Question about Mitsubishi VS-45607 45" Rear Projection Television
Mitsubishi vs45607 dead
When I press power only a click,and nothing more thank.
  • albert einstein Nov 12, 2007
    vs-45607 is dead, will not start. I checks H. output trans. and they ok, rect also ok. Flyback is also fine. I know the circuit is shutting down and i'm missing something. Any suggestion.. SF. Fl
  • BValde Nov 27, 2007
    I'm having a couple problems with my vs45607. The fist problem was with the antenna A hookup. I'd turn on the TV and all I had was snow. I switched it over to the antenna B hookup and it worked fine.
    Second problem; I have the tv plugged into a power strip. When I turn the power strip on the green timer light in the front flashes 3 or 4 times. Then when to hit the power button, the light goes on and off with a click and that's it. Any sugguestions would greatly be appreciated.
FixYa - your website fucking sucks!!!
Posted on Dec 30, 2007
    Problem Solver:
Service manual at eserviceinfo.com
In RAR compression from Europe  Has all the convergence setups etc and presets
4 MG PDF
Posted on Oct 11, 2007
    Genius:
  • 1,139 Answers
This denotes a problem in the HV power supply and the shutdown circuit shutting down the Tv to prevent damage from a component that is drawing too much current. I would suggest that you have a repair person look at your TV and give you an estimate.
Posted on Sep 21, 2007
Mitsubishi VS45607 tv
Brief an d to the source. A high voltage speed switch is bad and we will cross reference it with an NTE 2361. But this is only the start. You can crossreference all of the transistors. Q531,Q532,Q533 Q530 , Q5ADO [Horizontal output transistor] and Q5A02 Looks like Q502 on board [also i think this is also an horizontal output transistor. Then by all means change the following capsC541, C551, C531, C562, C534, C402, an d C933 . It will take some time to do this, be patient my friend. Your Mishis will return!
Jun 13, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Light defusion filter for vs45603
Yes the 45603 and 45607 will interchange screen component not electronic parts but screen assemblies are the same
May 12, 2008 | Mitsubishi VS-45607 45" Rear Projection...
un plug the set and use a flashlight and look for evidence of the CRts leaking on the chassis this is a common fault with that model. It will cause a dead set.
Apr 23, 2008 | Televison & Video
Vs45607
yes the regulator has to be solderd into the circuit board.
Feb 14, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Check for leaky D980 PART # 264P045040. You also can try to do a self test to get the error codes, search here or on ctechnicians.com
Jan 02, 2008 | Mitsubishi VS-45603 45" Rear Projection...
Mitsubishi Power Problem -turns itself off.
Sounds like CRT coolant leak onto signal board = check
for work....................................................T.
Nov 10, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Just plain dead
unplug keybord and try to turn on with remote.
Sep 23, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi vs-5052 tv
as you are not electronic person so call skilled person. problem is simple. 1 there might be in power supply. 2 if power supply is ok horizontal section might be defective
Sep 16, 2007 | Mitsubishi WS-65615 65" TV
CS- 40503 No Power
There is no external reset, and if the set is completely dead (not even a click when the power button is pressed) then there is probably an open main fuse or defective stand-by power supply. If the main fuse is blown then there is usually a heavy short in the main power supply, and either way the set should be looked at by someone with experience in Mitsubishi sets.
Jul 04, 2007 | Mitsubishi CS-40503 TV
Mitsubishi VS-45607 45" Rear Projection Television Logo
179 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
