Question about Refrigerators
Light on fridge door turns on & off
Have a Kenmore side by side. The light that illuminates the ice & water dispenser, on the door, is not working correctly. The light turns on & off by itself. With the light being off about 80% of the time.
  • 700 Answers
Check toi see if the light is tightned up on the soicket
Posted on Apr 20, 2009
The dispenser light won't turn off and ice and water not working after filter change..
I'm not really sure of this one but here's a couple ideas. If the refrigerator ice and water dispenser is not working the dispenser control board might be defective. The control board governs most of the functions of the dispenser system. If only one item of the dispenser system is not working, troubleshoot further to see if the problem is with one of the components in the system. The board is more likely to be the cause of the problem when the entire dispensing system fails. It may also be the door switch If the refrigerator ice and water dispenser is not working. When the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice maker dispenser. If the door switch fails the dispenser will not turn on. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.Before either of these try shutting it off (or place it in demo mode) and return is to active state.It may just need a reset
Mar 30, 2014 | Maytag MSD2732GR Side by Side Refrigerator
Last night, I connected an active water line to the back of my Kenmore side by side. The ice maker is making ice but water water and ice is not coming out of the dispencer. There is another water jug...
You have a dual water inlet valve where your water supply connects. One goes to the ice maker and the other goes to the water dispenser by way of the water reservoir you mentioned in the fridge.
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing.You should hear the ice door open and the augur motor turning to turn the augur which pushes the ice out the door. If the augur doesn't turn Take all the ice out of the bin and try. perhaps the motor is too weak or the augur is locked up. Take the bin out and try to see if the motor will turn with no load. The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter when you try the dispenser. If you are, probably bad motor. If not ,dispenser switch or solenoid is not working.
Apr 20, 2011 | Kenmore Side by Side Refrigerator
Kenmore s/s f/f; ice dispenser working; water dispenser not
If you can't hear the solenoid on the water inlet valve(it's on the back where the water supply hooks up) when you try the water then the water switch on the dispenser is at fault.
If you do hear it Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it doesleave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there.
Oct 02, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer door lost power, will not dispense ice or water, light does not work Kenmore/10 years old /side by side
Check the door switch.
If the door switch is not working the light will not work and the ice or water will not work.
John
Sep 28, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice dispenser won't work, light won't work.ge side by side fridge
A GE uses a 12 volt bulb . It will not come on , if you went and bought a bulb with the same receptical end . HAS to be a 12 volt .
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Smart light not sensing darkness
there is a small pc board right there in the front panel it sontrols everthing from the light to the water and ice despensing . there are a lot of problems with this board and there not cheep from 65.00 to over 100.00 . i would wait untill another part of it fails ,and it will your water will go out ,or your ice . then you will be forced to replace it most only last 5 years ( new refrigerators are only lasting 7 to 10 years ) good luck
Mar 19, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ge fridge makes Ice, doesn't dispense
turn freezer side to zero for 1 minute. press water dispenser
Jan 26, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
ICE MAKER NOT WORKING Kenmore cold Spot model# 106.55536400
there is some times a water relay that turns the water on and off the over heats, it located in the back where the water connects
Dec 08, 2007 | Refrigerators
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
