Question about Ovens
Westinghouse Freestyle 668 oven not doing anything , just blinkin
Have Westinghouse Freesatyle 668 electric oven or very similar ;(http://www.westinghouse.com.au/product/display/model/POH668S)
Had to remove it for Kitchen Reno and replace. Now when plugged in it just blinks Auto / 00.00 in the little timer window. No combination of button pressing or oven functions will do anything to make the light stop blinking or to turn the oven on. Anyone had this problem before ? Not even the oven light will work now , yet there is definitely power to the oven ! Thanks, Matt.
  • s0107381 May 07, 2009
    I have the exact same problem. I've just moved into a house and oven does the same thing. Any help would be much appreciated...
Yes I can help.Hold down the buttoms on the far left at the same and then set the time using the + and - buttons.Cheers
Posted on Jan 17, 2010
  • Em Cho Jan 25, 2012
    Thank you so much. I used to randomly press a combination of buttons until I could set the time. Now I know the correct combination (pressing the far left 2 buttons at the same time).
My Westinghouse 668 wall oven won't allow me to set the time. We had a power outage and I have checked the power and it's fine now. But the display flashes between 0:00 and auto and I can't hold the two...
Does the rest of the oven work ok? Did the timer work OK before the outage? Is the oven under warranty? Was the power outage at your home only? Check with the manual to see if it addresses your problem, there may be a way to reset the system and then I would say that you would need to contact Westinghouse and explain the situation.
Nov 06, 2014 | Ovens
I have a Westinghouse 668 Freestyle Multifunction oven. We lost electricity and when we got it again the digital timer is blinking from 0.00 to AUTO. How do I reset? It won't work otherwise.
Another Fixya member, skillful79, says you should hold down the two buttons on the left side at the same time, then set the time using the + and - buttons.
Mar 08, 2011 | Ovens
My Westinghouse 668 oven turned off in a recent power failure. I need to reset the time so the oven will work. How do I do it?
A lot of the time, particularly if you haven't got a manual, it is trial and error. I normally turn the oven to on. I then watch the oven indicator light as I manipulate the timer buttons/controls. It sometimes takes 5 to 10 minutes. Just try all different combinations.
Feb 12, 2011 | Ovens
Hi there, I've got a westinghouse freestyle 521 glass stove top and fan forced oven. Just recently when in use the oven stopped working, although the light and fan remained on. Is there anything like a...
Sorry to read about your problem, I hope this helps you out.
sorry their is no simple fuse for what you are writing about, you may just have defective heat elements.or open thermal switches. and they are not easy to check
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 30, 2010 | Ovens
Hi i am looking for a manual for my wall oven its a Westinghouse wall oven POPS668S
Here is a direct link to download your manual (free). This manual covers several similar models including yours:
http://manuals.appliancesonline.com.au/westinghouse-electric-wall-ovens/westinghouse_electric_wall_ovens_manual.pdf
Click the link and the file will open and you can then view, save and/or print the manual. You need adobe reader to view the file which can be downloaded here if the file doesn't open:
http://www.adobe.com
Please rate this solution if you find it helpful. Thanks.
Oct 17, 2010 | Ovens
I have a Westinghouse 678 freestyle.the element remains on. It may be due to the setting of the clock or timer. i do not have a manual to regulate either as this was not left by the previous owner. could...
I also have the same oven, it turns itself on at random at heats up, also is the oven door easy to remove for cleaning, I dont have a manual either
Jun 29, 2010 | Ovens
Need an instruction manual for Westinghouse freestyle 745 wall oven, preferably in PDF, having trouble setting the clock. Can you help please?
instructions-manuals.com/search.php?...WESTINGHOUSE%20FREESTYLE...FREESTYLE%20920%20DISHWASHER
safemanuals.com/index_upload.php
www.manualsnguides.com/search.php?...WESTINGHOUSE%20FREESTYLE......
You can copy and paste any of the above links in your internet address bar under a new tab to bring you to your manual
Nov 12, 2009 | Ovens
I have a Westinghouse Freestyle, fan forced oven Model NO 688.
I need a manufacturer name and model number
May 15, 2009 | Ovens
Westinghouse Freestyle 476 Cooktop Oven
After getting an electrician out, apparently the time needs to be set on the oven. As we're in a rental & don't have a manual/ couldn't download one, we got it to work after holding the first two buttons in (the timer buton + the one that looks like a hot pot) along with the + button at the far right, which made the tim tick on, so it could be set.
The oven works now! : )
Aug 20, 2008 | Ovens
Ovens Logo
3,610 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
