Question about SanDisk Sansa e260 MP3 Player
Memory overload I have a 1 GB SanDisc Sansa that has NO free space left even after I've tried to wipe the memory with the format option. No matter how many times I try wiping it, there's no space available. What can I do?
  • 626 Answers
Are you formatting it thru Windows Media Player or My Computer? If its WMP, try under My Computer, if it was under My Computer, try using Disk Management. Right click on My Computer and select Manage. Then in the next window, select Disk Management on the left side. ON the right side at the top, you should see your device listed, right click and select format. If your device does not show up in Disk Management, change the mode on the device via Settings>Mode or USB Mode. Best of Luck.
Posted on Sep 20, 2007
6ya staff
SOURCE:
My sansa fuse 4GB seems to have lost most of its internal memory.Although I've deleted everything from the unit , I'm left with only 35 MB free of 3.65 GB.How can I retrieve all the internal memory?
You should format the memory of your player but if you have important files on the device make back up of them before. You have two possibilities to do the formatting:
1. On the player use the device Format command under Settings and Format option.
2. Using your computer, and windows explorer select the drive of sansa and right click on and choose format. Type of it should be FAT.
Then you already should find all the internal memory in the device.
gylacz
Mar 16, 2011 | SanDisk Sansa Fuze MP3 Player
How do I create more space on a sandisc 16GB USB
To create more space, you can delete the files that are on the drive. If you are not concerned with any of the files that are already on the drive, you can right click on it in My Computer and select format. From that window, check "quick format" and then hit format. That will completely wipe the drive and you should have most of the 16GB free.
Jul 20, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Memory on my mp3 is almost full without any songs on it.
Try this: Connect your MP3 player to your computer. Open "My Computer". You should see your MP3 player connected. Right click on it. Click on FORMAT. This should completely wipe everything on your MP3 player (except for the original necessary files that came on it origianlly). You should then be able to get all of your space back.
Apr 15, 2010 | Insignia Sport MP3 Player
1 GB micro sd memory card for my mobile nokia 3110c ..
try reformatting your memory card, however, previous data will be lost...
To format a memory card, select Menu > Gallery or Applications, the memory card folder , and Options > Format mem.
card > Yes.
When formatting is complete, enter a name for the memory card.
May 01, 2009 | Nokia 3110 Cellular Phone
Error message on E260 player
Same problem delete a couple of songs up to 6 mg or 10 whatever then allow to refresh then download your songs back in the music file. the sansa needs some memory to know it has the sdcard in it...
Dec 28, 2008 | SanDisk Sansa e260 MP3 Player
Says not enough space for DB.Please free 4MB.
You need to format the device:
Format
This will format your Sansa c200 player’s internal memory
1) Select Settings from the Main Menu.
2) Select Format
3) Select Yes to format the internal memory or No to cancel.
-Tha Mp3 Doctor
Dec 10, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Says i need to free 4mb of space
Format
2) Select Format
-Tha Mp3 Doctor
Nov 27, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Free memory
Format
2) Select Format
-Tha Mp3 Doctor
Sansa c200 series – Computer/OS Not Recognizing
Connect the device to the PC in MSC Mode
View/c200: Turn on then press and hold the rewind button while plugging to the PC
If that fails, unplug the Sansa from the computer. Uninstall all the Sansa software in the add/remove programs section of Control Panel. Reinstall the clean version of the software from Sandisk’s website – make sure you get the files for the c200 series. Then replug the Sansa and try again. The root of the problem is that Sansa has one set of drivers and Windows has another. If you plug the mp3 player into the computer before installing the Sansa drivers, the Windows drivers will trump the Sansa’s.
Here is a helpful link from Sandisk on the problem with extra information on Vista operating systems:
http://kb.sandisk.com/cgi-bin/sandisk_en.cfg/php/enduser/std_adp.php?p_faqid=42&p_created=1221328944&p_sid=8VPwlRmj&p_brand=sansa&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NzQsNzQmcF9wcm9kcz00JnBfY2F0cz0mcF9wdj0xLjQmcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1jMjAw&p_li=&p_topview=1
-Tha Mp3 Doctor
Aug 03, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
My Sansa c200 says memory full
some times their is not enough space in phone memory! if you hav any pic or video in phone memory! move memory card or pc! then you can download songs! actually one songs is 3mb! check phone memory
Jun 30, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
MP3 player memory issue does'n free up all the space
Just reset ur player using the reset pin available on the player!!
Apr 03, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
71 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
