Konica Minolta Bizhub C451 Copy-print-scan Logo
A
Anonymous Posted on Sep 27, 2013
Konica Minolta C451 embedded network port is not working
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Mar 17, 2009
SOURCE: error c3921
C3921: Fusing sensor wire breaks detection (Center of the heating roller)...
• At the warm-up stage, the heating roller
thermistor/3 voltage does not decrease by
predetermined steps (temperature rise)
within a predetermined time.
Check the fusing unit for correct installation
(whether it is secured in position).
Check the open/close operation of the
upper right door.
Check the fusing unit, IHPU, PRCB and
REDB for proper connection and correct or
change as necessary.
If that check still give you error code 3921
Change fusing unit
Anonymous
  • 145 Answers
  • Posted on Mar 18, 2009
SOURCE: Konica Minolta c451: Tray 1 is not available
look behind the tray for paper....
if not do the folowning
power machine off from main switch sould be on the side or open the front door it;s on bottom left side.hold down the utility botton while powering on keep holdin untel prompted with message ...TROUBLE RESET press it should say ok than powr machine off wait 20sec power back on
hope that help
keep us posted
Anonymous
  • 67 Answers
  • Posted on Mar 30, 2009
SOURCE: Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
chip_reset
Konica Minolta Error Codes and Solutions
  • 210 Answers
  • Posted on Sep 03, 2009
SOURCE: network configuration for a minolta konica c451
If you know the IP of the machine, just type it in the browser address and you'll have access from there.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Anonymous
  • 7 Answers
  • Posted on Dec 13, 2009
SOURCE: how do you reset the konica minolta bizhub c451
Network settings are accessed through the Administrator menu. Press Utility/Counter, then choice #3 should be Administator Settings. Enter your admin password and Network Settings should be choice #5.
Also, if the bizhub is already on the network, you can enter the IP address into your web browser and log in as an administrator to get to the network settings.
Konica minolta c451 not booting after power on
Need to know screen advancement.
konica minolta appearing or
hour glass symbol or screen completely blank or full white...
2answers
Paper misfeed
828120c7-b2c6-4ef1-86da-8d12eb17847a.jpgkonica minolta c451 printing this type
First page of PDF files is printed in 10% size - rest of document is ok
Sir/Mam,
Does this happen with a word file, or a web page, or outlook, excel
please check. if OK with them its the file its bad. Mite want to upgrade the adobe to 10 or 11 current. Try different computer also. Print different adobe files also.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Base e-mail on a Minolta copier C451
ok the best way to do that is through the WEB interface. use a computer that is pluged into the same network the copier is. then login as admin PW is 00000000 or 12345678 then click on the scan tab. then change the email that your looking for
How do you reset the konica minolta bizhub c451 photocopier/printer to get access to network settings?
1helpful
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
