Question about Bose Lifestyle 48 System
Video from components not shown with HDMI, works with yellow cabl
A few months ago I bought a Bose Lifestyle 48 and had this problem. I sent it to the store for warranty and supposedly it works fine now. Now that I am trying to set it up, it still doesn't work.
I have the L48 hooked up to a plasma TV using an HDMI cable. If I play a DVD on the L48, it shows fine. System menus also work fine.
I have two external devices: a Playstation 3 and a DVD/R which I use for watching cable TV.
The problem is here: If I hook up the PS3 or the DVD to the VS-2 (part of the 48) using HDMI, I get nothing. If I use the yellow video cable, everything works fine (just not hi-def).
One curious thing I just noticed is that when I set the input to the PS3 when it's connected with HDMI, the TV and the 48 don't say anything about not getting a signal. If I unplug the HDMI cable, I get a "no video signal" message in the 48 and in the TV. If I do this same thing with my DVD/R, I get the no video signal both in the TV and in the 48.
I have tested the cable (even changed it) by connecting the PS3 and DVD/R directly to the TV and they work fine.
Does anyone have any idea?
Thanks!!
Luis Alonso Ramos
SOURCE: Lifestyle 48 locked up
Just got off phone with Bose support with this very problem during install of a VS-2 software updtae to an older LS48 system. (Bose support personnel were very helpful on phone - and walked me through procedure to solve). I presume you unplugged and replugged power supply with no resolution. In that case, unplug power supply, wait 30 seconds and while holding down the "open/close button" and the "store" button (on media center) plug the power supply back in. Continue holding until the "Bose Lifestyle" message disappears. I presume this puts the system into a diagnostic mode, as the next steps in my case were to press and hold the "erase" button while scrolling through a menu of options using the "volume up" button. I believe it was the third "volume up" press that brought me to "FLASH" on the system screen. At that point I was told to release the "erase" button and press the enter button. The system rebooted and my VS-2 install went smoothly after that.
I'd recomend calling Bose support (800-905-2138) since your lockup occured during a CD load vs a software update (just to be on the safe side) - I was talking to a live tech support person in less than 15 seconds... a pleasant surprise.
Posted on Feb 05, 2008
SOURCE: Bose Lifestyle V20 Error 180
Below is solution from an earlier post, I'm trying it out now as I have the same issue, system bought in Jan 09. I have received and installed the latest update from Bose recently, now this. Will call Bose tomorrow to fix if they can't they will be getting it back.
We disabled the power cord from the back of the media console (where the HDMI cables connect) and left it off for a minute or two.
Powered the media console back on and it is working as expected.
Was told by the Bose tech that the common reason for this issue is due to the use of the HDMI cables that have a propritary security protocol that is used between the media console and the component it is attached to (ie TV, Cable/Sat, BluRay ...ect).
I asked if there was a BIOS upgrade if it was indeed a "handshaking" issue and was told there was not one (yet).
If one becomes available, it will be shipped via mail on a CD\DVD that can be used in a CD\DVD player that is connected to the media console using the HDMI cable.
Posted on Mar 10, 2009
SOURCE: open/close tray disc stuck bose Lifestyle 48
Problem:
I also have a bose Lifestyle 48, and the same problem has happen to me where the DVD player would not open,
Solution:
Unplug the unit, Wait a few seconds, after plugging the power back in, immediately hit eject so that the player does not have time to spin up and try to read the disc again
Posted on Apr 22, 2009
cjackHD
  • 71 Answers
SOURCE: Bose Lifestyle 48 System play's dvd in black & white only
Your s-video cable at the back of your media center is loose. This will cause black and white internal video and is known to fall out or just become loose from minor movement. (it's the nature of s-video cables) This should solve your problem. This is the s-video cable that connects to the VS2 and media center.
If this doesn't solve the problem (I'd be surprised), just reset it by unplugging the DC power cable at the side of the VS-2 for about 30+ seconds and plug it back in..
Posted on May 31, 2009
SOURCE: audio problems connecting ps3 to bose lifestyle 48 system
audio has to connected seperatly.vs 2 is for video connection only..Bose is a ripoff.... u pay all that money and you need a seperate audio connection plus all those wires..it isn't worth it and regret i bought it.
Posted on Dec 28, 2009
Trying to connecting my Bose lifestyle to my Samsung led smart tv to play a DVD with a yellow video cord and picture is blurry and double and has jo color? Any ideas how to fix Bose lifestyle is older...
Without the specific LifeStyle model # it's not easy to say for sure, but it sounds like you might have a composite cable plugged into a component video output of the Bose. Assuming it does not have HDMI output, it might have white/red/yellow (RCA-type jacks, aka "phono") and that yellow jack is a composite video output. It would plug into the same color jack on the TV. There are also RGB (Red/Green/Blue) component outputs on many devices and similar inputs on the TV, so you have to match like color out to same color in and make sure the TV is set to composite video input, not HDMI nor component.
Also could just be a bad cable. It's always the cheap things that we overlook, so with the same output/input setup, assuming you match type, try a different cable. The actual color of the end on the cable does not matter, but don't plug a yellow-colored output jack to a red, white, blue or green input jack on the TV - that won't work.
Feb 18, 2015 | Samsung Televison & Video
Tip
Bose LifeStyle 48 Video Mode
Bose LifeStyle 48 System Video Mode Change
Follow these steps to change the video setting from European to North American:
With the media center turned off, use the controls on its front panel to follow these steps:
  1. Press and hold the Enter button on the media center.
  2. While holding the Enter button down, press the Store button. Selections will appear on the media center display each time you press Store.
  3. When Video appears as the selection on the display, release the Store and Enter buttons.
  4. Use the Volume up and down buttons to scroll through the Video options.
  5. Stop scrolling at the proper selection:
  • For a component connection only, select:
  • -NTSC COMPONENT (in N. America)
  • -PAL COMPONENT (outside North America)
  • For a component connection and progressive scan, select NTSC PROGRESSIVE.
6. With the proper selection made, press Store to confirm the
selection and leave the Video options.
I hope that helps.
_______________________________________
Bose LifeStyle 48 Manual Download
Reset Bose LifeStyle 48 VChip Password
on May 02, 2010 | Bose Lifestyle 48 System
No video at all!
I recommend you switch from using HDMI cables to using component (R/G/B RCA-style) cables. HD picture is superior through component cabling, and solves several HD picture issues, including HDCP (High Def Copy Protection) through HDMI issue. Component cabling should eliminate this problem.
I hope that helps.
___________________________________________
Download Bose LifeStyle V30 User Manual
May 31, 2010 | Bose Lifestyle V30 Home Theater System -...
I have installed the v30 bose lifestyle system but I can not get any video output on my Samsung led tv. I have tried the hdmi cable and the component cable. It both doesn't work.please help me with this
I recommend you stick with component cabling.
Having no picture at all generally suggests the V30 is trying a video mode your TV does not support:
  1. video type (PAL or NTSC)
  2. Progressive scan
  3. an HD resolution beyond your TV's range.
I hope that helps.
May 21, 2010 | Bose Lifestyle 30 System
A ps3 and tried hooking it up with hdmi to the 'vcr' connection on the vs-2 of the bose Lifestyle 48 but i don't get any audio (video is fine). hooked up the ps3 with hdmi directly to the tv and get both...
hook up computer straight to t.v with hdmi cable. then get two aux cables (usually red and white) and run them straight from tv audio OUTPUT to audio INPUT on bose system. them anytime you want surround sound even when your watching tv just press the aux button on the bose system controller. should be perfect.
Dec 27, 2009 | Bose Lifestyle 48 Series IV DVD Home...
Connect lifestyle 48 to plasma and dvr
You need to buy a Bose VS 2, video enhancer. Your cable/sattelite, vcr and aux connect to the VS 2 and the VS2 connects one HDMI cable to the TV. The VS2 then upconverts DVDs played on the lifestyle through the VS2/HDMI.
Sep 10, 2009 | Bose Lifestyle 48 System
Hello, i have a vizio flat screen tv and i don't know the correct places to connect the cables of my Bose Lifestyle 48 Series IV DVD Home Entertainment System. Please help me
Does the Bose have HDMI out? Does the tv have an HDMI socket?
If it does just connect them both together. All inputs i.e. cd, ps3 dvd etc will go into the Bose.
Aug 09, 2009 | Bose Lifestyle 48 Series IV DVD Home...
Audio problems connecting ps3 to bose lifestyle 48 system
Jun 14, 2009 | Bose Lifestyle 48 Series III System
Hello,I have a Bose Lifestyle
If you use both s-video and composite (yellow) video at the same time on the bose system, it thinks you want to use the component adapter (which is included with the system). Just use one or the other. But if this is still in black and white (it may because the system still thinks you're using the adapter) just press "system" on the bose remote, and go to "video" and then "video connector" If video connector says "Component", try to change this to "composite + s". If this doesn't let you change it (it may not) then restart the system by unplugging the DC power cable for 30 seconds and re-connect it. I hope this helps.
Jun 01, 2009 | Bose Lifestyle 48 System
Lifestyle 38 and HD
I have also have this problem with a lifestyle 28 system. Bose sent me a new cable then a software update. The problem remained, after contacting Bose and unplugging cables and powering down the system this solved the problem. However 2 days after and the problem has re-appeared. Back to square one. I should add that this is the second unit I have had the retailer exchanged the last one because of the same problem.
Apr 08, 2008 | Bose Lifestyle 28 System
Bose Lifestyle 48 System Logo
101 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
