Question about Electrolux 30" Built-In Single Electric Convection Wall Oven - Stainless-Steel
Control panel doesn't light up
We purchased a home with this oven and were told by a friend who owns a similar model oven that if you touch anywhere on the control panel, all the different buttons (cook, clean, bake, broil, lock, oven light, etc) should light up. Instead, the only way to get a response out of the oven is to touch it directly on the button, and only that button lights up. The oven cooks fine though.The actual model # is E30EW75DSS.
  • 6,784 Answers
HI, this issue concerns the touch pad(control board led). This will happen in certain models. it could be some minor corrosion within the wire contact clips that are not allowing the proper current to illuminate the led that is used to light the specific button or, it could be a minor circuit issue within the control board as well.
i recommend inspecting the control panels wire harness contact clips that are behind the actual control board. make sure they are not corroded or lose. if they are lose or corroded, i suggest replacing the entire wire harness. this could be the possible reason for some of the lights that are not illuminating during operations.
If the wires and contacts are in good condition and the harness is in good condition as well, this could be an internal control circuit board issue, concerning the LEd lights. they may have burned out due to the age or heavy usage.(heat related)..
Please rate and god bless:)
Posted on Apr 20, 2009
Whirlpool Wall Unit Double -oven. Part # 4451887 REV. C Control Panel doesn't work. Interior lights come on and the oven constantly beeps. We have been waiting for a replacement part for 4 months.
I have the same problem with the same part and was told by AppliancePartPros that the Control Panel would not be available to them until Feb 2012. I noticed a discoloration near a power transister and the big power resister next door (installed with about a 1/2 inch clearance to the PCB board, labeled R188 on my REV A board). The solder connections from the R188 resister to the PCB were cracked. That resister was hot when I touched it and the thermal cycling probably cracked the solder joints after 9 years. I am going to resolder those connections tomorrow and see if that resolves the problem. Do you see any burn marks near that Power transister (3 lead black package with a metal heat sink on its back (the heat sink has a circular hole above the black plastic package)?
Sep 01, 2011 | Whirlpool RBD305PD Electric Double Oven
Most of the buttons on the panel do not respond when pressed. incl;uding, convection, setup, rapid preheat
Are the oven doors locked as well, check if the front panel lock is active. Press and hold both the upper oven Cancel and Cook & Hold buttons for 3 seconds (or a bit longer). (Off should disappear from the display and the Lock indicator will flash.)
If that doesn't help, try pressing Cancel. Then try pressng the Cancel and Cook&Hold keypads together. If this doesn't help, then the control panel or the control itself is damaged and probably needs to be replaced. (Touch pads like this have electrical contacts on a membrane that is impossible to fix long term by cleaning the unit.)
For a parts list and prices see: http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Wall-oven-Parts/Model-JJW9130DDS/1266/0125300/M0603043/00001?blt=06&prst=&shdMod= or http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170052&diagram_id=28429593 . Specifically part 1A and 2 are suspect. The control panel is the more likely part to fail (much like a membrane keyboard).
Most Jenn-Air appliance manuals are available here: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US . Fill in Consumer and then the model number and press the right arrow button. The direct link to the manual is http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10176680.pdf .
I hope this helps.
Aug 11, 2011 | Jenn-Air JJW9130DDS Electric Single Oven
Only some of the keys on the keypad of my oven work. I have replaced the control board (computer board), but they keys still don't work. What specific part do I need to replace?
Hello, Thank You for using FixYa. I will be helping you today.You didnt have to change the computer you need to replace the control panel. The control panel is the whole front piece which has the touch membrane on it. This is common on these units.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Maytag MEW6530DDS Stainless Steel Electric...
Hello and thanks in advance for any help!\r\n I have an Electrolux Wall oven model# E30EW75ESS that has seemingy lost its mind, or temp control at least. When I spoke with Elux they told me that the front...
Call Electrolux service and not a private service man. These appliances are sophisticated and many require proper factory training to service. Most likely there is some type of latch or a retaining key-screw that is not clearly visible to release the glass cover. Actually the cover is most likely ceramic and if so is expensive to replace if it gets broken. These can be delicate to handle.
Apr 02, 2017 | Electrolux 30" Built-In Single Electric...
Sparks from the thermostat control! - frigidaire oven
you may have blown the control board. or blown the ac main control fuse for you home wiring. this is in your fuse box cookers have there own fuse separate from other appliances.
Jun 13, 2017 | Ovens
My DACOR + ECS 130 covection oven light relay keeps clicking.....
I have the same problem and sent an e-mail to DACOR. A James Carlos responded and advised that DACOR could not provide DYI info because of liability problems, pure BS in my opinion. I've had problems with a DACOR microwave (manuf. by Sharp), my DACOR wall oven Model ECS103 and my DACOR Raised Vent system and told Mr. Carlos so. I don't know how to fix the blinking oven light other than cutting power at the circuit breaker panel or removing the two light bulbs which other have advised but suspect a new front control panel is required. If you find a fix, please advise me at bsquared37@yahoo.com. I think DACOR products are overpriced and junk.
Thanks, Bill 12/10/2009
Aug 27, 2009 | Dacor ECS130 Epicure Electric Single Oven
Error code E6 F2
We repair these control boards frequently. The E6 F2 error is very common for whirlpool ovens and almost always is caused by the control board. It can be repaired quickly and reliably. www.fixyourboard.com
Jul 07, 2009 | Ovens
Maytag wall oven Model # MEW6530DDS control panel failing
HI, unfortunately, it is not just dirt, this is a faulty touch pad that is combined with the control board. most touch pads are separate parts that are clipped in front of the circuit board but, in this case, the touch pad and control board are one piece. You will need to replace the entire control board in this case. the touch pad is faulty.
Jun 03, 2009 | Maytag 30" Built-In Single Electric Wall...
F1 error code for Maytag CWE5800ACB
Defective touch pad or membrane, usually the touch pad.
Dec 24, 2007 | Maytag CWE5800A Electric Double Oven
Electrolux 30" Built-In Single Electric Convection Wall Oven - Stainless-Steel Logo
872 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
