Question about Maytag EPIC MFW9700S Front Load Washer
Maytag epic washer door lock
I press the on button, chose the wash cycle, press the start button then realize it’s the wrong cycle, so I chose another cycle, then press start button again but the machine does not work, and the door is lock. I followed manual to reset the machine couple times but unable to unlock the door
Please help
SOURCE: Maytag Epic washer MFW9700SQ
Good using the right soap. As a repair tech I work on all brands and I go straight for the tech sheet. On this model yours is located up top under the top panel. Their are about three screws located in the rear of the washer up top should be 5/16 nut size . Take them out set aside pull up and out and the top panel will come off and in a folder you should find the tech sheet that I would use to decide what F07 error is.If you would like to find out.
Posted on Feb 27, 2008
ngfam1
  • 639 Answers
SOURCE: Maytag Epic-Z F-28 error code
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Try unplugging the machine for 3 minutes and then rebooting it!
If the problem continues! Service is the only possibility
If your in the states try A&E Factory service the 800 number is below! They are usually quick!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
  • 409 Answers
SOURCE: Maytag Neptune front load will turn on then off in 3 seconds....
hi there,
please supply the full model # on your washer.
Posted on Sep 15, 2008
  • 409 Answers
SOURCE: maytag epic
hi there,
the FH error means it's either you have a drain problem if there is water in it or if if there is now water in it, make sure that both water inlets are turned all the way up. check to make sure that you don't have any water leaks anywhere visible.
Posted on Oct 03, 2008
michiganfan9
  • 179 Answers
SOURCE: my new Epic Z is only one month old
sounds to me like there is a short in the wiring or control board i would call the warranty company to come fix it
Posted on Dec 30, 2008
How much it cost to fix maytag washer epic z After I push Power, My Maytag epic z front load washer is turning itself off as soon as I press the Start button!
Press the button on the far right next to the Off button and hold for 3 seconds. I think it's the "Cycle End Signal" button.
Dec 02, 2011 | Washing Machines
My dog locked the control panel on my epic maytag washer
Various control lock features on differing models:
Press the end of cycle signal button for 3 seconds
OR
To reset press the DRAIN/SPIN button and hold it for 15 seconds.
OR
Press and hold the END OF CYCLE button for 15 seconds to reset the control.
OR
Unplug washer
Remove lower kick panel
Reach up and locate bottom of door lock switch
Grab the teardrop shaped tab
Pull gently till yall hear a click
The door will be opened
OR press options and select for 10 secs till LOC is no longer displayed
Service Manual
Apr 04, 2011 | Maytag Washing Machines
The control lock button is showing on my maytag epic washing machine how do i turn it off
press and hold the END OF CYCLE button for 15 seconds, the problem should be resolved ..
Feb 11, 2011 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic front load washer: Control lock on and won't reset.
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | Maytag EPIC MFW9700S Front Load Washer
EPIC MFW9700S Front Load Washer: washer stuck on control lock...
Press and Hold down the END CYCLE button for 3-5 seconds. Code will turn off and you can start your washing machine.
May 18, 2010 | Maytag EPIC MFW9700S Front Load Washer
During the wash cycle on a maytag epic mfw9800tq0 my daughter opened the door and after water splashed on the floor she slammed the door shut. It will not drain and spin out now. the tub will agitate...
if she could open the door during wash cycle the door lock is broken and you may need a new one also inspect pumpn and tub to pump hose for foreign objects
Jul 07, 2009 | Maytag EPIC MFW9700S Front Load Washer
Duet washer stopped during wash cycle.
take off the panel below the door three screws and look for the tech sheet located on the right side. It will coach yoou thru the codes and common problems. Sounds like it may be the door swithch does it lock when you push the start? If not the door switch my guess would be a machine control. 877-262-1479 parts.
May 30, 2009 | Maytag EPIC MFW9700S Front Load Washer
My new Epic Z is only one month old
Dec 30, 2008 | Maytag EPIC MFW9700S Front Load Washer
Control locked light on
The button on my Epic version is called the "Cycle End Signal" button.  I pressed it for 3 seconds and the "control locked" light went off and the washer started.  This button is on the far right, just like premm said, near the "Off" button.
May 09, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic
the control board has loose solder connections around the relays.
see this
diff model same issue with new boards as they make them all.
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
being it is in warranty its too early for you to fix it yourself.
you will have to wait for them to come out and say the parts are on backorder.
Feb 04, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
185 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
