Home | Bosch | 24 in. SHU66C05 Stainless Steel Built-in Dis... | Water remains in the tub...
Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher
Problem for Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher
Water remains in the tub after the cycle is complete.
By reeniemo50 on Apr 20, 2009
The drain is not plugged. What is wrong and how can it be fixed?
Solution #1
posted on Apr 20, 2009
Somewhat Helpful)
joed202902
Rank: Guru
Rating: 88%, 154 votes
If you are sure that the soft disposal and drain are clear, then check the discharge hose to the sink and be sure it isn't kinked or otherwise obstructed. Also check the drain for the sink and be sure it isnn't partially plugged. If all ok, then look for an issue with the control board or pump.
Was this helpful?
Yes
No
Solution #2
posted on May 01, 2009
Not Rated)
haze58
Rank: Apprentice
Rating: 0%, 0 votes
where pump located
Was this helpful?
Yes
No
Popular Solutions for Bosch 24 in. SHU66C05
Questions and Unsolved Problems for Bosch 24 in. SHU66C05
Do you recommend Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher?
Answer
Answer
I found that by initially disconnecting the pipes and cleaning them out (without the usual... (More)
Answer
our bosch dishwasher had some water on the floor . I think it's coming from the bottom seal of the... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bosch 24 in. SHU66C05...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
