Question about Kenwood KDC-X590 CD Player
I took my cd player out because the display was blank. I decided not to mess with it and put it back in and now it's locked up in protect mode. If anybody has any advise on what the problem may be please help me out!
Im not completely sure but it seems like that would either be a fuse or crossed wires.
Posted on Apr 20, 2009
You need the security code for the radio cassete should have come with the owners manual
I was attempting to take my head unit out, and i assumed i had to use removal keys and whilst trying to use them to remove the head unit i dropped one of the keys into the unit. i diddnt think this would...
remove the unit from power for about 15 min, that should clear the settings then plug it back in. if it still shows protect then there is a short in one of the power or ground wires.
Mar 08, 2011 | Kenwood Kdc-mp445u Car CD / USB/ MP3...
I have a kenwood it says,kdc-mp142 and all of a sudden it just says protect. it wont do anything
The Kenwood radio will generally give a "PROTECT" error if the amp or receiver is being overloaded. This may mean that some of your wiring may have gotten frayed, one of your speakers isn't putting out the right voltage, or the receiver has decided to go bad. Make sure all of your connections in the back of the radio are solid and not frayed. If that's not the problem, try running each of the speakers one at a time. If one causes the radio to go into protect mode, that's your culprit.
If neither of these are the issue and the radio decides to stay in "protect" mode, your receiver may have seen better days and may need a replacement.
Feb 28, 2011 | Kenwood KDC-MP142 Car CD/ MP3 Player
MY KENWOOD CAR CD PLAYER IS SAYING PROTECT??
Kenwood head units show "protect" when there's a problem with the speaker outputs. This might mean a shorted speaker wire, a blown speaker, or an internal defect in the head unit. Once the condition that's causing the "protect" mode is fixed, the CD player should be back in normal mode the next time you turn it on.
If it's staying in "protect", then you'll definitely have to remove the stereo and do some troubleshooting to fix it. Many car audio stores will do system troubleshooting, for a fee. If you want to do it yourself, here's what you need to do:
Pull the Kenwood unit from the dash and disconnect all the speaker wires. Turn it on and see if the "protect" message displays. If it does, the stereo has an internal defect and will need to be serviced. If it doesn't, then turn it off, and re-connect one speaker. Turn it on again and see if it displays "protect".
If it works with a single speaker connected, keep re-connecting the others until you identify the speaker that's causing the problem. There may be a wiring problem or defective speaker in that location.
If it displays "protect" with a single speaker connected, then disconnect that one and try a different one. If all the speakers cause a "protect" mode, then you're probably back to a defective head unit, unless your friend managed to blow all your speakers at once.
Thanks,
Dec 09, 2009 | Kenwood KDC-319 CD Player
Kenwood car stereo cd player reads protect mode how do i fix this
i have a kenwood kdc-241 car stereo and it has gone onto protect mode i have done everything it says in the manual and even taken it out of the car just in case it was damp i have tried putting it back in but still is in protect mode can anyone help me please
May 25, 2009 | Kenwood Car Audio & Video
Protect Mode on Kenwood KDC-MP335
this is very simple to do just take your face plate off and were you see a red light blinking just get like a bobby pin or something and pit it through the hole and the radio will reset and that should fix your problem
Jun 23, 2008 | Kenwood KDC-MP205 CD Player
Display read protected and wont do anything
Usually, protect mode is enabled when the speaker output wiring has shorted together or is touching ground/+12V. I would verify that none of the speaker wiring has come loose.
Mar 19, 2008 | Kenwood KDC-MP5032 - Car Audio CD MP3...
Will not record
the classic cdr201 will not record it will go to wait and return to cd status(blank cd etc) there is no led display of sound during this operation you can hear the audio for brief couple of seconds before it goes back to cd mode
Nov 28, 2007 | Classic Electronics CDR201 CD Recorder
RCA CD recorder/player CDRW120
You sure it's recognizing the CDR? And you are using 'consumer audio' cdr? Watch it at all times. If it 'opc fails' after you put a blank in it still shows as a CDR and 0:00 on the display but won't record. It's easy to miss.
Nov 02, 2007 | RCA CDRW120 2-Disc CD Recorder
Kenwood KDC-X590 CD Player Logo
93 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
