Question about HP Nc8430 Notebook
On other devices I have a ? mark next to PCI SERIAL PORT How to fix this
In device manager there is a ? besides PCI serial port where do I get the drivers for this?
How to check fo faulty USB port
W 7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for XP or earlier
Click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts Check if USB Ports Are Damaged
USB ports are an important part of your computer's hardware.
Many devices connect to the computer via USB, such as music players, cell phones and digital cameras.
This connection lets you charge your devices and manage files on them.
When you connect a device to a USB port, it is typically recognized automatically.
If not, there may be a problem with the port. USB ports sometimes fail on their own, or they may be damaged by force.
Plug a variety of devices into the USB port you think is damaged.
If none of them work, the port is probably broken.
Connect the same devices to the USB ports on a different computer.
If they work, this is another indication your ports may be damaged.
Run Windows Update on your computer to ensure your devices and computer function together and have the latest drivers.
Click "Start," then type "Update" in the search bar.
Click on "Windows Update," "Check for Updates" and "Install Updates."
Open the Windows Device Manager by clicking "Start," then typing "device manager" into the search bar.
Click the Device Manager link when it appears.
Click on each of your USB ports.
In the Properties window, look for "This device is working properly."
If this is displayed for each USB port, they are not damaged, but there may be a problem with your device instead.
Click "Update Driver" next to each USB port in the Device Manager, and Windows searches for and installs the latest driver.
If one can't be found, go to your computer manufacturer's website, and download the driver there. Try to use the USB port again.
Sometimes, outdated or damaged drivers result in a non-working USB port.
Open your computer case by unscrewing or sliding off the side cover.
Use a can of compressed air to clean out the dust from inside, especially from within the USB ports.
If your USB ports are hooked up to the motherboard, remove the cable, then replace it.
These actions sometimes help to fix non-working ports.
http://askbobrankin.com/usb_ports_not_working.html
Sep 05, 2013 | Dell OptiPlex 780 Desktop Computer 1 x...
Hi sir, I need help on my pc, i install a usb 2.0 pci to usb card on the mother board but cant get it working, i have on device manager under other devices have an exclamation mark on universal serial...
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
http://download.cnet.com/via-usb-2-0/3000-2098_4-10163319.html
Available in this download are drivers for VIA USB 2.0 host controller on a system running on Windows 98/98SE/Me. Due to licensing agreements, USB 2.0 drivers for Windows 2000/XP are not available for download. They are supplied on CD with new mainboards or available through Windows Update. This version is a bug-fixing release.
hope this helps
Jul 30, 2011 | NEC Televison & Video
My motherboard intel d915gav pci device not instal driver
You can download the motherboarddevice drivers from Intel WEB site. Select your model motherboard/device, andmake sure you select the Windows XP or Vista version of the drivers that
matches your Windows operating system. Please click on this link andselect your model motherboard : - http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
Jun 29, 2011 | Intel D915GAV Motherboard
NVidia GeForce 6600GT card (XP SP3 32 bit 3.0G Intel) is running VGA out plus video out via its S-Video port. The card flashes the monitor on and off at regular intervals. Can you help?
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
If your computer came with a motherboard disc the drivers could be on it
Want to make sure your drivers are in place and no errors have occurred? Simply click start right click on my computer select properties then select device manager scroll to Display Adapters and click on the small "+" you should see the model of your PCI Express graphic card there. If there is a problem with it, a yellow exclamation mark should appear besides it. If you don
Mar 26, 2011 | Gigabyte GeForce 6600GT, (128 MB) AGP...
I recently downgraded from Win7 to XP i got all the drivers installed but when i check Device Manager there are 2 device with Yellow question marks namely: PCI Device and PCI Serial Port ive check on the...
The "PCI Device" and the "PCI Serial Port" could be a modem that lacks the device-drivers.
Access: http://WindowsUpdate.Microsoft.com and do a "custom" search.
When it completes, click "optional hardware updates", to see if Windows Update is offering any device-drivers for your hardware.
Feb 21, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
My sound just quit and I was told that I would need a a new sound board or mother board?. can some one explain how that went out and is there nothing else that could be wrong with it before I go spend...
You should first check you have not accidentally muted it in both windows and on the speakers itself. Next go into Device Manager and check the sound driver is installed (no yellow exclamation marks can be seen).
If this has not resolved the problem then it is probably your soundcard. If you soundcard is integrated onto the motherboard then there may be further defects.
Check what internal ports you have free, there should be some long ports called PCI or PCI-e (not ports in line with the RAM). You can then buy a PCI/PCI-e sound card and it will just clip into the slots.
Hope this helps,
www.PuterCare.com
Jul 02, 2010 | Gateway GT5656 Desktop PC
My sund device wnt show up anywhere n my system(cmpaq evo usdt)
Hope this helps,
www.PuterCare.com
Jul 02, 2010 | Compaq Evo D510 PC Desktop
Tells me speakers not plugged in
Check that the speakers are plugged into the correct audio port, this is usually an apple green colour. Next go into device manager and check all drivers are installed correctly. Below is some further advice I wrote for another user.
Hope this helps,
www.PuterCare.com
Jul 02, 2010 | Dell Inspiron 531s Desktop Computer
Can not get online because of missing drivers for ethernet
do windows update custum scan least get driver for erther net on a cd from anther ok the custum scan then hardware add all
Feb 05, 2008 | Microsoft Windows XP Home Edition
PCI adapter did not install
I don't know how you could have installed the drivers BEFORE you installed the hardware... Shut down and UNPLUG the system; REMOVE the new PCI card, then hook up the power and boot the system back to the Desktop. Check the Device Manager to be sure you're not showing any problems; if everything seems back to normal, shut down and unplug the system a second time, then install the PCI card again, restore power, and prepare to reboot the system. Be SURE that ALL of the PCI cards are fully seated in the slots, and that the main power cable (from the PSU) is fully seated in the connector; IOW, check the system just to be sure that nothing has come loose while you've been working inside the case. Next, boot the system again; Windows SHOULD detect the new PCI card during bootup, though it might NOT request drivers, if they are already embedded within XP itself... Once you get back to the Desktop, open the Device Manager and check to be sure that the new card has been detected and properly installed. If you see any question marks, error messages, or exclamation marks, take detailed notes, and post that information here, so we can help you troubleshoot the problem... Good luck; I can only give you general advice about this, because you didn't provide any specific details about your new hardware, but with a little luck, you'll get everything working without any more heartburn...
Mar 31, 2007 | D-Link DU-520 - 5-Port USB 2.0 PCI Adapter...
HP Nc8430 Notebook Logo
170 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
