Computer died. Need to do data recovery of SATA hard disk.
My wife has a Compaq Presario SR1151NX, 160GB SATA Hard drive, 512MB RAM, Intel Pentium 4 processor 3.4 GHz, Motherboard ASUS PTGD1-LA. Her computer died (does not turn on at all). It seems like the motherboard or the processor stopped working. I like to back her data from her SATA hard disk to my computer (Dell Optiplex GX-270) which has an EIDE drive. I'm not sure how to do this. I'm pretty good with computers (it is a hobby of mine). My wife has very important files in that SATA hard disk and cannot afford to lose it. Any help will be greatly appreciated it. Thanks in advance. Edward Nino
  • 447 Answers
Hey Edward,
Use a SATA external hard drive enclosure (listings for the device on ebay) to connect the disc to a USB port on your other machine and transfer any data off of it.
You can find these devices locally also but you can pick them up on ebay pretty cheap.
Posted on Apr 20, 2009
Open site ZCRACK.COM. Type stellat in search box than u found complete software of stellar phonix 2.0 or 2.1 download.remember this utility is windowx xp or higher based.
use it if any problem than contact me.
My Mail ID :-Prashantasus@gmail.com
mail your email address I'll mail You this utility
bye
Posted on May 25, 2009
  • 107 Answers
You can open her comp and remove her hard drive...on the back where the wires connect will be 8 pins hopefully with a jumper attached to 2 pins...on the top of the drive should be a diagram as to which pins need to be connected to change it from being a "master" to a "slave"....keep the original HD in your comp as the master and install her drive in your comp set to slave...you may have to get another ribbon cable to hook to her drive if there isnt 2 connectors coming off yours ...it should have 2 though also there should be an extra power supply connector there...when you open up "My computer" it will show that you now have 2 hard drives and you can access all the info on it.....just make sure to keep your HD as the master cause it has all your operating system data on it..
it really isnt as hard as it may sound
lemme know if you run into any problems
Need recovery disk
Set BIOS hard drive parameters to AHCI or if already there, toggle to ATA
May 02, 2014 | HEWLETT-PACKARD Hewlett Packard HP Compaq...
How much is my computer worth
Based on brand new parts:
500GB SATA - $56
160GB SATA - $45
4GB RAM - $112
V-card - $105
CPU (Proc., Mobo, P/S, reader) - approx. $107
Your rig can be sold at around $425 - $450 approximately.
Hope this helps.
I had assembled a Quadcore system at around $750.
Mar 20, 2010 | Computers & Internet
My 40 GB hard disk got crashed for KOB 810e FST Mother board. can i use new 80G or 160 GB hard disk. does my mother board supports 80 GB or 160GB hard disk. I have 256 MB of RAM. can i upgrade it to...
Yes, any motherboard that supports "larger-than-32GB" disk-drives should support larger disk-drives.
Yes, most motherboards support up to 512MB per stick of RAM.
Jan 02, 2010 | Intel Computers & Internet
How much i can upgrade my d530 ultra slim desktop RAM and HDD
You can install up to a max 2 GB RAM and can add a 2nd hard disk
See the following Specs for your computer.
dotclear.gif HP Compaq Business d530 Ultra-Slim (Pentium 4 2.8GHz, 256MB RAM, 40GB HDD, XP Pro) Type Personal computer
  • Product Form Factor Ultra-slim desktop
  • Built-in Devices Speaker
  • Width 12.4 in
  • Depth 13.1 in
  • Height 2.8 in
  • Weight 15.4 lbs
  • Color Silver
Processor
  • Type Intel Pentium 4 2.8 GHz
  • Installed Qty 1.0
  • Max processors supported 1.0
Cache Memory
  • Type L2 cache
  • Installed Size 512.0 KB
  • Cache Per Processor 512 KB
Mainboard
  • Chipset type Intel 865G
  • Data bus speed 533.0 MHz
RAM
  • Installed Size 256.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM
  • Memory Speed 333.0 MHz
  • Memory Specification Compliance PC2700
  • Form Factor DIMM 184-pin
  • Upgrade Rule Max 2 x 1 GB module
Storage Controller
  • Type 1.0 x IDE - Integrated - PCI
  • Controller interface type ATA-100
Storage Controller (2nd)
  • Type 1 x Serial ATA - Integrated
  • (2nd) storage controller interface type Serial ATA-150
Storage
  • Floppy drive type None
  • Hard Drive 1.0 x 40.0 GB - Standard - ATA-100 - 7200.0 rpm
  • Hard Drive (2nd) None x None
Dec 08, 2009 | HP Compaq Business d530 Ultra-Slim PC...
Reagarding some Hard disk
You system probably supports IDE hard disks up to 200GB in size. It all depends on what chipset was used on your motherboard. Since it is a PIII system, the 200GB limit is most likely quite solid. Although, you can get past this by installing a PCI card that can handle larger capacity drives. You could also opt for using a SATA controller, but you will be limited to SATA-150 instead of the more current SATA-300 with a PCI interface.
Jun 07, 2009 | Intel P4 System Configurator (P4SDRAM1) PC...
No display on computer
First thing is do you have a beep when the system boots? Sounds like you may have a BIOS issue I would start there........your RAM and processor are more than likely NOT the problem
Apr 15, 2009 | HP Pavillion a818n Desktop PC (Refurb)...
IBM ThinkPad T20, Intel Pentium III 700MHz Upgrade to Pentium 4?
Max CPU for IBM T20, 21, 22 is Pentium III FCPGA2 1000MHz (1GHz). Max memory is 512MB (2 x 256MB PC100/100MHz). Max hard disc is 250GB ATA. Newest BIOS is from April 2004 at the homepage Lenovo.
Nov 06, 2008 | IBM ThinkPad T20 2647 Notebook
Vista Ultimate
need at least 2 gig of ram and 160 gig hard drive to run vista
May 29, 2008 | Microsoft Windows Vista Ultimate Edition
Seagate 160GB SATA Hard Drive Installation.
Hi, Was the original 20Gb HD also a SATA or was it installed as an IDE? Try installing a fresh clean Windows rather than the restore disc. However, you will need the drivers for the SATA 160Gb and press F6 when Windows installers ask you to. Post back how things turn up or should you need further information. Hope this be of some idea/help. Good luck and kind regards.
Sep 08, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
Computers & Internet Logo
505 people viewed this question
David Payne
David Payne
