of the PC is the system didnt come with the extra cable.
Posted on Apr 20, 2009
    Novelist:
  • 177 Answers
Don't Connect them to the Monitor Directly.
It will Be easier for you to Connect them TO THE SOUND CARD (back of computer).
Audio will play on internal speakers only
Are you plugging the external speakers into the right port? Try plugging them into the Headphone port if there is no external speaker port. Make sure you have the external speakers turned on and the volume turned up. Also make sure you have the software in the computer to have the volume turned up and not muted. Check the audio sound properties and make sure the volume is turned up and not on mute.
Click Start/Control Panel then look for Audio or Sound and check the volume.
You can also click the megaphone at the bottom right near the time to adjust the volume and check for mute.
May 12, 2012 | Dell Inspiron Mini 10 Notebook
Brand new out of the box Dell 560 set everything up and plugged in the speakers to the USB and the jack in the back and nothing no sound. the speakers are on, but the machine says no device detected. ...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 11, 2011 | Dell Audio Players & Recorders
Same problem, brand new Dell Vostro, hooked up Polk Audio speakers from former computer and get very, very faint music. Need a solution
if the sound is very faint. you can check the volume properties if it is set to maximize and also check the physical volume control on the actual speaker - also Disconnect Any Headphones That May Be Connected to the Computer - Check for and remove any headphones connected to the computer or speakers to prevent them from muting the external speakers.Click Start, and then click Control Panel.Double-click Sounds and Audio Devices. Click the Sounds tab. You can also try head phone if it is Crystal Clear on headphone then the problem is with the Speaker as Dell might need to replace it. :)
Dec 08, 2010 | Dell A215 Computer Speakers
I purchased a dell pc from a neighbor without speakers. I have hp speakers from an older computer and cannot figure out where or how to connect them. there are 3 possible places for speeker jacks, have...
Howdy, the speaker input on a Dell is often on the front and the back. It is usually the green one. The speakers from the HP should have no problem working on the dell; It doesn't care what brand of speaker it uses. Making the actual connection is only part of the deal, the mute could be on or volume turned all the way down.
If the speakers require external power, make sure they are plugged into a good outlet and turned on.
If you check all these things, and still have no sound, let me know and I will help figure out what to do next:)
Regards, Farmerbear at FixYa.com
Sep 15, 2010 | Dell Audio Players & Recorders
I have just installed speakers on my computer, but I can't get any sound.
Check to make sure the speakers power up.
Check to make sure you have installed the speakers into the correct jack on the back of the PC.
Go into Control Panel and check the settings by double-clicking the "Sounds and Audio Devices" icon. Make sure the Mute box isn't checked and that the volume is turned up.
Dec 09, 2009 | Dell Dimension 4600 PC Desktop
Dell speakers not working with HP Pavilion
Have You Plugged the speakers in the GREEN audio port on the back of the Computer?
Nov 16, 2009 | HP Pavilion Elite M9250F Desktop PC
My speaker all of a sudden stopped working, they are built into my monitor, and worked last night. what do i do?
  1. Check the volume control in windows and make sure audio was't muted
  2. Check the audio cable and ensure it is connected to the port on the system
  3. Ensure headphones are not plugged in an aux audio port as they will mute the speakers
  4. Check the audio drivers in Device manager
  5. Try a known good set of speakers (Or CD player headphones) and ensure the audio on the system if functional
  6. If all else fails, replace the speakers ($20 or less at any major department store)
Oct 14, 2009 | Dell E153FPT 15" Flat Panel LCD Monitor
Problem with Dell AX510 Soundbar
in order for your sound to work you have to disable the on board sound in the bios . unless you already did the , then i would return it and get a different one.
Apr 20, 2009 | Dell ADA745 Computer Speakers
Hello there, I have a Dell computer and trying to use HP speakers with it. Will this not work? I am not hearing a sound and my computer shows no device for speakers.
The HP speakers should work fine with your Dell.
Make sure that you have the speakers plugged into the correct port on the back of the Dell (This is typically a green colored port) Once the speakers ar plugged in to the correct port make sure that your sound is not muted.
Click on Start then on Settings or Control Panel.
Once you get to the Control Panel double click on the Sound Icon.
Verufy that the sound is not muted and you can also check the box to display your voulume settings on the task bar.
You may also want to check that your sound card in correctly installed.
Check these items and let me know if there was any change because there can be other items to check - These are just a few good jumping off points
Dec 28, 2008 | E-Machines eMachines Desktop PC
I can hear them talking but they cant hear me
Do you have a microphone plugged in? If so then see the picture attached for how to get the sound settings menu.4c9e35b.jpg
Jan 22, 2008 | Audio Players & Recorders
Dell ADA745 Computer Speakers Logo
187 people viewed this question
Top Dell Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
