Nikon D70s Digital Camera Logo
Posted on Apr 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Camera will not power up changed battery just went dead Nikon D70
Changed lens and went to turn camera on and would not power up no display, changed battery, still not display or anythin camera went dead
Jeff Marcus
Level 2:
Scholar:
  • Nikon Expert 115 Answers
  • Posted on Apr 21, 2009
 Jeff Marcus
Nikon Expert
Level 2:
Scholar:
Answers
115
Questions
0
Helped
37474
Points
169
Are you getting any power from it? How about an error message?
Try blowing some compressed air into the battery chamber. There might be some debri or dust in there. Try replacing the battery to see if that solves it. (Someone you know must own a D70).
HOW TO SOLVE BLINKING BLACK SPOTS IN MY NIKON D70
I can duplicate your issue on my Nikon D810. You may have set it to display the areas that are over exposed or "clipped". Go to "Playback Menu", select "Playback display options", uncheck "Highlights".
Fixing a Dead Nikon D70 - Green Blinking Light My first-generation Nikon D70, which I bought the day it was released to the market a few years back, died on me a few months ago. Without a card in it, it won't start, and when you insert a CF card in the slot, the green data-access indicator flashes on and off. If I hold down the Menu button, the menu flashes on and off along with the green LED.
d70_87x1.jpgAs it turns out, this is a known problem with the original Nikon D70 cameras, and Nikon USA has a service bulletin out on the camera body. They'll repair it free of charge.
So, if you have the same problem, visit this service bulletin page, http://nikonusa.com/Service-And-Support/Service-Advisories/D70-Service-Advisory.page click on the D70, and you can access a PDF file that you'll need to print, fill out and send to Nikon along with your camera body. Be sure to take your camera strap off and remove the battery, and don't send any lenses or other accessories.
Mine's on it's way to Nikon now - they say the turnaround is five days (plus shipping time).
Nikon D70 with brand new Sandik ultra11 2gb flash card error CHR
Go to the Nikon site and upgrade the firmware on your D70 to version 2.0.
Before doing that, try turning the camera off, wait a min, then back on. That sometimes clears the error. The D70 is having trouble reading the card(s) you're putting in. The upgrade fixes that.
1helpful
2answers
Nikon D70 On/Off switch will not turn the camera off.
Hi, The problem with your camera is the power switch under the top cover needs to be repaired Or replaced by a camera repair tec, I have repaired this problem many times, Not a quick fix.
When I changed lenses my d70 went dead
I had something very similar happen to me.
I now know what I did wrong.
I was using an older type lens that did not have electronic contacts.
I forgot to turn the camera off before I removed the lens and I believe this may have short-circuited the camera electronics.
I have to get the camera repaired at a cost of about £90 (sterling).
Nikon D70 will not power on after the lens was changed~
EDAWinc,
Is this a new or different style lens? You may not have it all the way on and aligned - try removing it again. Just remember to always turn off the camera before removing the lens or the SD card. Malfunctions are sure to follow if that happens. Try resetting the camera by holding down the two buttons on the top with the green dots for longer than 2 seconds (that works with the D80) The camera will not come on if the lens is not "on".
randy320sgi
3answers
Nikon D70 problem
Noe at all except to contact Nikon for advice you may have damaged lens or camera
My nikon d70 won't turn on and the battery if fully charged
The black spot i suspect was the CCD or processor failing. Checkout Nikon customer support re this.
Nikon D70
i think is power board dcdc converter board has been faulted or somewhere there is a short circuit , you do one thing remove the lens and put the camera on manual setting push the mirror upwards with finger and make on the camera if you feel a loading if not some time its main moter drive board goes else i will purchase the camera in dead condition tell me the rate thanks
D70 digital camera
could be bent pin in the memory card slot
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
