Visit to the given link and download "FinePixViewer" then install this software in your PC. After installing Restart the PC and then connect your cam to PC via USB. http://www.fujifilmusa.com/support/ServiceSupportProduct.do?prodcat=871202
... Now you wuld be able to transfer your pics from cam to PC. If you still got the same problem then install the driver too...
Hope this has helped you..
Please rate the answer
Thanks
Samsung say this has a USB 2 port. Maybe it is behind a door or has a rubber plug in it. It will be a mini-USB socket, not a big one like on the computer, and a lead should have come with the camera. If you are using a "charger" lead that plugs into a USB port on the computer, than that also serves as the USB connection.
People often find it simpler to remove the memory card from the camera and plug it into a cord reader on the computer to transfer files. Newer computers have card readers built in, but if yours doesn't, you can get a little SD card reader for a quid at Poundland. However, this camera uses micro-SD cards, so you will also need an adapter to get it to fit an SD reader slot. If you aren't using a card, then you will have to use the USB lead to transfer pics from the camera's built in memory.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
What software are you using now? You can download the latest version of Nikon Transfer from http://support.nikontech.com/app/answers/detail/a_id/61
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
In addition to Nikon Transfer there are plenty of other photo catalog software packages out there, some free, some not, that can transfer and catalog your pictures so you can quickly find pictures from Susie's birthday party, for example. Just do a google search for "photo catalog software".
Yes you cannot transfer pictures without the USB cable since that is working like the 'bridge' for your camera and computer communication.
However, there is still another way on how you can get the pictures. That is to use a memory card reader. Most laptops now has that particular slot. Or you can buy a cheap memory card on the nearest PC store.
I can'tg upload pictures. I have a polarioid t11031 digital camera, and I have a USB cord ffor it, but my computer does not recognize it when I plug it in. I want to know how I can get the pitctures off my camera and onto my computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
wat softwarre??
