Question about Vizio P4 46 in. HD-Ready Plasma Television
My 50" Vizio plasma tv has no power.
My Vizio just turned off! Is there a quick fix? Nothing. No lights come on at all, not even the back up yellow light? If someone can direct me on how to fix this or what parts I need, I would greatly appreciate the help.
  • louhun May 24, 2009
    I have an lg and have the smae problem just turned its self off and now have no power chenged the fuse but still nothing
  • 4 Answers
Mine did a similar thing (VP322), I would go to turn it back on after it having been off for a while, and it would turn on, then off, then on... Over time it would cycle on and off even longer... Eventually it stopped working, would not turn on and made a clicking sound.
Mine was past it's warrenty, so I opened it up and inspected the switchmode power supply board (where AC connects, and two voltage ribbon cables going to screen circuit and main circuit). On the side going to the main circuit board I noticed that five electrolytic capacitors were bulging at the top (a clear sign of overheating) and when this happens, their values (in farads) tends to drop, which can cause voltage instibilities.
The capacitor values were:
2 x 25V 1000 uF
2 x 10V 3300 uF
1 x 10V 1000 uF
I replaced them with spares and reassembled the unit, and it now works.
Hope that helps!
Posted on Sep 03, 2009
  • HDrider48 Oct 04, 2010
    How do you get the back off the tv to access these capacitors?
I tried a quick fix for this on-off-on-then-just-off problem on my dead VP322 and it works. Since the VP322 stayed on after it warmed up and would switch on and off normally then, I reasoned when it wouldn't start to just heat it up. I put a small space heater in the cabinet behind the TV and let it go. Fifteen minutes later the orange logo came back on, I hit the remote ON and voila it started up and ran normally. I've done this six days now until I can take it apart and replace something (like the capacitors). If you don't have a cabinet behind the TV try a hair dryer on the back but be aware it takes upwards of 10-20 minutes to warm up enough to turn on, (Incidentally this sounds to me like a cold solder joint but I'll know more when I take it apart and investigate.)
Posted on Mar 28, 2010
  • John P. Cater Apr 07, 2010
    Okay, rkrupski96 you RULE! Tried your fix on my VP322 exactly as you said and it works! $10 in parts and an hour of time. What a fix. Many many thanx.
    Oh, if you don't easily see the capacitors at fault, on my LG power board they were:
    C204 1000uf 25V
    C205 1000uf 25V
    C233 3300uf 10V
    C234 3300uf 10V
    C236 1000uf 10V
    The voltage on the replacements doesn't really matter as long as it's the same or greater than these values (and the replacement part fits). I replaced the 1000uf 10V cap with a bigger 25V one but then had to hot glue it to the surrounding parts to keep it physically stable. I'm still amazed that this fixed the problem (I'm an EE and it seems like this might have been a design problem ---or feature ;-).
  • 92 Answers
Check the fuse on the power supply if blown then get new one (cheapest way). If not change the power supply. Make sure you check your power source to make sure it has power. breaker may have tripped. Just a thought.
Posted on Jun 16, 2009
I have a 50 Inch Vizio plasma High Def. and it turned off while I was watching it and it will not turn on again. I have tried unplugging it and powering it down, but nothing is working.
Hello
Will you please inform me some more details of the fault? Is there power indicator at the front panel of your TV? Or it is completely dead? Give me these details too please.
Sep 25, 2011 | Vizio VP50 10A 50 in. Plasma TV
My VP504fhdtv10a vizio plasma TV when connect power cord the Vizio in front light up yellow/amber but will not turn on. I have replace Logic Control D Board still have same problem. I do research online...
Logic Control D Board got nothing to do with this problem. This is your main power supply gone bad(usually not the sub power supply). I just repaired my VIZIO by replacing main power supply. Just remove back cover and your board will be right in the middle of the screen. Just get board part/serial # and google it. My best price was through eBay(around $100). Everything is fine now.
Nov 07, 2010 | Vizio VP504F 50 in. Plasma HDTV
My vizio plasma tv quit, Problem with the
Check ur power source with other devices?Yes.Than,the power supply board it dead.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Oct 23, 2010 | Vizio P50HDTV20A 50 in. Plasma HDTV
My vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
Jan 08, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio TV wont turn on after three weeks no use
My vizio recently did the same exact thing. Vizio sent an HDTV tech out to fix it and it was the power board. He put a new board in (took 15 min) and the tv works like new.
Jan 05, 2010 | Vizio L32 32 in. LCD HDTV
Plasma does stay powered on
Your sustainer board is probably bad. You need to get the Y & Z sustainer boards replace then it should be okay.
Feb 08, 2009 | Vizio VP50 10A 50 in. Plasma TV
46" LCQ VIZIO WON'T TURN ON ALL OF A SUDDED
For the 46" TV, it sounds like the main board is bad.
For the 50" Vizio: is the LED light on?
Feb 07, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Hi, I have a Vizio P50HDM
For your Zenith P42W34D TV. The problem cause the a bad Y drive board. Replace the board will fix it.
Hope this will help.
Jan 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Big POP no sound no picture
if you could see light orange or green is has power is probably teh Y and Z board
Aug 22, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
VIZIO 50" PLASMA
Wow. This is more comon than I thought. My 50" Vizio plasma just went out as will after a loud pop noise. Power button is still lit. Sound continue to come through but no picture. I will dig into it and see if I can find a appropriate solution.
Feb 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Open Questions:
Vizio P4 46 in. HD-Ready Plasma Television Logo
2,225 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
