Home | Kodak | EasyShare DX6490 Digital Camera | I have a Kodak DX 649...
Kodak EasyShare DX6490 Digital Camera
Problem for Kodak EasyShare DX6490 Digital Camera
I have a Kodak DX 6490. I removed the battery to
By kjbont0 on Apr 20, 2009
I have a Kodak DX 6490. I removed the battery to charge and when i replaced it I get error code B03. The camera was not dropped, and was having no problems before this. Any ideas how to fix? Or sites on how to disassemble the camera?
Solution #1
posted on Aug 15, 2009
Somewhat Helpful)
BillB-SA
Rank: Guru  Kodak Expert Cameras & Camcorders  Expert
Rating: 85%, 298 votes
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Comments:
Aug 16, 2009
- This problem is frequently due to corroded battery terminals inside the camera. Remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
It uses a simple Q&A format to diagnose problems and propose solutions.
Was this helpful?
Yes
No
Popular Solutions for Kodak EasyShare DX6490 Digital
Questions and Unsolved Problems for Kodak EasyShare DX6490 Digital
Do you recommend Kodak EasyShare DX6490 Digital Camera?
Answer
Answer
I have a kodak dx6490. Recently I have noticed that the flash is not working - which isn't a problem... (More)
Answer
I swapped out batteries with the power still on. Now it won't operate properly. The power won't... (More)
Answer
when i have put in a fully charged battery .. i still can't get my camera to power up
Answer
how to install fisheye lens and adapter on kodak dx6490. Do I have to remove existing AF lens
Answer
Ho lo stesso problema. Sulla guida non esiste nulla. Alla Kodak non sanno risolverlo. Ho buttato i... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kodak EasyShare DX6490 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
