Question about Vizio VO47L 47 in. LCD TV
Vur9 remote only controls the volume and nothing else, cant change channels or anything any suggestions?
My remote for my 47" vizio LCD tv only works the volume and nothing else. I have been searching the web for a solution but cant seem to find one. Any suggestions within reason would be appreciated. B
  • 1 more comment
  • ning350 Apr 26, 2009
    I have the same issue - it worked initially though not it only controls the volume. My universal remote still can contril the TV so i am guessing it is the remote.
  • Anonymous Apr 29, 2009
    I thought my kids dropped it, so I'm glad to know its the remote.
  • thedenn1 May 25, 2009
    same problem, vur 9 remote works audio only,
  • 18 Answers
Press the TV button on the lower right (not the upper right) to tell the remote to control the TV.
The upper buttons are the Input Selector buttons. The lower buttons are the Device Control Selector buttons.
I had this same problem until this dawned on me.
Posted on Jan 23, 2011
  • 1 more comment
  • grrivera7 Jun 19, 2011
    That was it! Doh, I was pressing the TV button on the top to no avail. Didn't notice the TV button at the bottom.
  • Cheryl Heald
    Cheryl Heald Nov 06, 2013
    How would I do this on a VR17 remote, I do not have a lower TV button?
  • Tommy Carpenter
    Tommy Carpenter Nov 05, 2015
    OMG. ARE YOU KIDDING ME?! I was trying to fix my **** remote forever and was so close to buying a new one when I found this post... talk about a UI FAILURE. Now everything works. I was punching the thing thinking the buttons were broken after hours and hours of trying to fix the thing.
I assume you have to reprogram it.
Posted on Jun 13, 2009
  • Eric Hidle Jan 23, 2011
    Press the LOWER RIGHT "TV" button, NOT the upper right TV button.
    The Upper Right TV button is the TV Input Selector. The Lower Right TV button is the Device Control selector.
    I had this same problem until that dawned on me.
    New Friend:
Omg! Been frustrated for the past year trying to figure out why my remote stopped working correctly and only controlled the volume. I've searched many different sites with nothing that worked. Just did this and my remote shut off my tv! Thank you!!!!!
Posted on Jan 13, 2015
    New Friend:
You saved me Eric. Thanks
Posted on Jan 01, 2015
None of the control remotes we used work
Check the contacts for channel and volume on the remotes.
Nov 26, 2015 | Vizio VT470M 47 in. TV
VIZIO E470VA LCD HDTV Dish Hopper remote doesn't change volume
Try another remote code, many of the Dish or Cable TV remotes will have multiple codes for a particular brand of TV's
Sep 01, 2012 | Vizio E470VA 47 in. HD-Ready LCD TV
We replaced the IR sensor on our Vizio but still cannot control the volume via the remote (which has tested good). Any further suggestions?
Since sensor is receiving the signal of other inputs, there is nothing wrong with it. This looks like an incompatibility issue. You may have to retry using the original remote control.
Jul 30, 2012 | Vizio SV470XVT 47 in. LCD TV
My tv will freeze on menu
Looks like there is/are jammed button/s in the remote. Try removing the batteries from the remote and using control panel of the TV.
Jul 28, 2012 | Vizio M470NV 47 in. LCD HDTV
My Vizio SV472XVT 47" HDTV
Unplug the TV from the wall. There must be something wrong with your circuit board. Call customer service for what to do to fix your TV or get a new one.
Mar 05, 2011 | Vizio SV472XVT 47 in. LCD HDTV
The remote on my Vizio 47" LCD TV sort of stopped working. It still does volume and basic things, but power doesn't work and neither does changing the input...it's incredibly frustrating. I swapped in...
Try website 1-800-remotes Factory original.Buy an exact remote.Ur old remote is dead,main CPU chip is sorted.Can't repair this olny replaced with a new remote.
Mar 18, 2010 | Vizio SV470XVT 47 in. LCD TV
I have a moxi box and i just bought a vizio tv and i cant find the code so i can use the volume control on the moxi remote or to turn off the tv either
The Code for the Moxi Cable box remote control for VIZIO TV's is "1178". I just programed my 47" VIZIO TV with this same code
Feb 10, 2010 | Vizio VW42LF 42 in. LCD HDTV
Vizio 47" remote
If your manual buttons on the set do not work, then I would return the set. If they do work then contact the store on where to get a warranty replacement remote, or just go back to the store with the remote and see if it works on another Vizio.
Jun 18, 2009 | Vizio GV42L 42 in. LCD Television
47" Vizio Flat screen HD LCD freezes up and remote will not work.
could it be Ch 9's digital signal is not broadcasting right? what is your refresh rate on your tv? 60 or 120hz? if its 120hz, then its more then likely the digital broadcast, if its 60hz I think its your tv can't keep up with their signal that may be at 120hz. Make since??
Jun 16, 2009 | Vizio VO47L 47 in. LCD TV
Vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Apr 04, 2009 | Vizio VO47L 47 in. LCD TV
Vizio VO47L 47 in. LCD TV Logo
3,509 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
