Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Kenmore 52552100 staying too cold
I have a kenmore 52552100 side by side refrigerator. Even with the fridge side setting on as low as possible, our food and drinks are still ending up frozen (milk, eggs, O.J., lettuce...). We think it may be the thermostat but are not sure how or where to get one, or how to go about replacing it.
Thanks
    Master:
  • Kenmore Master
  • 753 Answers
Replace the cold control
Posted on Jan 01, 2018
SOURCE:
bobotfel
  • 241 Answers
SOURCE: Thermostat (1) Assembly defrost, (2) damper, (3)Thermostat???
If it is digital control its either the thermistor or the control itself, if it is manual then the problem is the thermostat.
Posted on Feb 05, 2008
Coldcut
  • 1554 Answers
SOURCE: Fridge not cooling
evidently the fan that runs in the freezer and blows air into the main fridge has a circuit issue or the fan is frozen, but if the bulb does not work then its a circuit issue. likely on the same circuit as fan.
Posted on Mar 20, 2008
docjohn174
  • 943 Answers
SOURCE: freezing problem
HI thanks for your question. try turning the thermostat to a lower, number. and clean all the coils at the back by the compressor. it might be all you have to do/ thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 12, 2008
  • 117 Answers
SOURCE: I have a Kenmore coldspot side by side- not cooling properly
Setting it to 5 is what the manufacturer recommends. If you set it to 1 and the frig is still not cold, then you probably have a faulty cold control (thermostat)
http://tclaundryrepair.com/home
Posted on Feb 19, 2009
  • 145 Answers
SOURCE: My Kenmore Elite refrigerator keeps freezing the food!
Replace your thermostat and will work like new again
Posted on Jun 07, 2009
My Kenmore side by side is fine, except for freezing everything in the crisper drawers.
The coldest place in your fridge is in the crisper drawers, manufactures know this and they even put heaters under the floor of your fridge to try to heat it up a bit in there, if you set your freezer temperture to low there will be less cold air current that flows into your fridge but it will flow in over a longer period of time, that air is about -22C so it will be blowing on your items in your crisper for a long time and it will probably freeze them, all very confusing and complicated but it may help to turn your controles for your freezer to a warmer setting, on the other hand if you only open your fridge a few times a day the cold air being denser will settle in the bottom of the fridge and freeze the crisper area, not much you can do about this, except eat more food... :-)
Aug 26, 2011 | Kenmore Side by Side Refrigerator
Not getting the cold it needed
Hi, both compartment of the refrigerator (freezer & fridge) not freezing and getting cold means you have low or empty freon (gas) in the compressor of the refrigerator and you need to refill it as soon as possible.
Take care
Jul 14, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer staying cold, fridge is not
You need to replace the refrigerator evaporator fan motor assembly.
Apr 16, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer door on GE side by side stays open slightly at top
i have kenmore side by side model 52552100 and the ice maker will not send ice thru the door. I is not even making any sounds when I push the button dispense. Can you duplicate this problem
Apr 10, 2009 | GE GSH25JFR Side by Side Refrigerator
Refrigerator too cold
Sounds like the damper door that regulates airflow from the freezer into the fridge is staying wide open. The cause could be a bad thermostat or a failed damper motor, but it could also just be ice jamming the mechanism. That could have happened after a two-day opportunity to melt and re-freeze, so let's try a cheap troubleshooting method first.
Look in the fridge for the plastic grill where air comes from the freezer into the fridge - probably down low on the partition wall. Aim a hair dryer, on a medium heat setting, into the grill for a minute or so and see if that helps. There's a fan in there, so don't go poking your fingers in unless you unplug the fridge first.
If this doesn't help, then you may have a failed component in the damper door assembly, or possibly a bad thermostat. Good luck with this, and I'm glad your power is back on!
Feb 02, 2009 | Kenmore 53642 / 53644 Side by Side...
Fridge not cooling down stays at 68 degrees
you may be low on freon..thats one thing about fridges if you are low one side will still stay cold while the other side gets warm
Jan 12, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Fridge does not stay cold
If the compressor is running continually, could be short of gas , or a compressor problem, ie not pumping properly,make sure it has plenty of ventilation
Dec 06, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore fridge not cold
You might have to have a repairman check the charge of freon in the system.
Nov 27, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
247 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
Jimmy
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
