Question about York / Cam-stat Compressor Cycle Timer 2cp04700124
Missing screw I have a York Electric timer for exterior lighting and there are 2 moveable "clips" that are secured on the timing whel by tiny brass screws and I lost one screw. I can't find a replacement for this tiny part.
    President:
  • 2,692 Answers
The screw is A common machine screw, which you should be aboe to match at an automotive parts store. The clips can be found at any elecvtricial supply house that sells that brand of timer switch.
Posted on Apr 20, 2009
Will turn off by timer if manually turned on but not on by timer
There are brass colored clips. and silver colored clips. It sounds like you are missing one of the colors. It may have dropped off. Look for it in "the little grey box". It attaches to a groove on the wheel with a simple thumb screw. Place it on the wheel at the time setting where you want it to turn on.
Also, If the switch is in the manual mode, it bypasses the "on" clip. If you want it to turn on, place it into the automatic mode.
May 16, 2016 | Intermatic T101 - 24 Hr. Dial Time Switch...
Tip
Replacing colorwheel on an InFocus X1A, X2, X3, and SP4805
to replace the colorwheel:
remove the 4 brass and 4 silver screws from the bottom and the 2 silver screws from the back. through the top vent on the back panel and using a flat head screwdriver, unclip the 3 clips holding the back panel on. once removed, unplug the 2 wire harnesses. remove the top and front panel. now unplug the large wire harness and remove all the brass screws on the 2 power supply boards (also the screw for the ground wire). there is a black clip in the middle of the larger power board. remove the boards. now remove the brass screws holding the metal plate on. once removed, unplug the flat ribbon cable (for the colorwheel). now facing the front end, remove the lamp and the 4 screws holding the lamp housing (with fans) on to the bottom case. remove the tiny black screw on the small circuit board and remove the board. now you can get to the colorwheel. there are 2 small black screws holding the bracket. pull the ribbon cable through from under the fan. replace with new colorwheel and reverse the instructions. the only difference, remove the front panel from the top by undoing the clips. good luck!
on Dec 02, 2009 | InFocus LP220 Projector
How To Replace The Exterior, Front Door Handle On A 2012 Toyota Camry
It removes just like the older style handles with one exception. You must remove the electrical clip/wire that attaches to it while still in the door. It has 2 black clips top/bottom for the harness, one white clip for the actual connector to come off handle (removes toward center of vehicle. After this is off and of course the part behind the moveable handle then the moveable handle will shift backwards and out while swinging rear away from door.
Dec 27, 2012 | 2012 Toyota Camry
I'm trying to install this Woods 59008 automatic fan timer in the bathroom. My old on/off switch only has three wires....and I that a light switch next to that. The woods 59008 has a red, black, white...
Sure George.
These in-wall timers have extra wire to operate the electronics located inside timer.
You said your old switch has 3 wires.
The new timer can only replace on-off switch that has 2 brass screws and a green screw.
If old switch has 2 brass screws and a dark screw, that is a 3-way switch.
Typically a 3-way switch is found at both ends of hallway.
The Woods 95008 countdown timer is not made to replace 3-way:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59000
Here's what to do:
1) Switch has 2 wires (plus bare ground wire). Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
2) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires. This wire will power timer electronics.
3) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
4) Turn on electricity, and push override button located below the OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Add a comment if your need more assistance.
Dec 22, 2010 | Woods Ind 59008 Digital Timer
Using a #5224 Combination two switches to light two different fixtures (an exterior light) and it will only turn off and on by 2nd switch being switched on or off (the interior ceiling light) Hooked each...
I think you have your wires connected to wrong screw.
Wiring devices have screws that are color-coded as you noticed.
The Hot wire from breaker connects to dark colored screw(s).
The wires to Load (ceiling light-outdoor light) connect to brass screws.
If you need more help, add a comment at bottom and I will help further
Oct 26, 2010 | Leviton COMBINATION SINGLE POLE TOGGLE...
I need to know the wiring for this timer. There are 2 brass screws on the left (w/ the number 1), and 2 screws on the right (marked X and 2) - 1 bright (X) and 1 brass (2). Where do I connect my electric...
Some how this ended up in the riding mower section. You didn't indicate what brand of timer.
If it is a tork then here is a typical diagram: The incoming hot ( BLACK) would connect to the L the out going black would connect to X. The white neutral coming in and out would connect to the terminal without number. Intermatic timers are similar, not same terminal numbers. You can download a intermatic manual at www.intermatic.com
If this was helpful, please rate and/or leave comments
Oct 07, 2010 | Garden
Carb need adjusted
this is an idle mixture screw
screw it all the way in then count the turns as you screw it back out. aprox 2 turns.
then if you can get it to idle,
as you screw it in 1\4 -1\2 turn it should start to richen and miss. as you screw it out 1\4-1\2 turn it will lean out and the revs increase and be uneven. then pick a place between the two where it idles best
a 1\4 of a turn can make a difference, and it will change slightly with a dirty aircleaner and hot or cold engine
Jun 15, 2010 | 2005 Honda CRF 450 R
How to change the timer on WGD5800SW0
First things first, disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the screws attaching the console to the rear of the machine then use a putty knife blade or similar tool to push and release the clips holding the console in place to the top of the machine. Push the putty knife blade rearward under the front corners of the console until the clips are released. Pull the timer knob off then flip the console to access the timer.
Remove the screws securing the timer to the console bracket then secure the new timer in place. Disconnect the wires from the old timer one at a time then connect it to the new timer to prevent messing up the wires.
Push down the console down onto the top of the machine to engage the clips then secure the console back into position.
Note: The timer is part number 3406725.
May 22, 2010 | Whirlpool WGD5800S Dryer
York timer roblem
Grasp the timer dial with your fingers and pull out on it to turn. Set the time of day with arrow at bottom and release. That's it!
Jun 15, 2009 | York / Cam-stat Compressor Cycle Timer...
York / Cam-stat Compressor Cycle Timer 2cp04700124 Logo
273 people viewed this question
Top York Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a York Hardware and Accessory Expert? Answer questions, earn points and help others
