Question about Great States 404-16 16-Inch Standard Push Light Reel Lawn Mower With T-Styl
I have a Great States 415 16 16 Inch reel lawn mower and need to figure out how to adjust the blades
  • 107 Answers
Heres a link to your owners manual
http://www.reelmowersetc.com/414-16,%20415-16,%20705-16%20Owner's%20Manual.pdf
instructions on how to adjust are on pg 3
Posted on Apr 20, 2009
Need a manual for a scott's model 21505x8a lawn mower
You should type that into google, with a space and then ".pdf" You should see some results you can click on to download the PDF owners manual
Oct 06, 2014 | Great States Corp 14 In Scotts Turf Reel...
Tip
Brill Razorcut As functionally elegant as a bicycl
Brill Razorcut As functionally elegant as a bicycle, the Brill RazorCut 33 Reel Mower ranks as a highly efficient human-powered machine. It's lightweight and easy to push - with no need for gas, oil or electricity!
MANUFACTURER'S INFORMATION
• Contact-free cutting, precision ground flame hardened bearing mounted blades • Cutting height: 0.7 - 1.8 inches (14-45 mm) easily adjusted, indicators both sides • Large hood protects overhanging flowers and shrubs • Rigid ergonomic handle with foam grip • Mows a 13-inch swath (33 cm) • Cutting technology: Blade cylinder, 5 blades • Weight: 15.21 pounds (6.9 kg) • Wheel diameter: 8 inches • Recommended for areas up to 2150 sq. ft. • Made in Germany • Two year warranty
on May 08, 2009 | Brill Razorcut 38 Push Reel Lawn Mower
Why one wheel turns and other won't
Sounds like a seized bearing. Shoot oil into it or remove wheel and you can tell that way. I would oil the shaft and wheel well before taking apart.
Sep 20, 2014 | Great States 18-Inch Deluxe Reel Mower
Front wheels on manual mower lock when pushing for awhile.
1 Locate the height adjustment lever on the inside of the left rear wheel.
2 Kneel next to the mower and push the left height adjustment lever toward the center of the mower. This will unlock the lever from the locking pin on which the height is currently set.
Read more: How do I Adjust the Height on a Great States Reel Mower? ' eHow.com http://www.ehow.com/how_6834215_do-great-states-reel-mower_.html#ixzz21NOr1e8d
3Rotate the lever toward the front of the mower to lower the height of cut, or toward the rear of the mower to raise the height of cut.
4 Release the lever over the locking pin closest to the desired height of cut.
5 Repeat these steps with the adjustment lever on the right-side rear wheel. Be sure to set the right wheel lever to the same position as the left-side wheel's lever for an even cut.
Jul 22, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do you adjust push-reel mower
You don't! Usually. Some allow height adjustments only. Others do not! One height fits all! On a side note...I hope you are a youngster! Maaaan! those puppies really require more push energy than you'd think. And if you aren't a young'in I sincerely hope you got a "victory garden" patch or something small in area...WHEW! But...I have seen them for sale "new" as recently as 2 weeks ago. (I'd rather faint from trying to pull start my "self propelled" baby!
May 09, 2010 | Great States 415-16 16-Inch Standard Full...
How to adjust blades to cut evenly?
should be a screw iether side above the blade turn clockwize to close the gap between  the blades both sides should touch the cutting blade on the bottom you have to turn the centre blades by hand to make sure both sides are even but be careful not to catch fingers on the blades while turning
Oct 04, 2009 | Great States Corp. 16 In. Scotts Elite...
Scotts reel mower gear problem
I found some replacements at http://www.reelin.com. The parts number for the pinion gear is 30737-2, 30737-3 (left and right) for the Scotts Classic.
You can find the owner's manual, with part numbers, here:
http://www.reelmowersetc.com/2000-20.pdf
Jun 09, 2009 | Great States 20" Scotts Classic Push Reel...
Reel mower isn't engaging -- blades aren't rotating and cutting
Remove the wheels and check the gears inside.
It sounds like they are worn or sheared and need
renewing
Jun 05, 2009 | Great States Corp. 16 In. Scotts Elite...
Scotts 20" reel mower. Drive wheels will not turn blades any more. Blades turn freely, but will not be driven by wheels.
This is almost certainly a problem with worn pinion gears, which are unfortunately made of plastic. Replacements are just a couple of dollars, but you'll probably want to buy a few for each side in the event this happens again. The Scotts 20" reel mower is manufactured by Great States 1-800-618-7474. You can also find more information at www.reelmowersetc.com and the user manual for this particular mower can be viewed at http://www.reelmowersetc.com/2000-20.pdf.
Feb 17, 2009 | Great States Corp. 18 In. Scotts Deluxe...
Great States 404-16 16-Inch Standard Push Light Reel Lawn Mower With T-Styl Logo
538 people viewed this question
Top Great States Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Great States Garden Expert? Answer questions, earn points and help others
