Question about Dometic Rooftop RV Air Conditioner
Airconditioner unit on my RV will not run.
The airconditioner ran great all day. I came back to ther RV and the air was off. I went to the thermostat and shut it off then put it back to air. It did not come on. I can here it click in the control box but that is it. Could it be a bad relay switch?
Thanks for your help,
Craig
  • Nahoku66 May 11, 2009
    I have a 5 button duo therm with a gas furnace. The ac worked fine all day but would not stop cooling last night. I set the thermostat to 99 degrees and it still would not turn off. Tenperature outside was 90 degrees when i noticed the problem. The coach was like a meat locker.
    Guru:
  • 588 Answers
Check to see if you have the proper voltage to the air conditioner and check your breaker.The clicking you are probably hearing is the thermostat opening and closing when you turn it up or down.
Posted on Apr 20, 2009
Rv airconditioner trips breaker
Does it trip when fan only , or when compressor for cool cuts in? Sounds like capacitor perhaps . Get back to me with model number, and whether it's a ducted system, or blows out at ceiling assembly.
Apr 02, 2012 | Dometic Rooftop RV Air Conditioner
Duo therm rv airconditioner pulls 17 amps, with compressor running. It cools very well though.
Check incoming voltage first to make sure it's not dropping under load, or low to begin with. Any poor voltage or long runs of extension cords could be causing voltage to drop, thus raising amperage draw.
Jul 04, 2011 | Dometic Rooftop RV Air Conditioner
Airconditioner does not cool
If compressor runs, freon low, if comp wont run, can be stat or compressor, etc. they are 650 dollars new online so not an economically viable repair if too involved at all, a throw away unit essentially, no offense.
Nov 01, 2010 | Dometic Rooftop RV Air Conditioner
The airconditioner is drawing too many amps and is tripping the breaker during the day at night it seems to run ok
Check the condenser fan and see if it is running. If it's not it will cause the head pressure to rise and the unit will work harder. This will be more noticable in the heat of the day. Also check your air filter. Let me know what you find and we'll go from there.
May 22, 2010 | Dometic Rooftop RV Air Conditioner
I have an airconditioner a Kelvinator KSR20C Split system
Your condensor fan motor has more than likely gone out. This fan should run at all times when the unit is on. Since the fan isn't working then the motor must have gone out.
Dave
Nov 16, 2009 | GE Zoneline AZ38H12DAD Split System Air...
I have a coleman electraheat rv airconditioner/heater. i think the thermostat has gone out on it. is this a replaceable?When i turn the thermostat knob nothing happens. the fan will run but the compressor...
The thromstat may be bad but it sounds like there is a loose connection where the wires plug on to the back side of the thromstat.
Any RV dealer should have the part or be able to order it for you
Aug 21, 2009 | Dometic Rooftop RV Air Conditioner
Duo Therm Model 59516.531 RV Airconditioner not cooling
The refrigerants in these units is R-22 But there is no reason to think the system has a leak. You need to confirm that the comprerssor is running. This requires an ammeter. If you don't have one call a technician.
Ray
Jan 10, 2009 | Dometic Rooftop RV Air Conditioner
NewAir AirConditioner on "Dehumidifier" Mode Only
I have a 3 ton a/c system that removes about 5-6 gallons of water from the air per day. Most portable dehumidifiers/air-conditioners rate at approx 1/2 to 3/4 of a ton. Your water output is pretty much normal.
Jun 23, 2008 | NewAir Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
287 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
