Question about Singer Sewing Machines
Feeding teeth on machine
How do i disengage the feeding teeth on my sewing machine? Apparently this may bethe reason its pulling the fabric underneath.
  • radcal May 11, 2010
    You need to give us a model number. Most common in modern machines is a small lever on the back side of the free arm. Lay the palm of your right hand on the free arm and wrap your fingers around the back side. Slide your hand from side to side and you should feel the lever, if your machine has one. Some of the entry level machines only have the ability to do free motion by covering the teeth with a plastic cover that snaps into holes in the needle plate.
    Post your model number and someone will probably know for sure how to disable the teeth.
    Problem Solver:
  • 6 Answers
There is either a "darning" option knob on machine, lower right hand, or a metal rod on top right that you use to lower the feeddogs.
Posted on Apr 26, 2009
The feeder isnt feeding the fabric through
The length has to be above zero. Insure the bobbin wind is off.
Aug 02, 2016 | Husqvarna Huskystar 207 Sewing Machine
Why is the fabric not feeding forward when stitching
on the front of the machine there is a lever/knob that sets the stitch size
if it is in the middle position ,the teeth will just go up and down and not back and forward
check that setting
it is used to seal of the threads when starting to sew and when finishing
start the sew for about 1/2" then reverse the feed then go forward again to complete the sewing
at the end of the sew do the same thing again before cutting the threads
this locks the threads as a knot so that the seam will not come undone
Sep 27, 2015 | Sewing Machines
Fabric does not feed through machine
When you sew the machine must be set at the correct settings. If your machine won't straight stitch, turn it off at the power point and then turn it back on. Most machines reset to the default straight stitch setting. Secondly when you sew the presser foot must be down. This engages the "feed dogs" or the triangular looking "teeth" below the presser foot. As you sew, the feed dogs grab the two layers of fabric pulling them through, the thread above (spool) and the thread below (bobbin) meet to form the stitch. Finally, maybe fiddling around with dials and settings you may have dropped, or disengaged the feed dogs. Check with your manual on how to re-engage the feed dogs. Hope this helps and happy sewing. Remember, when all else fails..... read the manual.
Mar 11, 2015 | Brother XL-5700 Mechanical Sewing Machine
How do i get the material to feed through
depending on the brand of sewing machine you have, make sure it's not in the darn mode,, make sure the presser foot is against the fabric so the feed dogs can pull it thru,,if the presser foot is against the fabric correctly then the feed dogs may need to be check to see if they need a adjustment or replacing
Dec 02, 2014 | Sewing Machines
Fabric not feeding
Check for jams on the bottom feed, if you do have a jam that could be why it's going slow. Or you may be using to thick of fabric.
Sep 20, 2012 | Sewing Machines
Feeding device (with "teeth") does not come up
Reengage the feed dogs by pushing the feed dog button AND manually turning the flywheel towards you through one stitch sequence, you should see them moving back above the needle plate after a stitch has been made.
Oct 10, 2011 | Husqvarna Viking 1
There is a knob on the left side of machine, I don't know what it does or used for. The manual didn't make it to me with the machine. I figured out the threading, but the tension is too tight. I would...
The knob on the left is the Pressure Foot pressure dial. Here is what the manual says about it: " This dial regulates how hard the presser foot is pushing down on the fabric. To little pressure may cause poor feeding of the fabric, skipped stitches, or difficulty in guiding the fabric as you sew. Too much pressure may result in one layer feeding ahead of another or feed teeth or presser foot marks on the fabric. For most fabrics set the dial at 2. For thicker fabric increase the dial to 3 and for thin fabric decrease to 1." The red dial on top, the far left one, is the tension dial. Just have to play around with that til you get it like you want. Hope this helps!
Jan 12, 2011 | White Sewing 2037 Mechanical Sewing...
Propeler foot
I'm pretty new to sewing as well, but have you checked to see if your feed dogs are up or down? If I am correct (little teeth on the sewing plate right under the needle)they are what moves the fabric along for you. If youre free sewing or quilting you'd want them down but not for regular sewing.
Mar 24, 2008 | Simplicity Denim Star SW210
Sewing Machines Logo
80 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
