Question about GPX MW3337G
New gpx mp3
The dirictions say to select manual when device setup wizard starts then hit finish but when i hit finish it says it cannot be done at this time try again later
    Sergeant:
    Champion:
  • 293 Answers
USB DEVICES THE PROPER WAY ON INSTALLING USB DEVICES 1. Do not plug in your device right away. Install all drivers and software first! 2. Reboot 3. Plug the power or turn on your USB Device 4. Plug in the USB Port. 5. Windows Will detect the Device Automatically. Finish! Hope this helps.
Posted on Sep 20, 2007
SOURCE:
I am not able to download mp3 I purchased from Amazon from my computer to the mp3 player. What are the steps I need to follow?
If you are using g Windows Vista with Windows Media Player 11 , you will need
to follow these instructions.
Note: You will be able to download purchased/subscribed songs to the unit.
1. Start Windows Media Player 11 and then connect your unit to your computer. If
you have not set up synchronization between your computer and this device, the
Device Setup Wizard starts.
2. In Device Setup - Configure Sync, write a name for your mp3 player.
3. Click Finish. The window closes and the Sync feature is displayed.
4. From the left pane of this Sync feature, you can select from Pictures, Music, and
Video.
5. After selecting a category, select the songs, pictures, or video from the center pane.
6. Drag these songs, pictures, or video into the Sync List, which is the right pane of
the Sync feature.
7. Click the Start Sync button on the Sync List pane.
8. Repeat steps 4-7 for any other items that you want to copy to your unit.
If you are using g Windows XP with Windows Media Player 10 , you will need to
1. Start Windows Media Player 10 and then connect your unit to your computer. If
. In the Device Setup Wizard, select Manual.
3. Click Finish. The wizard closes and the Sync feature in the Player is displayed.
4. Select the Library option. On the left pane select Sync List.
5. From the left pane you can select All Music or My Playlists and you will see the
songs located within these folders in the center pane.
6. Select the songs from the center pane, and drag them to the Sync List.
If you want more info you can download your manual here
http://www.devicemanuals.com/downloadguide.php
May 28, 2010 | GPX ML858B Digital Media Player
How can I download music to my MP3 player?
IF YOU R USING WINDOWS XP WITH WINDOWS MEDIA PLAYER 10, YOU WILL NEED TO: START WINDOWS MEDIA PLAYER AND THEN CONNECT YOUR UNIT TO THE PUTER. IF YOUR PUTER HAS IT, USE THE DEVICE SETUP WIZARD AND IT WILL START. 2.IN THE DEVICE SETUP WIZARD, SELECT MANUAL. 3. CLICK FINISH. THE WIZARD CLOSES AND THE SYNC FEATURE IN THE PLAYER IS DISPLAYED. 4. SELECT THE LIBRARY OPTION. ON THE LEFT PANE SELECT SYNC LIST. 5. FROM THE LEFT PANE YOU CAN SELECT ALL MUSIC OR MY PLAYLISTS AND YOU WILL SEE THE SONGS. 6. SELECT THE SONGS FROM THE CENTER PANE, AND DRAG THEM TO THE SYNC LIST. 7. CLICK THE START SYNC BUTTON ON THE SYNC LIST PANE. 8. REPEAT STEPS 4-7 FOR ANY OTHER ITEMS THAT YOU TO COPY TO YOUR UNIT. FOR MORE INFO GOOGLE "HOW TO PUT MUSIC ON MY GPX MW3837 PLAYER. HOPES THIS HELPS!! PS-MAKE SURE THE HOLD BUTTON ON THE SIDE OF PLAYER IS NOT LOCKED.
Dec 26, 2009 | GPX MW3836 MP3 Player
When I go to sync music from Windows Media Player, it says "It is not possible to change sync settings at this time. Try again later." What can i do to get it to work?
If you normally create a profile for your GPX on your desktop computer. Delete that profile, and then add back your GPX to your computer via the cable and it should work. I presume you are using windows XP?
Aug 14, 2009 | GPX MW3837 MP3 Player
I just want to know how to get music off my computer to the mp3
I have copied the method that GPX uses to transfer your music from PC to player.
If you are using Windows Vista with Windows Media Player 11, you will need to follow these instructions.
1. Start Windows Media Player 11 and then connect your unit to your computer. If you have not set up synchronization between your computer and this device, the Device Setup Wizard starts.
3. Click Finish. The window closes and the Sync feature in the Player is displayed.
4. From the left pane of this Sync feature, you can select from Playlists or Library and you will see the content of these folders in the center pane.
5. Select the songs or entire albums from the center pane.
6. Drag these songs or albums into the Sync List, which is the right pane of the Sync feature.
If you are using Windows XP with Windows Media Player 10, you will need to follow these instructions.
1. Start Windows Media Player 10 and then connect your unit to your computer. If you have not set up synchronization between your computer and this device, the Device Setup Wizard starts.
2. In the Device Setup Wizard, select Manual.
5. From the left pane you can select All Music or My Playlists and you will see the songs located within these folders in the center pane.
If you are using Windows 2000, Windows 98SE, and Windows ME with Windows Media Player 9, you will need to follow these instructions.
Note: You will not be able to transfer purchased/subscribed songs to this unit using Windows Media Player 9. You need Windows XP with Windows Media Player 10 to do so. However, you will be able to download regular MP3/WMA songs.
1. Start Windows Media Player 9 and then connect your unit to your computer.
2. Click Copy to CD or Device.
3. In the Items to Copy pane, in the drop-down list, select the playlist, category, or other collection that you want to copy.
4. Check the box next to any file you want to transfer to your mp3 player.
5. In the Items on Device pane, in the drop-down list, click the device to where you want your music files transferred.
6. Click the Copy button.
7. Repeat steps 2-5 for any other items that you want to copy to your unit.
Jan 03, 2009 | GPX MW3837 MP3 Player
Hi I would like to add the free songs my MW3836 offers Sherry
Dec 07, 2008 | GPX MW3836 MP3 Player
I cant delete anything or upload
Dec 01, 2008 | GPX MW3836 MP3 Player
I got a gpx MW3836 1gb mp3 player. i cant get any music on there from my wondows media player lists. my playlists songs might have been copy rights protected on it. i want toknow how to get my play lists...
Converting wma's to mp3 costs money unless you are getting the songs from an actual CD. Better to get an mp3-only music service like Limewire, Rhapsody Mp3, etc.
-Tha Mp3 Doctor
Nov 27, 2008 | GPX MW3836 MP3 Player
Making a folder will not work for me??
You cannot just create new folders - the player will not recognize them.
-Tha Mp3 Doctor
Nov 13, 2008 | GPX MW3836 MP3 Player
How can i see the songs on my mp3 player?
Uninstall the GPX software and then reinstall it - the new installation will take the new version of Media Player into account.
-Tha Mp3 Doctor
Nov 12, 2008 | GPX MW3836 MP3 Player
GPX MW3337G Logo
35 people viewed this question
Top GPX Audio Players & Recorders Experts
Ekse
Joe Negus
Joe Negus
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
