Question about Altec Lansing ADA 885 Computer Speakers
Can I hook up my ada 885 to my dvd player& my flatscreen tv?
Can I hook up my ada 885 to my dvd player& my flat screen?
Yes, it will even attach directly using a coax SPDIF cable. That is the best way to connect it. No distortion at all through the cable. Most DVD players have a coax SPDIF output, and the ADA885 has a ditto input. You can just use any single wire of a double cable it necessary, it will not interfere.
Posted on Jul 09, 2009
    Novelist:
  • 177 Answers
Yes. They are essentially Similar to any other 120 Watt Surround System for Home Entertainment. The Fact is, the only major difference is that the connections are different. On The PC it uses Stereo Standard Outputs. On Your DVD Player, It Will most Likely require an adapter to RCA (red/white -usually- Audio Cables). It just depends on your DVD Player. Have Fun!..... :)
Posted on Apr 20, 2009
Trying to hook DVD player to tv
CONNECTION THRUE USB WORKS.
May 22, 2013 | Televison & Video
I cant find any place to hook up a dvd player to it, Is it possible? Also What is the jack used for that is hanging above screen on left hand side. I have no manual as my son gave me tv for my bedroom when...
Look for a jack labeled HDMI, Component Video, or S-video on both the TV and the DVD player. You will need a cable that matches the jacks that you have available. HDMI is the easiest. Buy your HDMI cable on line - the retail stores mark them up drastically. Try firefold . com
Jan 13, 2011 | Televison & Video
I'm trying to get my dvd recorder and vcr hooked up to my new flat screen tv. How do I connect them and what channel do I put my tv on (flatscreens don't have channel 3 or 4) to recognize the dvd recorder...
DVD players do not connect using regular cable connections Your flat screen TV should have separate Audio and Video connections. These are the connections that you should use to connect your VCR and DVD player. If you have a combo unit, that is a single unit that has both DVD and VHS in one box, you might be able to get your VCR to work on the cable connection. However your DVD will not be able to work as the cable connection doesn't allow enough information to pass through. If you go to your local Audio Video store and tell them what you want to connect they should have the cables you need for less than $10.00. Good luck.
Sep 15, 2009 | Televison & Video
How to hook my altec lansing speakers to my TV? and my laptop @ the same time
You can do this through a receiver (like a stereo receiver). Hook the tv up to line 1 and the computer up to line 2, then hook the stereo receiver output to the input of your subwoofer. Then shift the receiver from line 1 to line 2 (as easy as pressing a button on the front of the receiver) to hear either one through your speakers.
Nov 26, 2008 | Altec Lansing ADA 885 Computer Speakers
No signal
can you double check the signal cable that its going to the right place?
I beleave its hooked up wrong.
Jun 09, 2008 | Insignia IS-LCDTV32 32 in. Television
Thanks for posting direct. As you posted, the Sony XBR has only left & right (white/red) outputs whereas your Altec ADA has multiple INputs. This leaves us with no other option but to used just the green INput of the Altec as the black and the S/PDIF has nowhere to be connected to in the Sony.
You would need to use a phone stereo to RCA cable/connector as shown below. Additionally, you would have to set up your speakers as suggested here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 11, 2008 | Altec Lansing ADA 885 Computer Speakers
Compatability with TV
Yes but you will not enjoy all the features of the Altec ADA 885 speaker system and if the TV's features will allow you.
Most TV's do not have audio out and if ever they do, chances are that it will only be left/right. Your Altec ADA 885 speaker system is capable of getting multiple inputs other than just left & right; main, front, surround & S/PDIF.
Hardware wise, the standard audio connector to the audio outputs of your PC are baby phone plugs, while those in the TV are RCA. If ever you will push through, you would need to get hold of a stereo RCA to baby phone cable. Am not sure if the yellow dongle cable that came with your package is long enough.
Additionally, here is a link to the normal installation instructions for an Altec ADA 885 speaker system should you be interested.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Jan 20, 2008 | Altec Lansing ADA 885 Computer Speakers
Altec Lansing ADA 885 Computer Speakers Logo
650 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
