Question about Husqvarna Designer I
Touch screen When I touch the screen nothing happens. Everything else works well. Does anyone have a diagram of how the board is wired? I had to take off the cover due to the fact that the bobbin winder needed repair. There is a pin on the bobbin winder that sometimes jumps out of the hole. I can not afford to take it to my dealer. Can anyone help me?
    Novelist:
  • 192 Answers
The most likely culprit is the cable of the touchscreen. If the cable is about 1/2" wide and yellowish brown in color, take it to your dealer and ask them to calibrate the touch screen for you. The screen can be calibrated by a trained technician without having the ability to use the screen for the adjustment.
If the cable is about 1" wide and green, save up your money and have your dealer replace your touch screen. Those cables are very short and if you flex the end prior to getting your hand in to disconnect it you can very easily damage the cable and the touch screen must be replaced. Also, if the cable was pulled taught during removal and pulled out of the connector on the main ckt board prior to releasing the locking device the contacts on the ribbon may have been damaged.
Just be honest with your dealer and tell them that you can't afford a costly repair at this time and you need to know what is wrong.
I don't know what your dealer will charge for labor, but I can say that a new touch screen costs about 5 times what a new bobbin winder does. Removing the covers of modern machines on your own can end up causing your repair cost to skyrocket. Also, once the pin in the bobbin winder has moved in the frame, it will most likely move again and the winder should be replaced to avoid recurrence.
Posted on Apr 20, 2009
Bernina 180E Touch Screen Dark, machine light won't come on.
I don't know the circuit of this sewing machine but it gives me the impression the light and the board are in series with a fuse. If this is true the light will burn out and cause the screen to go black as well. If the fuse would go out the same thing would be true. Anyway, change the light first. If this doesn't work you will need to replace the fuse. If there are still problems it will need the mother board to be replaced. Tell me how this worked out.
Oct 24, 2014 | Bernina Artista 180
The LCD Touch-Screen not working
Hi-
Chances are you need to reset the settings. check the guides as well for the correct setup.
Hope this helps
Sep 22, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Brother 4000D innovis machine....when I turn it on, it will not start up..the lcd screen is faintly lit, and the machine just beeps
I had the same problem Machine off! I took off the rectangular cover on the right side (had to pry it carefully} GENTLY Pushed in connections of wires to board and then plugged in and it worked!! I happened a couple of times They must vibrate loose. All I has to take apart was that rectangle cover
Jan 18, 2013 | Brother InnovIs 4000D Computerized Sewing...
My Kenmore 19001 touch screen works when I am sewing regular stuff, but when I put in the embroidery card - I can see the designs on the touch screen but nothing happens when I try to go to a design. I...
to recalibrate the machine press the stop/start; the reverse; and the knot button at the same time and while holding it down turn the machine on.
Sep 28, 2012 | Kenmore 19001
I am a service technician and am in need of the diagram illustrating the schematics for cable connections to the pc board. Can anyone help me without it costing me anything?
Do you want detailed information on what each wire/signal is, or are you just needing a 'block' diagram covering what each connector generally does ?
Aug 22, 2011 | Bernina Virtuosa 160
HOW TO CALIBRATE MY DESIGNER 1 SCREEN the screen is off if i touch program nothing happens and the arrows are off to the right side
Hi,Try this,switch off machine,press in reverse and pivot button together,switch on,release buttons and press up/down needle button,this brings up calibration screen.With a plastic stylus or something similar(not metal) touch in centre of each cross,they should turn green.Switch off and on again,and it should be fixed. Regards, Cathy.
Sep 15, 2010 | Husqvarna Designer I
DEsigner I...I had been having some issues with the touch pad. Now it does not work at all when you touch it.
Youu either need a new touch screen or it has come unplugged from the main power board inside the machine. Those touch screens cost about $210 and should only be installed by your dealer. If you have someone try to put the touch screen in and they just touch the display screen incorrectly, you'll need a new display screen too. They cost about $700.
Nov 10, 2009 | Husqvarna Designer I
The touch screen is scrambled and frozen
Are you saying that nothing at all happens every time, or sometimes you get the wrong thing i.e. you touch Prog and Rep screen comes up? Have you ever recalibrated your screen? This should be done regularly - at least every six months, but I do mine monthly. The catch is that in order to do this, you need to access the Set Menu and if your screen is not responding at all this would be impossible. In the Set Menu on the last page (I think) there is a "Color Touch Screen Adjust" button. Use this to access the calibration screen, and you must touch exactly in the centre of the two crosshairs until they turn green. Instructions are on Page 31 of my manual.
Mar 07, 2009 | Husqvarna Designer I
Screen is frozen
Dec 26, 2007 | Husqvarna Designer I
Sewing Machines Logo
292 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
