Question about Samsung TXN3071WHF 30" TV
Xbox 360 screen cut off on left side
So i finally got the pincushion issue repaired and that is all good. now i hook up my xbox 360 for the first time, and the screen is cut off on the left side, almost as if the image is just a tad too big for the screen. this doesn't happen with the dvd player using standard (not hd) cables, or on regular tv. i've looked around on the internet and others have the same issue. i tried setting the 360 at 720p but it didn't work-just a scrambled image. 420p produced the same results as 1080i, which is what i had it set on. the 360 looked fine on other tvs so i don't believe it is malfunctioning, as other users with the same model tv have this same issue. could this be remedied thru calibration? none of the settings i could access for the tv had any effect.
  • 1 more comment
  • poe diddley Nov 17, 2007
    well after some research i've found that other users have the same problem. my xbox is set on 1080i just as it should be, and the left and right side of the screen is cut off. i read somewhere that it could be that the xbox transmits at 70hz and the tv is built for 60hz, but for some reason i doubt this is right.
    when i had my tv repaired, the guy tried to stretch out the picture by manipulating some screws inside the tv, so i'm thinking that maybe they didn't reset it when it was repaired. i am going to order the service manual and try to fix it without screwing up my tv.
  • prolific07 Dec 02, 2008
    i have a similar problem when i use 1080i for my ps3. The screen is cut off, it appears the image is too big to fit. im gonna try that mute 1 2 8 power trick and see if i can get it to display correctly. Also why is the front so damn small with 1080i.  Ive used 1080i on other televisions and its no where near as small what is displayed on my TV.
  • Anonymous Dec 28, 2008
    I can't get the mute 123 thing to work. I control my tv via a sky+ remote though. I bought a new tv yesterday and suddenly the picture from my xbox 360 is too big for the screen. I tried changing all the resolutions. I phoned xbox yesterday and they couldn't fix the problem so they phoned me back today and are gonna phone again tomorrow. They're just messing me around. If they can't sort the problem I'll be selling the xbox. Microsoft customer care is awful.
Ok, I've had the same issue and I was able to fix my problem. I was getting cut off sides in HD mode on my playstation.
I entered the service menu by doing this:
Turn TV Off
Use remote and hit "Mute 1 8 2 Power" (not at the same time, but one after the other)
The TV will come on with the service menu. Enter the 1080i adjustment screen. Write down ALL the values in case you mess up. Adjust the values as necessary to fit your screen. It's sort of like adjusting a computer monitor's image for different resolutions.
Hit me if this helps... mlager at sysnosis dot com
Posted on May 03, 2008
Sorry not really a solution to your problem, but the TXN3071WHF wont accept a 720p signal thats why it was just a scrambled image.  The TXN3071WHF will accept 480i/480p/1080i, the only thing i could suggest is try each of these outputs from your 360 and try both component inputs on the back of the TV.
Posted on Oct 23, 2007
My xbox 360 has the 2 red rings of death and it wont cut on
I KNOW HOW TO FIX IT! There are links that show you how to repair this issue yourself (but they are not very clear and every thing is very fragile inside the XBOX 360) or you can contact me via email at mycharminglife@gmail.com and we can discuss the issue further as I recently repaired my XBOX 360 with the same issues and it works better than when was brand new.
Nov 11, 2010 | Microsoft Xbox 360 Console
Xbox 360 Screen Jumping/ Games Unplayable
Try running a dvd cleaner through it, if that doesn't work call xbox customer support, (be nice though, they will be more reseptive!).
Mar 02, 2010 | Microsoft Xbox 360 Console
How do you fix your xbox 360 open tray problem
Your best bet is to get a new DVD drive. Here's how you should do it. First, open up your Xbox 360. (there are plenty of tutorials for this online, and I will be writing a Tip for it soon) Check your DVD drive's Model and F/W.
F/W is the firmware model. It is the key that tells your motherboard it has the right drive. MAKE SURE YOU GET THE RIGHT ONES! This fix may work if you have just the right Drive model, but you can never be too careful.
Okay now, you will need to carefully take apart your new DVD drive. (once again, tutorials online) once you do that, un-hook and remove the new DVD drive's motherboard and place it to the side.
Next, do the same to your old DVD drive.
Finally. Take the motherboard from your old DVD drive and place it in the NEW dvd drive. hook the motherboard up and put the NEW dvd drive back together. Place the new DVD drive in your Xbox 360, hook it up. Close your 360. Turn it on. Place a game in. And viola! As long as your NEW dvd drive wasn't faulty, Your Xbox should work perfectly!
Things to try before doing this:
Wiping the dvd lens with a soft cloth.
wiping the game with a soft cloth.
Things to do instead of this.
Send your Xbox to Microsoft if you still have a warranty.
Send it to a trusted Xbox Repair Service Center. I currently run DRAGONF1R3 REPAIRS. Contact me for more info. My e-mail is in my description.
Hope this helps! good luck!
Jan 24, 2010 | Microsoft Xbox 360 Console
Put in disk in 360. Play Playonline viewer, but screen goes black, and says cannot read disk, need to clean or restart. I did this several times and same result.
I had this problem recently. What happened was you closed the game without logging out of Playonline. The long shut down I call it. This corrupts the FFXI data on your HDD. And since FFXI does not appear in the memory you have to format your HDD and redownload. I can guarantee if you put the disc in your xbox with no HDD that it will read or even place it in an xbox with a HDD that has never had FFXI.
Dec 26, 2009 | Square Enix Final Fantasy XI for Xbox 360
2 red lights on the left hand side. comes back on for 5-30 minutes then goes off red again.
Your xbox 360 console is overheating. Make sure all your vents are clean and unobstructed. Allow to cool for a few hours. If problem persistes you'll need to contact microsoft. May be an issue with the cooling fan
Oct 05, 2009 | Microsoft Xbox 360 Console
My xbox 360 wont play a xbox game. please help.
you need an update from xbox live (or disk) before you can play that game.
Here's the website to read on how to obtain the update.
http://www.xbox.com/en-US/games/backwardscompatibility.htm
Good luck - hope this helps!
Sep 17, 2009 | Microsoft Xbox 360 Console
Xbox 360 has no video or sound on startup
I've fixed that problem several times now with a great xbox 360 repair guide
Mar 05, 2008 | Microsoft Xbox 360 Console
Xbox 360 no video
Warrenty issue. Contact Microsoft to get this fixed. There a lot others having the same problem. do not take it apart. This will void the warrenty.
Feb 15, 2008 | Microsoft Xbox 360 Console
The power button on my 360 puts the one green light on the right instead of the left
I have a very similar problem I had a few days ago. But what I did was I shut down the Xbox 360 console completely. Then I unplugged the power cord from the Xbox 360 console and the wall outlet, and then I disconnected the batteries from the wireless controller. let it sit for about 5 min. Then plugged everything back in, and finally I hit the the wireless connecting buttons on both the Xbox 360 console itself, and the wireless controller(s).
And from then on, I have had no problems, what so ever since I did that (above).
Jan 05, 2008 | Microsoft Xbox 360 Console
Open Questions:
See all Samsung TXN3071WHF 30" TV Questions
Samsung TXN3071WHF 30" TV Logo
3,404 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
