Question about Dell Inspiron 1150 Notebook
No lights when power button pressed. acadapter shows power
  • Richard Finney
    Richard Finney May 11, 2010
    Does it work off the battery ?
    Thanks
    Richard.
    Novelist:
  • 177 Answers
Try a different outlet....
if that doesn't work, then...
Your Battery Might be damaged. (partially charging any type of rechargable battery/pack can substantially shorten the lifespan of said battery.) I would take your laptop to a repair shop or store and have the battery tested as well as the AC adapter.
Posted on Apr 20, 2009
My printer show error e07 how to solve
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
4 times Green Waste ink counter reset
Jun 01, 2012 | Office Equipment & Supplies
Battery doesn/t charge Instructions for charging
If the laptop works OK with the acadapter, then the adapter is OK. Does the charge/battery light come on? How old is the battery?
If the charge light comes on the battery is low power. If the battery is over 24months old and has been used in the laptop all that time, it is probably exhausted and need a replacement.
Mar 27, 2011 | Acer Computers & Internet
It was showing error code 5200, I did the fix of removing the print head and when I re-installed it , now it is showing that print head is incorrect. It is the original one that came with the printer and...
1. The printer is turned off and plugged the power cord.
2. Press Resume button 2 seconds
then press the POWER button until the green light on (when pressing the POWER button, Resume button ... jgn released first)
3. Then release the RESUME button, but do not release the POWER button.
4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ...
5. Release both buttons simultaneously.
6. Led will blink briefly and then will glow GREEN.
7. And the computer will detect new hardware, just ignore ...
8. Press the POWER button, then the printer will die.
9. Press the POWER button again then the printer will flash
Mar 17, 2011 | Canon PIXMA MX700 All-In-One InkJet...
My laptop wont start up. When I press the on button yellow lights come on and then turn red and then it shuts down.Why?
That would be of the following. There is no Operating system anymore on the hard drive to do a malware virus. Or also the motherboard needs to be replaced. Usually if there is a Orange/yellow light on the board inside, the motherboard needs replaced. Hope that helps you out. First try to reinstall windows from the CD, if doesn't let you boot from the CD ROM (F12) (F2) then it is the motherboard. Hope this helps you
Sep 22, 2010 | Dell Inspiron 1521 Laptop
No pawer up
Hi this is vinod. You said computer is not powering on. So first thing if it is laptop or netbook. check the walljack if it is working or not. or try with another. Acadapter brick cables so check the connection on either side of it. if fine check if any led or light glowing on the brick. if it is still not working. slightly vigil the acadapter where it is connected to the acadapter. if still doenst . check the pin in the port is secure or not. or acadapter pin is secure or not. if no go. check with battery if has enough charge. if no go
conact emachines support. it can be motherboard issue as well.
Apr 21, 2010 | E-Machines M5312 Notebook
My Dell Inspiron 1525 just stopped! Won't turn on!
Ok not an issue follow these steps
1. check the ac adapter has a light on it when connected to the laptop and when disconnected from the laptop.
2.If the ac adapter has light then connect it to the system and then press and hold the Fn key present at the bottom left hand corner and then turn on the sytem . Check if there is any light that comes on and then turns off . If it does make a note of it and at the same time check if the sytme beeps , if it does make a note of the interval of beeps
3. if there is no response then you could try removing something called as the memory from ur laptop by flipping the laptop over disconnect the acadapter and battery check for a bay whicj\h reads C/M on it which is the memry bay . U will find memory modules which is green in colour . u just need to move the latch on either sides of it to release it . Try one memory and then turn on the ystem . If this doesnt fix most probably its an issue with the motherboard .
INSPIRON SYSTEM HAVE ISSUE WITH MOTHERBOARD hence try using a different ac adapter amd check the acadapter port for damages .
HOPE IT HAS BEEN INFORMATIVE:)
Mar 31, 2010 | Dell Inspiron 1525 Notebook
Acer 5920 aspire wont start
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well.
2. Make sure AC Adapter is not yet connected to the laptop. Pressand hold on the laptop’s power button for 10 seconds to drain the powerflea.
3. Connect the AC Adapter for laptop to a known good power outlet, check ACAdapter power LED if it is on. Try to sense if AC Adapter is not makinga bit of noise when it is plugin to the wall power outlet.
4. Connect now the AC Adapter tothe laptop. Check if AC Adapter LED stays on when it is connected tothe laptop. If the LED stays on means the AC Adapter is fine. If the ACAdapter LED turned off check the AC Adapter pin that goes to the laptopAC socket if it is loose.
5. If AC Adapter stays on after connecting to the laptop try topower on laptop. If no power LED comes on then this is motherboardproblem.
6. Before replacing the motherboard there is one checking needs todo. If you can open your laptop bottom part then good, do this whenlaptop is not connected to any power source. Try to reseat the laptopCMOS battery then try to power on laptop after, if still fails thenreplace motherboard. I hope this helps.
Jan 19, 2010 | Acer Aspire 5920-6727 Notebook
It shows an error massage "service error 5100"
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Oct 25, 2009 | Canon PIXMA iP1300 Printer
Acer travelmate does not battery charge but pwr jack, battery ok
First power drain your system take the battery out unplug the acadapter and then push the power button on the laptop and keep it pressed for 2 mins without connecting any power souce this will drain the static power from the syteme after few mins connect the battery first and then connect the ac adapter that should take care of the issue.
May 05, 2009 | Acer TravelMate 2300 Notebook
Changed ink jets alarm flashing number 5800 showing
Hello Saron Girl,
its not 5800 its 5B00
7 times LED Blink Waste ink absorber full [5B00] - Ink absorber (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864 / 4221 / 4257)
<Service mode operation procedures>
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The LED lights in
green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
4) When the LED lights in green, press the Resume/Cancel button the specified number of time(s)
4 times LED Green Waste ink counter resetting
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes,
the printer returns to the menu selection mode automatically.)
Regards,
May 14, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Dell Inspiron 1150 Notebook Logo
70 people viewed this question
Alun Cox
