Question about Weber Q Grill
Weber q 200 all of a sudden won't ignite- just clicks away
  • 25 Answers
Most ignitors work of a battery which makes it spark. find the battery and replace it
Posted on Apr 26, 2009
Weber grand cafe heat
Some tips here
Weber com Support Help Grilling Tips
You can ask them for manual
Weber com Support Manuals
Some tips for smpking
Top Ten Tips for Smoking
The Best Setup for a Weber Smokey Mountain Barbecue Smoker and Other Bullet Shaped Charcoal Smokers
amazingribs com
Watch this video
Weber Grills Smoking on Your Smoker
May 24, 2015 | Weber Grilling
Why won't my Weber grill ignite after installing a
Disclaimer- be careful when working with gas. Starters in gas grills are just about novelty anymore. Often, they only light 1/3rd or 1/4th of the burners and they usually stop working within one grilling season. I recommend using a wand lighter. Try to light just one burner but if doesn't light in 5 to 7 seconds, turn the gas off and wait to try again. Incidentally, you are turning the gas on at the tank, right? You should hear it when you turn the burner on.
Apr 24, 2012 | Grilling
Infared burners ignitor won't work
Mike, have you replaced the battery in the igniter button ye? That's the first place to start troubleshooting. Be sure you install the new battery facing the same direction as the old battery. Also, check the interior contacts of the battery holder for corrosion. If you find any, use a Q-Tip sprayed with a little WD40 to clean it.
If the above doesn't solve the problem, trace the igniter wire from the igniter button to the spark igniter at the burner for damaged wire or a loose connection.
And finally, try match lighting the infrared burners to make sure that they are getting an adequate flow of gas.
Hope this helped you t troubleshoot and solve the problem. Happy Grilling and thanks for choosing FixYa.
Aug 24, 2011 | Weber-Stephen Products Weber Summit...
My weber grill won't heat up beyond 200 degrees - why>
Your problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101 ,,./,./
May 28, 2011 | Weber Genesis Silver B Grill
We purchased a new Weber Q 200 grill and there was no instruction manual with it. How do we go about getting one?
Actually, it's fairly simple, Nancy. Just click on the link below and you can download and print the Owners Manual for your grill. Happy Grilling!!
http://help.weber.com/manuals/pdf_files_2011/Gas/Weber%20Q/Q100120200220_OwnersGuide_41061_020708.pdf
Apr 20, 2011 | Weber Q Grill
Can i get a replacement switch for the ignition weber 200 switch will not ignite the gas there is no spark coming from the switch
First, you want to make sure the end of the piezoelectric switch is close to enough to something metal to spark. Maybe it got displaced when you cleaned the bbq?
If it is close enough to arc, but doesn't spark, you can replace the switch with this kit here:
http://www.grillparts.com/weber/Q200.asp?product_id=QSPARK
Good luck, and if this helped, please rate my response! Thanks!
Mar 22, 2011 | Weber Q200
In June I bought a new Weber grill but the auto ignitor does not work--there is no click--therefore no spark. I can light the grill manually.
If there is no click, it is most likely the igniter module is bad. The igniter module should be available at any Home Depot or Lowe's; in any case, your owner's manual will show you how to remove and replace the igniter module. If you don't have the owner's manual, I will include a link to one online; you will need Adobe to open it. Here is the link: http://www.bbq.us.com/images_templ/weber-manual-3741001.pdf
Try this and if it doesn't fix your problem, come back and let me know and we will troubleshoot further. Good luck!
Nov 16, 2009 | Weber Spirit? E-310 Propane Grill
The igniter does not work. i changed the battery. it used to click when pressed down and pop up. now it does not. i do see that the spring is still in the unit.
I had horrible luck with my Weber igniter. They just don't seem to last. I replaced mine two or three times in the 10 years I had my grill, then finally gave up and started using a lighter. So, try replacing it with a Weber part, or one of the universal igniters at your favorite home improvement store.
Jul 25, 2009 | Weber Genesis Silver B Grill
Weber gas grill will not ignite
you will probably have to get a new igniter or try to adjust the one you have. there is a little electrode on the igniter that needs to be clean and a certain distance away to work properly.
May 26, 2009 | Weber Q Grill
Weber Q Grill Logo
1,205 people viewed this question
Top Weber Grilling Experts
paulcarew
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Weber Grilling Expert? Answer questions, earn points and help others
