Question about Sony Playstation 3 (PS3) Console
My ps3 dont start
When i turn on my ps3 it makes 3 beeps an the red light start blinking. What should i do?
  • 344 Answers
Re: my ps3 dont start
It is believed that what you have is a general hardware failure. Like the 3 red lights on Xbox 360. Best thing to do is call Sony. Good luck.
Posted on Nov 10, 2007
3 Suggested Answers
  • 709 Answers
SOURCE: Turning PS3 on problems
You and most all PS3 owners have or will experience this problem. Your Heat Transfer compound is dried up. This to me is a definite Manufacturer Defect. Contact Sony at 1800 345-7669 unless your outside North America. If you know how to get to the heat sinks, I suggest you go there and put some new high quality Heat Transfer compound between your processors and the heat sinks.
Also check your Ribbon cable connections, as I did se where one PS3 owner found his Ribbon cable fromt he Card readers miss inserted. He orrectly inserted it and he was up and running. Now you do need to contact and Get Sony to fix this if you have the required credentials. Do not waste your warranty.
Posted on Nov 07, 2007
  • 172 Answers
SOURCE: PS3 Wont Turn On
Hi my name is Juan and I do fix and sell playstations3's so I do know your problem better than any body here the main problem you have is similar to the xbox360 red ring of dead so for now your ps3 is dead no way to turn it on but we have a fix for this problem the only bad part of this is that is done with a special system that is controlled by computer so not every one can do this like the xbox360 ps3 is more complicated in order to get your system up and running we need to have the motherboard or the completed ps3 to reflow the graphics chip some of the connections under the chip are not making good contact and this problem was cause by excessive heat so your ps3 needs to be open and the motherboard needs reflow and new thermal compound to dissipated the heat better there is some guys on ebay they do this type of job there I only sale parts and ps3's on ebay I don't offer this service on ebay but I do have the system to do it so if you like to see your system running again let me know I am located in Georgia.
Posted on Jun 10, 2009
  • 178 Answers
SOURCE: My ps3 shut off secs after i turn it on red light blinks n beeps
If the motherboard is defective, go to the store where you bougt your ps3 if you're still having warrantyon your ps3 else test if it is realy the main board that is defective, if so you're able to vind a new main board here, note that 60GB board is difrent from the one that is placed in 40 gb version and the 80 gb and slim are also different, each generation ps3 has a diferent board.
Als watch out for eurean versions of the board's they are also difrent from the ones from other regions.
Here is where they have a new board for sale:
Posted on Aug 28, 2009
Testimonial: "Thanks for the info,i really appreciate it especially getting a fast response."
0 characters
3 Points
I turned my ps3 on today and the light turned green, then amber and red and the system beeps three times. the red light then just keeps flashing. When i tap it while its blinking it stops but when i do...
i have the same problem but to make matters worse mine wont even turn on now but a bunch of people say you have to take it to sony or i dont know if this works but a bunch of people say is does try turning it on or off (i dont know which one) and press the eject and front power button at the same time hope this works tell me if it does
May 07, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 turns on than turns off with flashing red light
If it turns off randomly and blinks red and beeps, then it's an overheating problem.
If it turns off as soon as you turn it on and blinks red and beeps, then it's an overheating problem that is getting close to being a YloD.
If there is a yellow light mixed in with #2, then you have the Yellow Light of Death which kills your console. If this happens, repost on here saying you have the YLoD.
If the problem is #1 or 2, then leave the Ps3 off for a day and move it away from carpet and anything that makes heat. Also make sure it is atleast 4 inches away from EVERYTHING.
Feb 15, 2010 | Sony Playstation 3 (PS3) Console
Ps3 had red screen error, replaced hd and updated, still has red screen error. when i try to turn it off it beeps 3 times and the green light blinks constantly doesnt shut off.
These articles could help fix your PS3 again.
<a href="">PS3 Red Flashing Light</a>
<a href="">PS3 Red Light Fix</a>
<a href=",-You-Really-Need-to-Read-This&id=3512063">PS3 Blinking Red Light Problem</a>
<a href="">PS3 Red Light OF Death</a>
<a href="!&id=3676847">Playstation 3 Repair Guide</a>
Feb 10, 2010 | Sony Playstation 3 (PS3) Console
My ps3 wont turn on
HI, the power supply is unstable or weak. you will need to replace this failing power supply soon. it is damaged.
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
PS3 not working
Good News! PS3 got red light blinking and beeps can be fixed by yourself! With the all-in-one PS3 Repair Package - You will learn the techniques and knowledges to repair your PS3 including motherboard problem, hard disk problem, blu-ray drive errors and much more. Get one copy and secure your PS3 now.
Feb 21, 2009 | Sony Playstation 3 (PS3) Console
My playstation 3 wont turn on. the red light blinks then it blinks yellow makes a beep and turns off.
3 beeps of death?
bad problem!
open your Ps3 and resolder the GPU and CPU with an Hot air gun...but you have to be carrefully!
try this and bring your Ps3 to Life again!
Good Luck!
Dec 05, 2008 | Sony Playstation 3 (PS3) Console
Ps3 wont start up
how long have you had the ps3 i think mine crashed or fried
Oct 26, 2008 | Sony Playstation 3 (PS3) Console
Red light blinks after beep
I look all over the net but could't find anything, until i found a site that said they
could show me how to fix any problem with my ps3. At first i was not so
sure about ordering the manual but i did, whats $5 plus i used paypal, but
long story short i fix my ps3, i recomend this site
i hope this help you like it help me.
Jan 19, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
894 people viewed this question
Top Sony Video Game Consoles Experts
Troy Gorman
Troy Gorman
Are you a Sony Video Game Console Expert? Answer questions, earn points and help others
