Question about Sylvania SSC719C 19 in. TV/VCR/DVD Combo
SYLVANIA SRCD227 REMOTE CODE
Does anyone know how to find the 4 digit code to control this TV? I'm trying to set up a Comcast gray button remote control so it will turn this TV on and off and control volume. None of the registered Sylvania codes work with it. I've spent nearly 2 hours using the Comcast search method and have gotten nowhere. Any suggestions or actual knowledge of this product will be greatly appreciated. Thank you.
  • 3 more comments
  • lala8 Dec 25, 2007
    I need a code for a all for one universal remote for a sylvania tv. It is a used older model and I am having trouble hooking up a dvd player to it and get it to work. I need to keys on the universal to set up the dvd player. I have tried to search the code but, it doesnt appear to be working . Can you please help
    Laura
  • Anonymous Jun 01, 2008
    Cant find a code to set up our really big universal RMC10 remote
  • Anonymous Mar 15, 2014
    how to manually set code on remote for whafedale tv
  • Anonymous Mar 18, 2014
    Have Apex LE3212D tv combo have tried all codes digital adapter remote still will not power on or off my TV plus not able to control volume with digital adapter remote
  • Anonymous Mar 20, 2014
    I have a meos TV radio and CD. The TV and radio have stopped working. It says the Data Base is empty. I have tried initializing it but get nowhere. Is there a program on the net where I can reload the meos through a USB cable. I have tried getting it back to factory format by using the 0000 code, but still no joy. I thank you for any help yuou can give me. Pauline [email protected]
First tell me what brand tv and date of mfg & model# maybe I can help. Chuck [email protected]
Posted on Oct 08, 2007
SOURCE:
My mother in law just passed away and I inherited back the Sylvania LD320SSX I bought her last year. What is the 5 digit remote code for a Comcast remote? Tried all I could find to no avail.
Comcast uses at least 11 different remote controls. I referred to the manuals listed on their remote control page for instructions on programming the three Comcast-branded remote units:
Comcast Universal Remote (Red OK/Select button)
Sylvania LCD TV codes: 20000, 20035, 20043, 20081, 20593, 21593, 21781
Procedure:
  1. Turn on the TV.
  2. Press the TV button once.
  3. Press and hold the Setup button until the TV button blinks twice, then release Setup.
  4. Enter a five-digit code from the list. If this is done correctly, the TV button will blink twice. If you enter an invalid code, the TV button will produce one long flash and the remote control will exit the program mode.
  5. Aim the remote control at the TV and press the Power button. If you have the correct code, the TV will turn off. If not, repeat steps 2-6 with a different code.
If none of the codes work, you can try the code search procedure:
  1. Turn on the TV.
  2. Press and hold TV. Press and hold Setup until the TV button light blinks twice, then release Setup.
  3. Press 9-9-1. The TV light will blink twice.
  4. Press and release the digit 1. The TV key will blink twice. Press the Power key.
  5. Aim the remote control at the TV. Press CH+ until the TV turns off. You may have to press numerous times until the remote control finds the right code in its library. Stop when the TV turns off.
  6. When the TV turns off, press Setup once to lock in the code set. The TV light will blink twice.
Comcast Universal Remote (Grey OK/Select button)
Sylvania LCD TV codes: 0000, 0035, 0043, 0081, 1781
Procedure:
  1. Turn on the TV.
  4. Enter a four-digit code from the list. If this is done correctly, the TV button will blink twice. If you enter an invalid code, the TV button will produce one long flash and the remote control will exit the program mode.
  1. Turn on the TV.
  4. Aim the remote control at the TV. Slowly Press Power and TV alternately until the TV turns off. You may have to press numerous times until the remote control finds the right code in its library. Stop when the TV turns off.
  5. When the TV turns off, press Setup once to lock in the code set. The TV light will blink twice.
Comcast Digital Transport Adapter (DTA)
Jan 22, 2011 | Sylvania LD320SSX LCD TV
I have comcast cable. i need the 5 digit code for the remote.
here is a link to all comcast remote controls and there manuals. Code will be in the manual
http://www.comcast.com/corporate/customers/customer_support/remotes.html
Oct 17, 2010 | Sylvania LC370SL8 37 in. LCD Television
Red/ Bright Tint/Color on Sylvania SRCD227
Your Logitech Harmony 550 is able to learn commands that are not included in its command database.
To teach your Harmony 550 a new button follow these steps:
  1. Connect your Harmony remote to your computer to start the Harmony remote control software.
  2. Click Devices.
  3. Click a device.
  4. Select Learn Infrared Commands.
  5. Click Next.
I hope that helps.
___________________________________
Harmony 550 Manual Download
Logitech Harmony Firmware Update
Harmony Mac Software Download
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
Feb 11, 2010 | Sylvania SRCD227 27 in. TV/DVD Combo
Remote code for comcast dvr/proscan tv
I was having the same problem with my 40" Proscan Tv. I had to go to Comcast and get the remote with the gray OK button instead of the red. I could program my DVD player with a 4 digit code so this remote worked when I put in the 4 digit code Proscan sent with the TV (0178). This was the only solution I could find . They do have the remotes with the gray button but you might have to be very persistant to get one with the codes for the rest of your electronics.
May 23, 2009 | Samsung DVD-HD845 DVD Player
Need remote control code for Panasonic PV-DF2703
I found a newer Comcast PDF file that shows a 5 digit number for tv with vcr ( no mention of DVD) but the code worked to turn on the tv and cable box together. My problem is it won't work the volume, yet
https://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Dec 24, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
Comcast Universal Remote code for Sylvania LC370SL8
10030 or 10054
  1. Turn on your device (i.e. TV).
  2. PRESS the button for the device you want to program (TV, VCR, CABLE, AUD, etc.) then RELEASE.
  3. PRESS and HOLD the SETUP button until the red LED for the selected device flashes twice, then RELEASE.
  4. ENTER the 5 digit code for your brand from the list above.
  5. You should receive 2 quick flashes on the LED for the selected device after entering your code.
  6. PRESS the POWER button to test the code. (On VCR,LD,and CD players use PLAY)
Dec 04, 2008 | Sylvania LC320SS8 32 in. LCD Television
Need codes for comcast remote to ilo tv
When programming your Comcast universal remote for your TV, the programming guide states that you should enter the 4-digit code provided for your equipment, and if you did it correctly, the TV button will blink twice.
What you have to do is put a "1" in front of your 4-digit code, making your code a 5-digit code. For instance, the code for my Panasonic is listed as 0250. I tried and tried. Then I entered 10250 and it worked perfectly the first time. I did it again to make sure I wasn't seeing things, and it worked.
Good luck.
Apr 10, 2008 | Audio Players & Recorders
Envision remote codes
Try
10813
11365
10032
10039
10019
Feb 18, 2008 | iLO 3200 32 in. LCD Television
Codes for sylvania tv
I purchased a sylvanis lcd tv and it won't work with my comcast cable remote...I can't turn it on or off with it or turn up or down the volume. i've called my cable company 3 times and they can't seem to help me. Can you help?
Feb 10, 2008 | Zenith ZEN450 Remote Control
Televison & Video Logo
467 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
