Question about Brother Multi-Function Center® MFC-215C All-In-One InkJet Printer
MFC 215C, mfc 215c erorr 46
Brother MFC 215C,"unable to clean" mfc 215c erorr 46
  • Anonymous Mar 15, 2014
    Won't clean
  • Anonymous Mar 31, 2014
    how to clean head
  • 526 Answers
Most likely your flush box is full of ink, the pads will need to be replaced by a service center.
Posted on Apr 20, 2009
The purge counter needs to be reset to zero. it is trying to say that your ink filter box is full and it may not actually be full and you may get away with resetting the purge counter instructions listed below.
Fax models with numerical keypads: press *, 2, 8, 6, and 4 keys within 2 seconds . (if you fail to complete the correct key sequence with two seconds, press stop key to try again)
other non fax models: press the menu/set button and black start keys. next press the up arrow key 4 times to enter maintenance mode
2). press the 8 then 0 keys in the intial stage of the maintenance mode to call up the machines log information list (function 80)
3) press the black start key several times to scroll through the log information list to reach the purge counter. The purge counter is around the 25 item in the list
4)then press 2, 7, 8, and 3 keys in this order to reset the purge counter to zero
5) press the stop/exit key top return to the initial stage of the maintenance mode.
6) press the 9 key twice to return to standby state
You may still need a new ink filter box which is easy enough to install. I found that this message can appear several times before needing to replace you may find more or less so check that the filter is not full. You can do this by lifting off the scanne top and undoing a few screws. your local pc/printer shop will change a filter for you without the need to pay a lot of money for a service engineer.
Posted on Oct 11, 2012
I cant get my printer to clean or print keeps saying unable to print, please help
verifiqure se da algum erro
se der o erro:machine error xxx
faça o seguinte:
May 15, 2009 | Brother MFC-215C All-In-One InkJet Printer
Brother mfc-215c unable to clean?
The ink blotter in the bottom of the machine is full, this is a built-in redundancy. Machine needs to be completely stripped to replace this.
Buy another brand next time.
Oct 01, 2008 | Brother Multi-Function Center® MFC-215C...
Mfc 215c unable to clean
Problem was fixed. See link below by SkipperOz
http://www.fixya.com/support/t485892-error_46_unable_init
Solution applies to MFC-5440CN but also applies to MFC-215C.
Jun 19, 2008 | Brother MFC 210C All-In-One InkJet Printer
@artkoy:
There is no Error 10 within the maintenance of the printer!
An error starting with 10 (and two more digits) belongs to the communication device (fax).
Plz check again what two digit error you have and post again.
@peter:
you need a new waist ink absorber. plz check the forum for unable to clean or error 46. Its explained many times.
Mar 27, 2008 | Brother Multi-Function Center® MFC-215C...
I have the same problem my printer (a MFC-215C) is unable to clean and when I press Menu/set I do not have "Black print"? So what do I do now?????? HELP... Thanks Nathalie
Nov 09, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother Multi-Function Center® MFC-215C All-In-One InkJet Printer Logo
862 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
