Sony LF-X1 12.1" LocationFree TV Television Logo
A
Anonymous Posted on Sep 27, 2013
Touchscreen calibration The touchscreen works inconsistently, and sometimes the wrong numbers come up.
Bernina 830 : How to calibrate the touchscreen through service menu ?
To access the service menu on your Bernina 830, you can follow these steps:
  1. Turn off the machine and unplug it from the power source.
  2. Hold down the Reverse and Needle Down buttons, then plug the machine back in while holding these buttons.
  3. Continue to hold down the Reverse and Needle Down buttons until the service menu appears on the screen.
From here, you should be able to navigate the service menu using the arrow keys on your machine. To access the calibration option, you will need to select the "Touch Test" option from the menu.
Unfortunately, without a working touchscreen, it may be difficult to navigate the service menu. One option may be to try using an external USB keyboard, as you suggested. However, this may not be compatible with the Bernina 830, so it's not guaranteed to work.
If you're unable to access the service menu or calibrate the touchscreen, it's possible that there may be a hardware issue with the machine that needs to be addressed by a professional technician.
When pressing letters wrong one show up zumo 550
Have you tried recalibrating the touchscreen?
To calibrate the screen of the Zumo 550, press and hold the power button for about a minute until the screen calibration appears.
Sep 21, 2013 • GPS
2answers
Touchscreen on a Garmin nuvi 1350 doesn't work
My touchscreen on Garmin nuvi 1390 not working too and .calibration it's help alsoI did twice hard reset my GPS Garmin Nuvi 1390 and nothing happening and after I tried different trick,when I turned GPS off I hold the top left corner screen.The screen exchange for calibrations and I pressed several times according request and my GPS Garmin Nuvi 1390 started work,but repairing company wanna charge me $100 Canadian dollars.I didn't connect GPS to computer
Hi i have a Nokia xpress music and it out side bottom get locked i mean the two bottom in the sreen of contacts and the numbers bar it wont work
Try to calibrate your touchscreen response by going to SETTINGS>PHONE SETTINGS>DISPLAY SETTINGS>CALIBRATION..
1helpful
Does not work on the edges, can not access start by touching. when the screen is touched the arrow appears about half an inch away
Sounds like the calibration for the touchscreen needs to be reset. If you check in the control panel, there should be a ELO shortcut that allows you to calibrate/test the touchscreen. Try running through the calibration and see if the touchscreen behavior improves. If the calibration doesn't fix it, then you may have an issue with the touchscreen itself.
1helpful
My harmony touchscreen remote is working intermittently. sometimes taking out the batter works but it is not working now.
try recalibrating the lcd. to do this, please follow the steps below:
One can incorrectly calibrate the remote by pressing areas on LCD other than the ones marked during the calibration process.
Solution
To re-calibrate a remote which has been incorrectly calibrated, please follow these steps:
  1. Put the remote in safe mode.
    1. Remove the battery
    2. Hold down the System Off button on the remote while inserting the battery back into the remote
    3. Continue to hold the System Off button until the remotes LCD has lit up and reads Safe Mode
    4. Let go of the power button
  2. Reboot the Remote
    1. Remove the battery once more
    2. Re-insert the battery
  3. Follow the calibration wizard on the Remote to re-calibrate it by pressing on the areas indicated.
1helpful
Palm TX power button and touchscreen
We have three TX's in our family with non-working power buttons. I downloaded the program Au Dodo http://www.freewarepalm.com/utilities/audodo.shtml and simply now use the far left button (button 1) as my 'power' button. It works wonderfully.
I haven't found out how to fix the calibration problem, but power on/off has been totally fixed. Good luck for you.
3answers
Touchscreen
try calibrating the unit
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
